Question about Hobart 29 in. AM15-1 Free-Standing Dishwasher
Wiring a heater element on a hobart am14
While replacing the element I noticed only two wires goto the three loops for the heater element.
the loops are attached by jumpers to complete the circuts.
the left element and one connection on the center elemnt were attached to one wire.
the right element and one connector on the center element were attached to the other wire.
the center element was burd and had lime deposits on it the other two were clean and in great shape.
was the origional element wired wrong??
m.
  • Hobart Master
  • 8,220 Answers
That connection was probably a little loose and caused that.
Posted on Jan 24, 2009
Just purchased this heater, the fan comes on but the heat is next to nothing. I checked the voltage at the elements and is is 235v the amperage on L1 and L2 is 20.8a. If I pull the fan wire off the relay,...
First off, 20.8 amps is approximately the amperage draw on a single element furnace (nominally 5 kw.) So if you have 3 or 4 elements, (15 or 20 kw capacity) the problem is the remaining elements are not being enrgized. Look to see if there is a W1 and W2 and even possibly a W3 terminal on the terminal strip. If so, and its not a heat pump, there should be thermostat wires on all three, indicating three stages of heat. To energize those properly, the thermostat should be a multi-stage heating thermostat providing W1 and W2 at the minimum. If you do not have a multi stage thermostat, and there are no wires on W2 and W3, jumper W1, W2 and W3 together and the furnace will come on at full capacity with the single stage thermostat.
If you DO in fact have wires on the additional W terminals, you more than likely have a heat sequencer that is not energizing the 2nd and possibly the third stage of heat. A three element furnace is typically called a 15kw furnace and the three elements should draw approximately 19 to 20 amps each. So when each stage draws in, the clamp on amprobe on the main incoming wires will correspondingly increase with each stage.
Also, some 15 and 20 kw furnaces require two circuits to supply the elements, and I have been on calls before where the second breaker was not turned on, and in one case, the second circuit wasn't even wired in from the electrical panel box.
DO NOT pull the wire off the fan while the heaters are energized as they will rapidly cycle on an overtemp device. Some actually have a "one time" thermal link that once melted render the respective element inoperable until that thermal link is replaced. They will melt very easily. An energized element MUST have airflow across it !!!
Dec 13, 2014 | Ouellet 5000-Watt Utility/Garage Space...
I have a hobart am12 dishwasher. It blew the breaker. My service guy "who isn't a hobart dealer" said motor was bad. So I took it to a motor repair shop to be rewind. The motor repair guy said that he only...
http://tdfoodequipment.com/images/am14-14c.pdf
This has the contact info for Hobart on it. Given the age of the unit though, you might be out of luck. It is possible that the motor was done correctly and the power issue is somewhere else. There could be an internal fuse or a power transformer that has failed/
Nov 04, 2013 | Hobart AM14-253 Free-standing Dishwasher
'01 Sequoia throwing 2 OBD II codes: po125 & po135. replace pre-cat o2 sensor?
DTC P0125 OBD-II - Insufficient Coolant Temperature For Closed Loop Fuel Control
This means that the engine coolant temperature (ECT) sensor indicates that the engine has not reached the required temperature level to enter closed-loop operation within a specified amount of time after starting the engine. You will likely not notice any drivability problems.
A code P0125 may mean that one or more of the following has happened:
Insufficient warm up time
Low engine coolant level
Leaking or stuck open thermostat
Faulty coolant temperature sensor
DTC P0135 OBD-II - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
This code refers to the front oxygen sensor on Bank 1. The heated circuit in the oxygen sensor decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0135. You will likely notice poor fuel economy the illumination of the MIL.
A code P0135 may mean that one or more of the following has happened:
O2 Heater element resistance is high
Internal short or open in the heater element
O2 heater circuit wiring high resistance
open or short to ground in the wiring harness
For additional details, feel free to contact us in the preivous code link.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Oct 12, 2011 | 2001 Toyota Sequoia
What is diagnostic procedures for DTC p0135 & p0141
Oxygen Sensor problems... P0135 (Bank 1, Sensor 1) and P0141 (Bank 1, Sensor 2)
P0135 - Oxygen O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 1)
Symptoms: You will likely notice poor fuel economy the illumination of the MIL.
Causes: A code P0135 may mean that one or more of the following has happened:
Possible Solutions:
Repair short or open or high resistance in wiring harness or harness connectors
Replace oxygen sensor (cannot repair open or short that occurs internally to sensor)
P0141 - O2 Sensor Heater Circuit Malfunction (Bank 1, Sensor 2)
This code means that the heated circuit in the oxygen sensor on bank 1 decreases time needed to enter closed loop. As the O2 heater reaches operating temperature, the oxygen sensor responds by switching according to oxygen content of the exhaust surrounding it. The ECM tracks how long it takes for the oxygen sensor to begin switching. It the ECM determines (based on coolant temp) that too much time elapsed before the oxygen sensor began operating properly, it will set P0141.
