Question about Zanussi Tricity Bendix Washing Machine Drain Pump Filter
Where is the filter on a Zanussi zwg1121p washing machine
  • 249 Answers
SOURCE: zanussi aquacycle 1600 washing machine..cannot remove the filter at the front
prise it out with two flat screwdrivers you may have to use a pliers .good Luck
Posted on Dec 02, 2007
  • 17 Answers
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
Posted on Dec 17, 2008
SOURCE: zanussi washing machine filter
Open the panel at the bottom right of the front of the washer. Then pull out the drain hose and pull the plug from its end - this will drain most of the water. Then the filter turns anti-clockwise - if it is too stiff to turn by hand I use an open set of pliers or strong scissors to give more grip (It may be an idea to put a cloth between the pliers/scissors and the filter to offer some protection.
Posted on Jun 21, 2009
barkencoa
  • 3463 Answers
SOURCE: Zanussi Aquacycle 1050. My washing machine seemed to stop spinnin
Locate the filter at the botton front right of washer, behind a drop down cover.
Unscrew anti- clockwise to remove and clean.
If still no go, then you need to check the brushes in the motor.
Hope this helps.
Posted on Dec 31, 2009
  • 50 Answers
SOURCE: DO I HAVE TO REPLACE THE FILTER WHEN E20 COMES UP
Simple in most cases its just the filter outlet has become full of day to day junk, debris and slime.
Slowly release the water by turning the handle to release the water. Ensure power is off.
Once the water has been drained into a shallow tray you can open the door.
Once the drum is empty, unscrew the handle completely to remove filter housing and clean out thoroughly.
replace and tighten up.
Turn on power and reset all programs.
This should work, Will take about 15 minutesto do, If it doesn't work, then it may be your pump. Also, check your long drain to see if there's anything clogging it up, rubberbands, hair bands coins, sock, etc.....hope this works for you....
Posted on Jan 09, 2010
Zanussi z918 washing machine wont empty or spin although the pump seems to work
if the pump seems to work, check outlet hose for blockage/check pump filter as well
Dec 09, 2011 | Zanussi Washing Machines
I need to clear the filter on my zanussi zwf16070w washing machine but dont know how to and cannot find the manuel for it??
If it is a british made washer, then the filter is usually located at the bottom front right of washer behind a drop down flap or cover, unscrew filter anti-clockwise to remove and clean.
Oct 13, 2010 | Zanussi Washing Machines
I put on a load of washing and it stops half way through the machine flashes E20 n just stops the machine is a zanussi jetsystem zjd12191
Error code E20 relates to the pump/filter blocked.Drain the water either manually through the filter or drain hose.Check that filter is clean and pump can turn by hand.
Hope this helps.
May 19, 2010 | Zanussi FJS1225W Front Load Washer
Hope this helps.
Dec 31, 2009 | Zanussi ZWF1230W Front Load Washer
Zanussi washing machine will not empty
There should be a filter located at the bottom right front of washer behind a drop down down cover.
Unscrew the filter anti-clockwise to remove and clean.
If filter clear, then possibly the pump is faulty.
Hope this helps you with your problem.
Dec 02, 2009 | Zanussi ZWD1470W Front Load Washer / Dryer
Zanussi washing machine filter
Jun 15, 2009 | Zanussi F1245W Front Load Washer
ZANUSSI WASHING MACHINE
I have taken out the filter and washed it thoroughly! Also flushed the out pipe to make sure the whole system was clean. This resolved the problem
Dec 19, 2008 | Zanussi FJD1666W Front Load Washer
Zanussi electrolux washing machine zwf1431w
Dec 17, 2008 | Zanussi ZWF1430W Front Load Washer
Zanussi Aquacycle 1200
Pump jammed or filter blocked, check filter if not blocked remove pump and replace if faulty. Regards Advisor
Aug 01, 2007 | Zanussi FJS1225W Front Load Washer
Zanussi Tricity Bendix Washing Machine Drain Pump Filter Logo
162 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
