Question about HP LaserJet Pro CM1415fnw Color Multifunction Printer
Toner tray stuck - HP LaserJet Pro CM1415fnw Color Multifunction Printer
3 Suggested Answers
  • 66 Answers
SOURCE: Toner cartridge tray is stuck and will not slide out. Any help would be great.
open front door, when machine starts to run and turn motors about 1 second, open front door. Toner tray should slide out now.
Posted on Aug 08, 2013
  • 66 Answers
SOURCE: HP cp1215 toner tray stuck
open and close front door, wait for the motors to start turning about 1 second then open front door. toner tray should now slide out.
HP CP1515n Toner tray stuck on right side
you should check transfer belt or fuser unit.
Aug 24, 2016 | HP LaserJet CP1515n Printer
Paper is stuck/jammed on the drum and I am having difficulty removing the d rum unit and toner
Hi lbestu,
Please Read Tip Carefully :-
Tip: To manually remove paper pull on the paper with both hands being careful not to tear the paper while pulling it. If you're unable to get to an edge of the paper that allows you to pull it you may need to manually rotate the gears that feed the paper through the printer.
1.Turn off the printer.
2.Inspect the location or tray the printed paper ejects to. If the stuck paper is visible manually remove it.
3.Remove all paper trays and any paper that may be stuck between the tray and the printer. If the stuck paper is visible manually remove it.
4.Open the printer door that allows you access to the printer ink cartridges or toner and look for any stuck paper. If the stuck paper is visible manually remove it
5.Turn the printer back on. If you continue to receive a printer jam error try repeating the above steps again. If issue still persist and you see no paper that is stuck in the printer it's likely your printer is experiencing another hardware issues and we suggest contacting the printer manufacturer for additional assistance or repair
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For
Brother Printer Support
Feb 05, 2014 | Brother MFC-7340 All-In-One Laser Printer
Toner cassette tray jammed
You'll need to remove the covers and find the release actuator slightly below and behind display/control panel. The actuator can then be taped so that the drawer will no longer get stuck, but when you replace a cartridge you will have to manually calibrate. Good luck!
Jan 06, 2014 | HEWLETT-PACKARD CP1525NW Laser Printer
Call hp and sit on the phone until they answer. They will talk you through it.
Oct 08, 2012 | HP Color LaserJet CP1215 printer...
Aug 28, 2012 | HP Color LaserJet CP1215 printer...
When i m on printer inittilizeing sound came but but any one light on and like hang dont work again,some times paper error light ,some time toner error light,
You can test the printer by three ways,
1. Press and hold Green button for atleast 5 seconds it will take out the configuration printer, also the toner status page will come too
2. If the toner light is on , check the current toner status from the test prints taken before,
3. if the Error light is on, make sure there is no paper jaming in the printer, remove any paper stucked on the tray side, as well as check by removing the toner also
One thing more you can check the configuration for the Printer tray selected in the system,
Remove the Printer Drivers from the computer and try installing the software again, sometimes if you have selected manual tray feeding, or you have selected Tray 1 as default Tray and there is no page in the Tray 1 it will also, gives you the error on printer, 2nd thing you can check is the Paper size, both in computer and on tray 2 in printer, you take out a tray from the printer and adjust the nob to A4 . if you are using this printer on network, you have to reinstall the drivers for the printer, and it should give you the print,
If you require more assistance, feel free to reply to this post,
Thanks for contacting FixYA!
Regards-BA
Feb 02, 2011 | HP LaserJet P2015dn Printer
My Brother MFC-9840CDW keeps jamming every time I print mailing labels. I've had it four 1.5 years with no trouble. The label gets stuck and I have to pull out the toner tray to fetch it. I also...
hello, sounds like there are many possible solutions for you machine, first with paper jamming, are labels going thru manual feed tray, or paper tray, it might be possible that mp feed roller needs cleaning or replacing. if paper tray, simple would be feed roller, clean or replace, if jams continue with normal paper from paper tray, the problem will be front door, i have yet to be able to repair paper jams when front door assembly fails. as far as colors, both drum and toner can cause this problem, if using 3rd party toner, this will also cause some color problems. sorry no real quick fix for this machine, i've tried.
Sep 24, 2010 | Brother MFC-9840CDW Laser Printer
Two error messages persist after replacing toner cartridge.
This kind of error indicates that your toner is not properly set or there is some paper jam. so please follow the instruction and open the panel and remove the toner and check for any kind of paper piece and than refit toner properly and close the panel and than check you will definatly able to resolve the problem ok
Dec 20, 2008 | Canon imageCLASS MF4270 All-In-One Laser...
Yellow light blinking after clearing a paper jam
hi
If this if a office printer its bound to have stuff fall into it like staples or paperclips. these things fall under the tray and get stuck underneath the paperout flag so firstly take the printer turn it upside down nb remember to remove the toner cartridge then shake it to get anything loose thats stuck in it.if you have done this and the problem persists then you have to strip the front section of the printer and clean out all unecassary things stuck in there.
The other problem could be that the toner does not connect properly. when you close the front door there is a pin that comes out and connects with the cartridge of the printer. this pin could be jammed or even dirty as toner get stuck on it. this pin earths the drum on the cartridge and if it does not connect then the jam light flashes
I have found alot of things like money, dust and lots of foreign objects stuck under the tray. If you can do it yourself then it is best to get a qualified service technician todo so for you
Dec 05, 2008 | HP LaserJet 1300 Printer
We need local repair person
I don't understand your website. I was charged 14.99 or so yesterday on my visa, but after your company accepted my payment, I learnedno one was available to help me. So I waited and this morning I have an email that is asking me to pay again or tell me how I fixed the problem.
It really is a simple problem that should be handled by you with a phone call rather than a lengthy internet procedure. I pulled out the toner tray and the bottom tray remained while the top came off and the powder spilled everywhere. I don't want to use a household vacuum on it. It is a mess. I need an approach to unhook the stuck bottom toner tray of the Mita DC 1455 (an old but serviceable copier) and replace the spilled toner with a new module. And how do I clean up spilled fine toner powder which is everywhere?
Jul 24, 2008 | Kyocera Mita FS 3800 Laser Printer
HP LaserJet Pro CM1415fnw Color Multifunction Printer Logo
482 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
