Question about Diversitech Condensate Removal Pump
Green and red light stays on
Model cp-22
I have a Sharp stereo system that needs a new belt for the turn table. What size belt do I need?
Use a string to wrap around the table and pulley to get close approximation of size. Reduce number by a smidge and get that.
Sep 03, 2017 | Sharp Computers & Internet
When power button pressed get three blinks accompanied by a squeal with each blink. I replaced capacitors CP 130, CP 120 and CP 114. I removed CP 150 and verified it good with meter. I replaced fly
Your Set Is In HV Shutdown,Probrably Caused By A Shorted Flyback Transformer & Horiz Output Transistor,With That Model Rca, These Items Are All On One Separate Module Or Board,Which Can Be Purchased Seperately..
Sep 24, 2014 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi CP-A52 will not open keeps moving back and forth and will not project
You are listed in the Cars and Trucks section. Relist in a category more closely matching your product for a knowledgeable Expert.
Sometimes if you visit the Manufacturers website, there will be access to Repair manuals model specific.
Aug 28, 2013 | Hitachi Gst Hitachi CP-A52 Projector...
Diversitech cp 22
the filters could be blocked on your indoor unit or iced up coil due to air flow across coil or due to loss of refridgerent or the drain from indoor coil to outside is blocked or flat bateries in remote try fix those see what happens to clean filters use hose
Jun 29, 2013 | Heating & Cooling
Is the only difference between at CP-X1200 and CP-X1250 the bulb, or is the ballast circuit different too? Just thinking how easily I could boost the brightness from 3500 to 4500 lumens.
Model: CP-X1200 ( Lamp)
Part#: DT00591
Lamp Type: UHB
Wattage: 275 Watts
Lamp Hours: 2000 Hours
Model: CP-X1250 ( Lamp)
Part#: DT00601
Lamp Type: UHB
Wattage: 310 Watts
I'm not sure but I would think the same ballast board is used, and the trimpots adjustments set in the factory.
If you fiddle with it, you may not be able to get the tube to strike on startup, or worse you can explode the lamp.
Also the extra heat generated may degrade the optics and LCD panels.not mention melting the housing.
Better to leave well alone.
Feb 18, 2011 | Hitachi CP-X1200 Multimedia Projector
I have a Motorola Axu4100 , I want to change the frequence that I currently have on this radio to a Motorola CP-200...just wondeing if these two radio can work together....
Hi
Motorola CP-200 have frequency range
VHF: 136–162, 146–174MHz;
UHF: 403–440, 438–470, 465–495MHz depending on the model
Motorola AXU4100 have frequency range 435 - 480 Mhz
The first model has a wider frequency range so it is best to include transmitter Motorola Axu4100 to transfer and try to receive signal to Motorola CP-200
Sep 03, 2010 | Motorola AXU4100 (10 Channels) 2-Way Radio
I need to find the user manual for a Hatchrite Mobel Number HR CP I-250 or HR MP I-250 incubator.
See my free Hatchrite information web site at
http://idk.serveftp.net/hatchrite/manual/
There are manuals available for download for the CP-50 and the Watlow controller that goes with this model. Hatchrite used the same hardware on many different models, so the CP-50 manual may give you a good start.
Best regards,
Kevin G. McCoy
Dec 10, 2009 | Kitchen Appliances - Others
Ppano mgreprogram ng cp q?
ano ba model ng cp mo e mail mo ako erwinkylevillafuerte@ymail .com im a technician
Jul 19, 2009 | Nokia 3650
I need to find parts for my old Chicago Pneumatic impact wrench
You may be able to find your parts online but you will probably pay a lot more than you need to. Your best bet is to call or go to a service center that deals with CP. There are 3 different anvils for that particular model so you will have to get the right part number. You can get information by emailing or calling CP for the nearest service center to you.
Mar 26, 2009 | Chicago Pneumatic CP7750 1/2" Air Impact...
I have a 92 model nissan largo ld 20 diesel engine 4 cyl i have replaced glow plugs but when i put battery on it blew my relay wire near the battery and the plugs are 2xcp70 and 2x cp 71 is there a...
in a 4 cylinder diesel 2x cp 70 in front cp71 in the rear the reason why inline fuse blew cause by an electrical fault in the alternator thanks heaps after the alternator was replaced it work
Jul 17, 2008 | Nissan Minivan Cars & Trucks
Diversitech Condensate Removal Pump Logo
Top Diversitech Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Diversitech Garden Expert? Answer questions, earn points and help others
