Question about Nikon D60 Digital Camera
My nikon d60 won't turn on
I was putting in my charger after charging complete and did not notice camera was on the ON position. When i put in charger i heard a little pop and now camera will NOT turn on. Took camera to a camera shop and my charger was entered into another D60 and it worked fine. The new charger was put into mine and it would not start. Is there an internal fuse I can have replaced. Nikon too expensive. If so where are they located and where can i purchase one. Please help.
    Genius:
  • 1,019 Answers
There is no fuse you can replace, the camera needs repairs.
Posted on Jan 27, 2013
Steve5
  • 423 Answers
SOURCE: Nikon D60 highlight
When you have the flashing highlight areas, press the down arrow on the command dial and it will scroll through various playback screen options until you get to the screen you prefer to view.
Posted on May 30, 2009
  • 9 Answers
SOURCE: Can not get pictures off of internal Nikon D60
You don't. Without a memory card in the camera, there are no pictures to get out. It's really hard to be nice when they ask these kinds of questions.
Posted on Jun 28, 2009
SOURCE: Nikon D60 memory card problem. When i turn my
check your sd card, there's a tiny bar on the side that you can "slide" to unlock...
Posted on Aug 24, 2009
  • 102366 Answers
SOURCE: Will the Nikon SB600 speedlight
Yes. The SB-600 instructions don't mention the D60 because the SB-600 came out before the D60 existed. Bear in mind that the D60 does not have a commander mode so you can't use the SB-600 as a slave.
Basically, as far as the SB-600 instructions are concerned, just pretend that you have a D40.
Posted on Dec 30, 2009
  • 51 Answers
SOURCE: My nikon D60 is taking dark photos.
The only reason the camera will be taking dark photos is when it is under exposing the image taken. This can be due to the exposure compensation set to under expose the metered exposure. Make sure the expsosure compensation is set to '0' or increase it to compensate for the dark photos.
Also inaccurately metering a scene (such as a high contrast scene) can easily fool the meter into under exposing, especially outdoors.
Posted on Jan 03, 2010
Camera wont turn on after charging the battery
Bruce, you didn't provide a lot of information but I can tell you that the few times this has ever happened on my Nikon D-90, the battery did not charge, would not charge and I had to throw it away, or it was a charger problem.
I've had it happen when I tried to charge it on my corded Nikon Charger and I never got a charging complete indication after charging over night. When I put it in the camera, the camera indicated it was not charged even though the charger indicated it was charging. But, when I put it on a travel charger, it charged in about an hour and worked fine. The next time I put it on the Nikon charger, it worked fine.
I suggest you verify that the battery is good and charged or capable of charging. If it is, then check to make sure the battery contacts are clean both on the battery and in the camera.
If the contacts are clean and you're sure the battery is good and charged, I'd say the next step is to contact Canon. I've heard their customer service is very good.
May 20, 2014 | Panasonic Lumix DMC-FZ7 Digital Camera
Nikon s6300 won't turn on
Coolpix Cameras are tricky to use with chargers. I will assume your USB Charger EH-69P is 100 - 240V 50/60 Hz so it CAN work in many places around the world with an adapter. Do not go over 240V or you could damage it.
These cameras like to have the power supply connected when it is on to charge - meaning if you have it connected and you plug the charger in the wall it will NOT charge. So if you plug the charger in the wall first and then plug the cable in the camera it will work. The camera is actually ON when it charges and I never REMOVE the memory card when it is ON.
When you have a dead battery. Plug the camera in and make sure the ON LED lights and the Charge LED flashes. Then don't mess with it. Let it charge completely (Charge LED stops flashing and is OFF) and then unplug it. It will turn off. Then later you can turn it on.
May 08, 2017 | Nikon COOLPIX Cameras
I have a brand new Nikon D3100. The battery was fully charged and placed in the camera. I took about 4 photos, and then turned the camera off. When I turned it back on the battery wasn't working to...
The solution to your problem is simple, Kathrynbax.
The battery never comes in fully charged. It's always charged only so you may be able to check if your camera is working. I suggest, you take out your battery and put it to charge for exactly 90 minutes as the manual says. Then I'm sure you won't face any such problems.
Hope this solves your problem.
Good day!
Rebel
Sep 17, 2011 | Nikon D3100 Digital Camera
My current barrtery will not charge. So I bought a new battery and it will also not charge. It will flash for about 20 minutes and then the light goes solid as if it was charged. Whem I put it back in the...
Did you buy a cheap aftermarket battery? Sometimes those batteries are faulty right out of the box, sometimes they work great. If this is a "Nikon" battery you may have a defective charger.
Jul 18, 2011 | Nikon D60 Digital Camera
Nikon D60 won't turn on and the battery is charged, i'm getting nothing at all. The camera was left on for an extended period of time, is it possible the battery is dead. the camera is only six months old
Usually, when your battery has been in the charger long enough for it to be fully charged, the indicator light either changes color, or turns off. This indicates that the charge is complete.
Does your light do either, change color or turn off?
If neither of these works right, check your user manual, usually in the back, which will tell you what the indicator lights mean.
If your camera and battery are doing what they are supposed to be doing, then you may have bought a faulty camera, or the battery which came with it was faulty.
Be certain to read the manual very carefully, to be certain that you are following the instructions properly. If you have done everything right, then return the camera and or battery to the place from which you purchased the camera, and have them check it out to ensure that all is proper.
Dec 30, 2009 | Nikon D60 Digital Camera
Will the carama charge while plugged into the
No it will not charge.To get a reliable charge remove battery and use supplied charger
Jul 18, 2009 | Nikon D60 Digital Camera
Jul 10, 2009 | Nikon D60 Digital Camera
I thought the battery charged via the USB cord. It has to be charged only via the wall charger. Problem solved. I'm just a dummy!
Nov 22, 2008 | Cameras
Nikon D60 Digital Camera Logo
407 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
