Question about Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit
Bottom lights do not turn off
Hampton fan bottom light does not turn off, previous fan had fan and lights control by the two switches on the wall, I believe this is on the one switch(when this was installed I did not see the work done). Could this be the problem?
  • brkptfingrou Jan 24, 2009
    Thge previuos fan was controlled by one switch for the fana dn the other the lights on the fan. This was installed and one switch does nothing. The lights go on when the switch is turned on and the remote does control the fand and the upper lights. The lower ones do not respond. I was thinking that the person who hooked it up put everyhting on one switch but before I took the thing down I thought I would check here
  • Brian Jacoby May 11, 2010
    It's hard to say what the problem could be without knowing what wires you have going where. If you have two switches on the wall, then are both switches doing anything? Does the fan work on one switch and the light doesn't work on the other switch? Did it used to work?
  • 37 Answers
If you have a remote for the fan and light, then it makes sense that only one wall switch operates as a master switch. Then as far as why the remote doesn't operate the lower light, the question I would have is whether the remote you have for the new fan came with it or not? If the remote you have has a button for the upper light and a button for the lower light, then you need to make sure that the reciever in the fan has wires for both lights. On the receiver there should be a black and white for the power and neutral coming from the switch. Then there will be a white wire for the neutral to the fan, a black wire going to the fan, and probably a blue wire for one of the lights. If there is another wire on that reciever (it may be orange or some other color) that would be the wire for the other light. That would be simple... four wires from the fan to four wires coming off the reciever. What you might have is four wires coming from the fan, and three wires (other than the black and white which connect to the wires from the switch) coming from your reciever. The way around that is to connect the two lighting wires from the fan to the one lighting wire from the reciever. Then when you press one of the light buttons on the remote, the upper and lower lights will always come on together. The other possibility is that there is a problem with the lower light kit itself. I would first check the wiring inside the canopy of the fan where the receiver most likely is.
Posted on Jan 25, 2009
Trying to find manual for a Hampton Bay ceiling fan. I have two. Tag on fan says model: AC-552AL, Item# 154620 NN, Another sticker on fan says 05/02 E192641 UL Listed CEILING FAN 47BF
You should find what you need here:
Apr 03, 2017 | Hampton Bay Dryers
Need to program Hampton Bay Ceiling fan remote control CHO88T7030T, HELP!
Change the battery. This is the first step when troubleshooting a ceiling fan remote. The easiest fix to any remote control problem begins with battery replacement. A 9-volt battery is needed to operate all Hampton Bay ceiling fan remotes.
Check the light switch used for the ceiling fan. The light switch found on the wall must be in the "on" position. This allows the ceiling fan to be operated by remote control
Re-program your remote. If battery replacement fails to get your remote working again, try to reprogram the remote. Open the battery cover you will see 4 dip switches. These switches must be set to the same position as the receiver on the fan. Use the screw driver to move the dip switches either up or down.
Follow the previous step to change the frequency if the ceiling fan is randomly turning on or off. Other electronic devices such as garage door openers can interfere with the ceiling fans receiver, causing it to randomly turn on or off.
Sep 10, 2011 | Televison & Video
I have a Hampton Bay ceiling fan with light. It is white with a round florecent tube. The fan works fine but the light will not turn on. I have tried replacing the light bulb with no success. The only...
It may simply be a case of a loose wire to the light fixture. But, you want know, until you remove the light kit and check the wires in the bottom of the fan housing. Be sure that the wall switch is OFF or the circuit breaker that handles the fan is OFF, before attempting any troubleshooting.
Jul 06, 2011 | Hampton Bay Heating & Cooling
My dimmer is not working
Never use the dimmer switch for ceiling fan.
Jul 19, 2010 | Hampton Bay 24002 Ceiling Fan
Can't use Wall Switch to turn on light
The problem may not be with the fan, but with the wall switch. Try changing the wall switch and see if that works, sometimes they go bad.
Jun 03, 2009 | Hampton Bay 24002 Ceiling Fan
Lights flicker when turned off by remote
I had this same problem with a Hampton Bay fan with a remote light switch. I call the manufacturer of the of the switch and was told that the model switch I had would not work correctly with CFL bulbs. The problem is with the dimmer function. You either need to change the bulbs to incandescent, or change the remote receiver in the ceiling. Hampton Bay was kind enough to send me a new receiver that works with CFL. The CFL units are white, and the incandescent is black. Hope this helps you.
Feb 26, 2009 | Universal Remote Control Hampton Bay...
Hampton Bay Classic Collection 52" remote ceiling light/fan
rechecked wiring, but blue with blue, white with white, etc., now lights work with remote,but fan only works with wall switch - so why doesn't fan work with remote,if lights work the remote & receiver must be ok?
May 30, 2008 | Hampton Bay 52 In. White Redington...
Hampton Bay 52 In. White Redington III¿ Ceiling Fan w/ Remote Control & Light Kit Logo
147 people viewed this question
Top Hampton Bay Dryers Experts
Craig Butler
Craig Butler
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