Symptoms: You will likely notice poor fuel economy the illumination of the Check Engine Light.
Causes: A code P0141 may mean that one or more of the following has happened:
O2 heater element resistance is high
Note: Typically a failed catalytic converter does not cause this code. You're more likely to see a P0420 code for a failed converter.
Possible Solutions:
Hope this helps (remember to rate this answer)..
May 11, 2011 | 2000 Nissan Maxima
8975 does nothing,voltage out of switch but does not heat up or blow air
I have 4 dead MW heat guns with the same problem. The most common problem is a blown fuse in the heating element assembly which prevents the circuit from being completed. It is attached inline with the Red wire. Test the fuse with an Ohm meter, then use a jumper cable to temporarily jump the fuse. The fan and heater should then work. Replace the fuse and you will have a working heat gun
Nov 26, 2010 | Milwaukee Tool Milwaukee 8975 - 6 Dual...
I have a maytag side by side with water/icemaker. model msd2456dew. it has frozen up in the freezer, under the white interior paneling. we think this is what is causing the cool air to not filter into...
Checking defrost components on Maytag SideXSide refrigerators
To check the defrost circuit , unplug the refrig and inside the refrig section at the top about 2" in from each side in the back , there are "D" slots to put a finger in , and pull downward and foreward , to remove the control panel cover . Once removed , there is a 1/4" screw on each side holding the adjustment indicator panel on , 1 phillips screw behind both light bulbs , and 1 screw holding the complete panel to the rear wall . After removing these 5 screws , at the top right corner , with about 6-8 wires going to it , is the adaptive defrost board . Sometimes you can see the electronic board and on newer refrig's , a white box will be seen. Inside this box , is the adaptive defrost control . Disconnect the plug going to the board and on the right side of the PLUG , the far right wire is yellow , then another color , then white . Useing a small insulated wire with both ends stripped , insert one end into the yellow wire hole and the other into the white wire hole . This will bypass the adaptive board and send power directly thru the defrost bimetal ( thermostat ) AND heater to check if they are good .Plug the refrig back in . Now , wait about 3-5 min and look for a red glow at the bottom of the inside freezer panel , which will be the defrost heater or listen for sizzling which will be the frost melting and dripping onto the heater .If NO red glow , watch for a spark while removing the jumper wire you installed , from the plug . If a spark IS seen , then the heater was on and the heater AND bimetal are good . If you see the red glow , hear the sizzling , or see the spark , then the adaptive defrost board should be replaced . If no glow , sizzling or spark , then unplug the refrig and reinstall the refrig control section .
Remove the food in the freezer section enough so that the 2 screws holding the lower freezer panel on and the freezer panel , can be removed . Remove the panel . If the heater (black element at the bottom of the coils ) wires are visible , trace then to the top of the coils and disconnect . Use an ohm meter to determine if the element is good . If the element IS good , at the top of the coils , is a 1" cylinder with 2 wires , clipped onto the coils . This is the defrost thermostat ( bimetal ) . Replace this part if the element shows good . If the element shows bad , replace the element . NOTE 1 : sometimes the element and the bimetal come wired togather and the replacement part comes with a new heater and bimetal already wired togather . This would be the adviseable replacement part . However , each part can still be replaced individually . NOTE 2 : If looking at the bimetal and the top plastic " cap " looks cockeyed , replace the bimetal as moisture has gotten inside and disturbed its designed function .
Jul 28, 2010 | Refrigerators
Hobart dishwasher am14 displays 255 in temp window heater wont fire
The wash thermistor is shorted. The float and probe assembly in the wash tank should be replaced.
Jun 13, 2010 | Hobart AM14C-155 Dishwasher
Milwaukee 8977 - 20 Variable Temperature Heat Gun blows air but no heat. how do you troubleshoot the circuit board or the heating element?
With out the thing plugged in with an OHM meter the heting element can be checked with the nose removed. Most of the time once the nose is removed the problem is easy to see the end is burnt off the element connection. Remake the connection reinstall the nose and test. The heating element runns right off the switch and the connection there is easy to see with the handle opened. This is simple unit and wires burnt off from being too hot is almost always the problem. look it over carfully and the problem will be seen.
Apr 21, 2010 | Milwaukee Tool Milwaukee 8977 - 20...
Hobart am 14 electric heat does not turn on water temp just drops
Assuming that the machine fill cycle works properly and the float is intact, and the heater contactor doesnt pull in:
possible heater contactor malfunction: check for power to coil
High limit snap thermostat may be tripped or damaged ( needs to be manually reset). located in heater connection cover.
Thermistor probe and or wiring to it may be damaged
main control board may not be functioning properly. check output to heater curcuit
Feb 01, 2010 | Hobart AM14-253 Free-standing Dishwasher
Hobart 29 in. AM15-1 Free-Standing Dishwasher Logo
300 people viewed this question
Top Hobart Dishwashers Experts
Jason
Garth Jackson
Are you a Hobart Dishwasher Expert? Answer questions, earn points and help others
