Question about Panasonic NN-S254BF Microwave Oven
Panosonic NN-S525BF Latch Spring Broken
Actually its the plastic post that secures the bottom loop of the latch spring that is broken, making the spring useless. The plastic edge of the door is also cracked near the bottom. I can see the broken "post" lying in the bottem of the door's interior when I bend this piece of plastic out. Of course without the latch spring working, the microwave door does not activate the safety required to operate the microwave.
The Sears parts website is the only place I can find a basic schematic diagram to order parts to repair the door, but I cannot figure out how to get the door off the hinges or to disassemble the door so that I can replace the part that has broken inside.
Does anyone have a service manual or knowledge that can help me remove and repair the door componens?
Many thanks for your assistance!
  • thebingamans Jan 25, 2009
    This repair took me about 15 minutes and cost me nothing! I first used a putty knife to release the choke cover (the plastic door liner that faces the inside of the microwave). And yes, it only takes one putty knife to release the plastic tabs securing the choke cover as you work around its perimeter. The plastic tabs are engaged in square receiving holes on the metal inner door frame.
    The plastic post that secured the bottom of the latch screen had broken off. Rather than rely on an epoxy bond to reattach this post, I opted to use a plastic gypsum board anchor (the type that you insert a screw in to secure in the wall). I slimmed one end loop of the latch spring around the plastic anchor and then firmly wedged into the square hole in the metal door frame beside the broken post location.
    I then snipped off the plastic tab that used to be held in this square hole as there are others nearby to secure the choke panel. I then used a nearby BBQ skewer tip to lift the other end of the latch spring onto groove at the base of the latch assembly and pressed the choke cover back into position. There is a very satisfying snap as each plastic tab pops back in the square receiving hole!
    Now I can warm my coffee and celebrate another appliance victory thanks to FIXYA!
  • Panasonic Master
  • 9,098 Answers
You have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
In most cases, the spring mount on the inner door panel breaks off, and while the ideal way to fix it is to replace that whole panel, the time, cost and labor are considerable.
It's usually easier and cheaper and just as effective to use epoxy and some kind of hardware to fashion a new spring mount.
Or if there is enough material to drill a hole for the spring, do that, install the spring, then add a dab of epoxy to cover the bottom loop of the spring where it goes through the hole you drilled.
Let the epoxy dry overnight before you close the door or use the oven.
Posted on Jan 24, 2009
There should be tension from the spring that pulls the door hook down. If there is no tension, the anchor for the spring has broken off and the outer door frame must be replaced.
Sep 02, 2014 | Panasonic Microwave Ovens
Microwave oven door wont close
Most microwaves will have a spring loaded latch on the door. The likely issue is the clip for the spring has broken. Unplug it, put it on the benchtop and pry open the inside of the door. It's usually a soft plastic cover that with a gentle persuasion from a flat screwdriver will come off. Start above the latch and pry open as much ad needed. Locate the spring at the bottom, open up one of the fixing loops on the ends with long nose pliers and attach it to a fixed spot around the inside of the door. There are usually metal ribs inside the door and attach the other loop to the base of the latch
Mar 09, 2013 | Microwave Ovens
I have a Panasonic microwave. It is Model NN-T774SF. It has an inverter. The latch on the door will not close. Is it worth the cost of repair?
This is usually a pretty simple fix.
The spring has probably become disconnected from the door latch head assembly or inner door panel.
If so, you can either order a replacement for the broken part, or install a small screw into the broken part, reinforce it with epoxy, and then reassemble everything.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the parts involved.
Or you can watch a
Oct 25, 2012 | Panasonic NN-T774SF Microwave Oven
Door latch
see this causes and fix it. God bless you
Open Lever If the microwave door won't open the open lever might be broken. This part can be replaced separately.
Door Spring If the microwave door won't open the door spring may have broken. The door spring is located inside the door and keeps downward pressure on the door hook.
