Question about Garden
0340 AV stihl chainsaw won't fire
My stihl chainsaw won't fire-- it has spark, but will not fire-- what is the problem?
    President:
  • 2,692 Answers
Spray a little starter fluid down the carburator . It is starts then is is a fuel problem. Most likely a gummed up carburator. Remove and clean .
Posted on Jan 24, 2009
Instruction on how to start a stihl chainsaw model 014 AV
this is a picture of a 014
looks basic..older model .. no safety features
starting all depends on
carby idle hi /low set correctly
air filter clean
clean fuel....fuel /oil mix
good spark
new spark plug if required
chain oil in oilier section
correct chain tension on the cutting bar
being a two stroke
and the engine has good compression
crank casing seals are in good condition
never have your body in line with the chain
it could run off the bar at startup ..flick .onto your arm or face
choke on
trigger lock on
hold the handle and pull cord handle ..firmly
let the weight of the chainsaw start itself
let the chainsaw go downwards till motor splutters
choke off
trigger lock on
drop the chainsaw downwards a few more times
and it should start
other way is put foot in the foot plate of the handle
and start sequence is the same
if not something is out of adjustment or needs servicing
Oct 14, 2016 | Stihl Garden
Stihl chainsaw problems
Adjust the high speed screw on carb
Install a new spark plug
Use fresh fuel
Aug 05, 2014 | Stihl Garden
How to remove the clutch assembly on a stihl 015 AV
Remove spark plug.
Use a piston block to stop the piston rising.
Remove the chain sproclet cover.
Turn the clutch with a socket clockwise to undo.
Dec 11, 2012 | Stihl Chainsaw Hedge Trimmer Clutch 015 Av...
Stihl 038 super av starts hard, once started runs great till its warmed up then dies and wont start
check the seals on the crankshaft for a leak and the ignition module for a loss of spark as it warms up.
Dec 07, 2012 | Stihl 038av Case Buffers Caps / Plugs 2...
My stihl 031AV chainsaw bogs down when pulling trottle
Ive had numerous similar faults with both stihl and husqvarna saws. all turned out to be leaking fuel tank vents. Im not sure if this model has a vented tank or not but it might be worth checking. Sounds like a fuel/air issue.
Nov 28, 2012 | Stihl 031av Manifold /intake Boot 032 030...
Can't start sthil AV34 chainsaw
Do you sitll have a good spark.? Have you increased the gap too much.?
Nov 12, 2012 | Stihl Garden
Working on a Stihl 16" 031AV Chainsaw and have
Plug may have weak spark, as odd as it sounds it does happen, try fresh plug.
Sep 02, 2011 | Garden
I have a Stihl 028 Av super chainsaw it has been runing well but now I can't start it how do I check the spark on the ingnition
Just remove the spark plug, connect the wire, and lay the plug base on engine metal. Turn on the ignition and pull the starter. If nothing, first try a fresh plug gapped at 0.020". If still nothing, service on the ignition system is required. Suggest finding a Stihl service dealer if you don't have mechanical service skills. Hope this helps!
Nov 22, 2010 | Garden
I have a stihl chainsaw that won't fire
DID YOU REMOVE THE PLUG AND CHECK THE SPARK AT THE GAP? IF YOU HAVE FIRE THERE THEN THE PROBLEM MUST BE A FUEL PROBLEM. ARE YOU USING A FRESH GAS MIXTURE? YOU CAN PUT A FEW DROPS OF MIXED GAS IN CYLINDER THEN RE-INSTALL PLUG TO SEE IF IT FIRES, IF IT DOES THEN YOUR NOT GETTING GAS FROM THE CARB.POSSIBLE STUCK DIAPHRAGM. GOOD LUCK!!!
Jan 24, 2009 | McCulloch 16 In 4.5 Hp Electric Chainsaw...
Garden Logo
762 people viewed this question
Top Garden Experts
EugenesDIYDen
EugenesDIYDen
Dennis Key
Dennis Key
john h
