Question about GE JVM1440 Microwave Oven
Microwave model jvm1540dmlww went out when door closed
When I closed the door everything went out. I turned circuit breaker back on ,checked fuse and still doesn't work.
  • GE Master
  • 9,098 Answers
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
See:
http://www.microwavedisplay.com/safety.txt
http://www.microwavedisplay.com/disassembly.txt
http://www.microwavedisplay.com/doorsw.txt
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Please write back if you need further help.
Posted on Jan 24, 2009
Everything went out
you blew a circuit breaker...find fuse panel and reset breaker. It will be the one that is tripped
Apr 05, 2014 | Maytag MMV5207BAW Microwave Oven
GE Profile Microwave, model JES2251SJ02, just stopped working.
1= reset the c.breaker from your home see if are tripped and reset.
2= open for thermal fuse open, test continuity with DVOM OR VOM and replace.
3) test the power cord for open or broken or break.
4= check the switch for door maybe is open must be continuity until 0 , or swtich defective see the diagram attached. God bless you
Jul 13, 2012 | Microwave Ovens
GE Microwave Spacemaker2. The toouch screen does not respond
could use a little more detail.
when u have no display screen the solutions are. possible causes * A fuse in your home may be blown or the circuit breaker tripped. A. Replace fuse or reset circuit breaker
* Power surge. A. Unplug the microwave oven, then plug it back in.
* Plug not fully inserted into wall outlet A. Make sure the 3-prong plug on the oven is fully inserted into wall outlet.
* Door not securely closed. A. Open the door and close securely.
Jan 19, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Panasonic Genius Prestige Model NN-P794SF No power ! Checked circuit breaker OK switched receptacle still no power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking TCOs or thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
The TCOs you need to be concerned usually with have all black or white wires only. Please reply with photos of your interior if you have questions.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can order Panasonic parts here.
You can find an authorized Panasonic servicer here.
Sep 28, 2008 | Microwave Ovens
No Power
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Aug 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
LG microwave model MV1526B
The pop leads me to suspect that the high voltage rectifier diode blew.
We have the service manual for this model and have uploaded it to our site here to help you. You will need the free Adobe Reader to view or print it.
It may be the fuse, which is usually located on the floor of the oven behind the control panel or between the door switches.
Aug 08, 2008 | LG LMV1650SW Microwave Oven
Panasonic Dimension 4 microwave model NN-C703BBPQ not working. Display is not illuminated as if fuse has blown. Have changed fuse in plug, but still no visible sign of life. Anything obvious that might...
Jul 29, 2008 | Panasonic Microwave Ovens
My microwave over my stove just stop working. There is power in the wall receptacle, the circuit breaker has not tripped,what is the problem.The microwave is a LG appliance model#LMV1630ST, serial...
Ifthe fuse is good, it may be an open thermostat or thermal cutout (TCO)/ thermal fuse on or near the magnetron or on top of the cavity / bodyof the oven.
If it goes dead for a while during or after cookingthen comes back on, the magnetron is probably overheating and causingthe magnetron thermostat to open.
Whenchecking thermostats, if it has a hood fan thermostat, that should readopen, as opposed to the others, which should read closed.
Ifit goes dead or blows the breaker (or GFI) when you plug it in or open or closethe door, then there's a problem with a door switch or door switchmount.
If it's intermittent or random, it may be a badconnection, usually on the control board or a loose fuse holder, oreven an intermittent fuse.
You should do a continuity test onthe fuse while it's in the holder (with the microwave unplugged, ofcourse) then turn the fuse by hand or take it out and put it back in,then test it again.
If you remove the fuse, then press the meterleads against the ends, it can allow internal contact to be made andmake a bad fuse appear to be good.
ForGoldstar / LG / L.G. parts, call 1-800-243-0000 (M-F, 7am-8pm CT, Sat8-5 CT) and choose the appropriate prompt from the menu or visit here.
We're happy to help you and we'd appreciate yourthoughtful rating of our answer.
Jul 15, 2008 | Microwave Ovens
My Panasonic Microwave Oven will not turn on. It is model: NN-T694. I have only used it for two years and not very much. It was working fine this morning; however, when I tried to use it for lunch, it...
If it goes dead or blows the breaker when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 05, 2008 | Panasonic Microwave Ovens
GE JVM1440 Microwave Oven Logo
47 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
