Question about Kirby Ultimate G Bagged Upright Vacuum
I am trying to put a belt on my Kirby Classic vacum cleaner i just can't figure it out.
  • Kirby Expert
  • 324 Answers
HERE is the belt installation instruction. On your vacuum it is a bit different how the brush roll is installed but I am sure you will be able to figure this out. Adjust screws on the both ends of the brush roll to have bristles sticking out by about 1/8 of the inch.
HERE is also a video on belt installation but the one with pictures is more in depth.
Good Luck
Posted on Jan 27, 2009
How do I replace a belt in my classic iii kirby vacuum cleaner
The below link leads to an excellent video on replacing the belt. It's for a newer model, but I believe they're pretty much the same.
http://www.kirby.com/Portals/0/videos.html
Jan 15, 2011 | Kirby G4 Bagged Upright Vacuum
Why wont my kirby carpet cleaner pick the foam and water off the carpet leaving my carpet soaking wet?
Is the carpet washer attached to unit is the belt hooked up? don't use the vacum head you well get shocked.be careful
Jul 26, 2010 | Kirby G6 Bagged Upright Vacuum
I have problem with the belt and roller how to put
I read the fixit website about getting the roller off on maybe a newer version of Kirby vacuum cleaner is there a solution for the same problem with the Utimate G?
Aug 17, 2009 | Kirby Ultimate G Bagged Upright Vacuum
I'm trying to find out how to install a drive belt in a kirby G4
I think this video that I shot should tell you everything you need to know about replacing the belt, and how to do basic maintenance on your vacum cleaners roller brush.
If you find the video helpful, please kindly rate it by clicking the thumbs up icon below;
Thanks for watching!
Chris
Apr 26, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
How to replace a belt on a Kirby G4 vacum
Here's how you replace the belt on all Kirby Generation Upright Vacuum Cleaners;
Jan 25, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
HOW TO REPLACE BELT ON kIRBY cLASSIC 111 vACUM cLEANER?
I don't have a diagram, but I might be able to explain it to you.
Take the nozzle off the machine. Remove the brushroller and old belt.
Set the belt pulley to the on postion. Put the belt on the roller and put the roller back into the roller housing with the belt centered. Turn the belt pulley to the off postion. If you look in the hole in the back what you want to happen is the pulley to spin and hook the belt stretching it out.
Put the nozzle back on the machine. Lock it into place and turn the pully to the on postion, and you should be ready to go.
Nov 25, 2008 | Vacuums
I have no idea how to put the belt back on
Take the nozzle of, remove the brush roll, put the a new belt over the brush roll, re-install and put the bottom plate on, making sure that the belt is in the middle of the brush roll. Turn the big knob on the front until it locks, when it grabs the belt it will be hard to turn. Re-install the nozzle on the machine and lock it down. Turn the knob again all of the way, this will release the belt unto the pulley.
Jul 13, 2008 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Heritage 84
http://geeksquad.fixya.com/ThreadView.aspx?prdid=11562&thid=699518
Kirby Heritage 84
Posted by sixbrocks on Jun 23, 2008
I can't figure out how to get the belt engaged on my Kirby Heritage 84. There are very simple instructions on the front assembly; however, the belt doesn't engage with the rotor, and the beater bar does not spin. When I have the front twisting section on the "Belt On" setting, it seems as though it actually disengages the belt. I see no faults in any of the mechanical parts, but just can't get the belt to go on the rotor.
(I purchased this machine @ a garage sale on Saturday. It's in perfect condition.)
My vacuum cleaner is a Kirby 84 Legend.
Help! Jennifer
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. You can always check your owner’s manual but the Kirby has a dial on the front of the machine and you needs to dial the belt off of the fan pulley counter clock wise and to check to see if the Kirby bell housing will release @ the top so that you can remove the bell housing. If not then remove the bottom plate and take out the brushroll on one side and then slide the belt off of the brushroll. Then you can slide the new belt onto the brushroll to the center and then re-insert the Kirby brushroll with the screw heads facing downward then you can replace the bottom plate – then use the Kirby spoon or hook to dial the belt onto the fan pulley clock wise. Once that is done then plug in the Kirby and try to vacuum to see if the Kirby is picking up properly, if not repeat the process. If you have a question, feel free to contact your local vacuum cleaner dealer in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://kirby.com/ Customer Service – United States & Canada 1-800-494-8586
Hours 8:00 am to 5:00 pm (EST) U.S. & Canada Fax # 1 (216) 529-6146
Mail To:
Consumer Relations
The Kirby Company
1920 West 114 Street
Cleveland, OH 44102
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 23, 2008 | Kirby Heritage II Vacuum
Kirby G6 drive mode
look under the vacume cleaner and take off the cover make, shure the belt is where it needs to be, you should have a setting on the vacume cleaner that gives you an addjustment for the carpet your on, raze it up.
Nov 26, 2007 | Kirby G6 Bagged Upright Vacuum
Kirby vacum cleaner
TURN THE BELT LIFTER IN THE FRONT CLOCKWISE UNTIL THE RED ARROWS LINE UP. NOW TURN THE LATCH AT THE TOP OF THE POWER NOZZLE AND TAKE THE NOZZLE OFF. HOOK THE HOSE EVENLY ON THE BAR BELOW THE FAN, LEAN IT UP AND LATCH IT ON WITH THE LATCH.
IF YOU NEED ANY MORE HELP WITH THE POWER NOZZLE, SEE MY ONLINE GUIDE...
http://reviews.ebay.com/CHANGING-THE-BELT-ON-A-KIRBY-G3-G4-G5-GSIX-ULTIMATE-G_W0QQugidZ10000000003720039
HOPE THIS HELPS!
MARCI
Nov 09, 2007 | Kirby Ultimate G Bagged Upright Vacuum
Kirby Ultimate G Bagged Upright Vacuum Logo
85 people viewed this question
Top Kirby Vacuums Experts
JoeVacs
Are you a Kirby Vacuum Expert? Answer questions, earn points and help others