Door Latch If the microwave door won't open the door latch might be broken. The door latch is inside the microwave. The door hook, which is part of the door, engages with the latch to keep the door closed during operation. If the door latch or actuator breaks the door may not open.
Door Hook If the microwave door won't open the door hook might not be releasing properly. The door hook is installed inside the door and normally releases when the door is opened. The hook is made of plastic and will break over time. When this happens it will need to be replaced, it can't be repaired.
Button Spring If the microwave door won't open the button spring might be broken internally. The button spring can be replaced.
Button If the microwave door won't open the button might be broken internally. The button can be replaced.
Handle Actuator If the microwave door won't open the handle actuator might be broken. This is a plastic part which can become brittle over time. This part is connected between the door button and the door latch assembly.
Oct 15, 2012 | Samsung SMH9187 Microwave Oven
NEFF H5470NOGB Microwave door latch fault
theres a small plastic hook inside the door which holds a tension spring this will have snapped off stopping the latch from entering the lock its actually quite easy to fix the inner plastic frame can be unclipped with a small flat blade screwdriver exposing the hook mechanism and the spring will be lying in the bottom of the door frame you can reconnect it to the metal inner frame it stretches the spring a little more but it will never snap again ive done this loads of times with no probs otherwise you will have to replace the outer door to reinstate the broken hook.
Oct 27, 2008 | Neff H5470 Microwave Oven
Sharp Carousel Microwave door latch stopped working door won't stay closed
Normally the problem is not the spring, but a broken spring mounting tab on the door latch head (hook) assembly or the inner door panel.
If it's the door panel, it's usually easier and cheaper to use epoxy and some kind of hardware to fashion a new spring mount.
The door latch head (hook) is easy to replace or repair if that's the issue.
We have *critical* safety & disassembly info at our site, linked here:
We also have this full service manual at our site:
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the screws you need to remove.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 18, 2008 | Sharp R-1480 Microwave Oven
check the door latches inside the oven, open the housing and spray some lubricants on the latches.
Feb 21, 2008 | Frigidaire FMV145K Microwave Oven
Panasonic inverter door won't shut, light stays on.
Thanks for the tips - here is what I did (my wife calls me the Canadian McGuyver!) After taking off the plastic frame (using instructions in Solutions noted above) I used the metal part of a key ring and hooked one end to the spring and looped it around the thick finger/protrusion at the bottom. _197.jpg
Jan 28, 2008 | Microwave Ovens
Door Doesn't latch shut
Usually it's not thespring but instead the "latch head", which has a little loop on the backside to hold the spring. The loop breaks off.
The latch head is the long plastic piece with two protruding hooks which activate the hidden door switches.
The door will need to be taken apart (but not removed from the oven!) to get to the latch head. See the attached example photo.
If you or a friend decide to look into it, we have critical safety and disassembly information at our site, linked here on Fixya:
You can order Sharp parts from Tritronics at
We appreciate your thoughtful rating of our answer.
Nov 17, 2007 | Sharp R-1480 Microwave Oven
Door latches to microwave broken
I assume you're talking about the spring that keeps tension on the door hooks (latch heads, as they're called by Sharp). When you shut the door, the "hooks" are held down by this spring to actuate the door switches. To fix this, you'll have to separate the door panels. You can download the service manual from my Web site. There's a loop built into the latch head assembly and sometimes the loop breaks. If so, you can drill a tiny hold in it and reattach the spring there. There may also be a loop on the innner door panel to hold the spring. That one can break, too. If it's broken, you'll have to find a way to secure the spring to the panel. If the panel material is thick enough, a tiny screw eye could be inserted, then epoxied overnight to secure it. I've attached a diagram to this message that should help you. If that doesn't help you, I have the service manual for the R1600-series microwaves on my Web site at: Repost if you need more help.
Nov 15, 2006 | Sharp R-1610 Microwave Oven
Panasonic NN-S254BF Microwave Oven Logo
342 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
