I am installing a new thermostat and there are 3 wires to connect. 1 red, 1 green, and 1 white. Where do they go. Should I assume red to R or RC, green to G, and white to W? Thanks
    Problem Solver:
  • 13 Answers
Connect Green White Then Put red In Middle
Posted on Jan 24, 2009
I have 4 wires green blue red and white my red is connected to the rh rc with jumper green connect to g blue to y1 and white is connected to w1 my new thermostat has no rc rh or a jumper
Paulette, if your new thermostat has no Rc and Rh thats fine. The Red wire should simply go to the R terminal. The Rc and Rh terminals on the old one was for the old 'two transformer' systems. The vast majority of systems now have no need for the Rc Rh terminal and jumper. The rest of your wires connect as on the old stat also.
Jul 31, 2015 | Heating & Cooling
I installed the RTH 230B thermostat, Theheat only works when set to the cool mode, I only have gas furnace(no ac unit). My old wires are Red, white, green and blue. What wires go where?
Hey jim Try....RH/RC jumper (connected with a small piece of wire)...RH/RC=RED...W=WHITE...G=GREEN blue=unused... should give heat only (in heat mode) no ac..tks
Nov 12, 2011 | Honeywell Programmable Thermostat Heater
I am replacing a 10 year old Honeywell Thermostat with a mercury switch with a new programable digital Honeywell OS#RTH7500D1007 MD 0638. There a 4 wires coming out of the wall and are installed on the old...
You are on the right track, you can hook the same 4 wires to the new thermostat without the jumper you had on the old thermostat. The jumper wire that is on the new thermostat can stay with no problems. Just connect the wires to the same terminals on the new one and your good to go!
May 10, 2011 | Honeywell Electronic Programmable...
Installing thermostat - extra wire?
you have to go down to your furnace and follow the thermostat wire ...it connects to a terminal strip or fan centre...the color doesn;t really matter...installers mix and match all the time....look at the furnace wiring and mark it down...Red on "R"...Green on "Y" whatever it is...and connect it accordingly upstairs...if you only have 4 thermostat wires downstairs you will need a jumper wire between RH and RC...if you have 5 wires you will see 2 wires on "R" at the furnace.,...and connect either to RH and RC at the thermostat
Nov 01, 2009 | Honeywell Electronic Programmable...
Wiring
red goes to RC and RH, White goes to W, Green goes to G and Blue goes to Y. iam assuming on the old tstat that Red whent to R White went to W Green went to G and Blue went to Y
Sep 20, 2009 | Honeywell Programmable Thermostat Heater
Need help with wiring on Hunter 44110
There is no real color code for wiring but the standard is red wire to r, yellow wire to y,white wire to w, green wire to g, blue wire to c. since there's no c on your t- stat its probably battery operated, but in your case im betting white wire to w, and blue wire to g.
Mar 08, 2009 | Hunter Fan Company 5/1/1 Programmable...
Replacing a Williamson (White Rogers) Termostat
rh is power for cooling terminal and rh is power for heating terminal connect red wire to rc or rh and there should be a jumper between rc and rh if not install one all other wires are color coded correctly. now the blue wire is not used.
Jan 05, 2009 | Honeywell Electronic Programmable...
Hot air does not come on
common color code is as follows:
Terminal Wire Color
R RED
W White
G Green
Y Yellow or Blue
This does not guarantee your thermostat was wired to common color code. Assuming it is a single transformer forced air heating and cooling system the following is likely your problem there should be a RC & a RH termial on your new thermostat incase you need a split sub-base for multiple transformers. My guess is that you are connected to RC, if there is not a wire to RH the heat function will not work. the thermostat should have been supplied with a jumper to connect RC & RH together for single transformer applications. If not any small gage piece of wire will work, if I have assumed incorrectly please give me more info about your system.
Dec 11, 2008 | Honeywell CT87B ROUND HEATING&COOLING...
Hunter 44155c wiring from manual thermostat
I have a manual thermostat with the following wire connections (Y, G, R, O, C, & E) with the respective wires attached (yellow, green, red, orange, blue, white). My 44260 has available G, Rc, Rh, Y/O, W/B, Y1. Which wires should I connect to which terminals on the 44160. Thanks.
Jun 19, 2008 | Hunter Fan Company 5/1/1 Programmable...
Changing out home heating and cooling thermostat
Yes, the blue or yellow are interchangeable. they are for the cooling mode. Just first make sure the white is heat, green is fan and red is the power 24v.
Dec 17, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
