Question about Acer X1230 DLP Projector
Acer dlp projector model no dnx0905 spreparts
There is a white vertical lines appearing every time we open Acer X1130P DLP Projector
means the DMD chip is broken,you need a new DMD chip.I supply the DMD chip and the price is USD120
Nov 20, 2013 | Acer X1130P 3D Ready DLP Projector...
How to connect Acer X1161 3D DLP Projector via USB
1-i have some dots like pixel damage so i need a solution for that
2- i need to connect via usb cable but i cannot connect
thanx
Jan 26, 2012 | Acer X1161 3D DLP Projector
My Acer X1130P has white dots (dead pixel)..... How can I fix the problem
You will most likely have to get the DMD chip replaced. I suggest you get a quote from the local Acer agent as to how much it would cost for this repair.
Aug 22, 2011 | Acer X1160 DLP Data Projector, 2,000 ANSI,...
I plugged in the acer dlp and it came out a white vertical lines in the display,is it at the bulb? or is it in the settings?
this sounds like the DMD board on the light engine not working properly. It's not something that can be fixed in the settings, but it is a hardware failure. light engines are usually very costly to repair. if the projector is still under warranty have it serviced by Acer.
May 27, 2011 | Acer X1130P 3D Ready DLP Projector...
ACER PH530 COLOR WHEEL
http://www.mk-electronik.de/hersteller/PDFDokumente/Acer/Projector/PD520.pdf
Aug 27, 2008 | Acer PH530 DLP Projector
Acer X1230 DLP Projector Logo
233 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
