Question about Tetra 16361 Vacuum Bottom Drain Portable
Question before purchase (existing pond)
Wandering if I can get a 3" pipe connection. Also trying to visualize if the pipe (hopefully will accept 3" flex pvc) can connect to the "Tetra Vacuum Bottom Drain" and from there, run uphill above water level, over edging stones and back down to pond level (outside the pond) into a settling chamber, and then to a bio/mechanical combo filter U.V. etc., with the pump at the END of all of the above, not before. (I don't want dirty water churning through a pump first before it gets to filters, this method doesn't work) which then takes water to the waterfall and back into the pond. I cant visualize if it would work like that, coming up over edging rocks (ABOVE water level). Im wandering if I would have to cut a hole in the liner and use a bulkhead to keep the flex pvc below pond level the entire route described above. The answere is probably simple but I can't get it through my head how these things work. Thanks.
  • Anonymous Mar 12, 2014
    Adjusting water level with a levolar system
  • 21 Answers
You don't need a bulkhead if your liner is EPDM. You can use a boot that is attached with adhesive that will seal you pvc piping. I don' t see a problem with dirty water going thru the pump before the filters. for some diagrams of settling tank installations see:
http://www.koipondfiltering.com/koi_pond_filters_diagrams_intermediate.html
Posted on Mar 05, 2009
2 Suggested Answers
  • 10865 Answers
SOURCE: Tetra Pond GreenFree 9W UV Clarifier
Hello. Get a tube of plumbers GOOP. Joe
Posted on May 02, 2010
Pond pump quit working
1. fix power cable fix in place.
2.fix hight and distance of sucksion and dilivery pipe ability
3.check ballbaring,impiler,valves,capacitor,and other part carefuly
4.first time starting u fill some water than start
5.check manual carefully
Nov 07, 2012 | Garden
I PURCHASED A DESA RADIANT HEATER AT A GARAGE SALE, IT WORKS BUT IS IT VENTLESS AND IT IS A MODEL 0630545
I would really like to help you determine what you have. However, the model number you listed is not a DESA model number. I think you may have listed the Serial Number instead. DESA/Vanguard/Comfort Glow wall heater model numbers start with 2 to 3 letters then 4 to 5 numbers.
However, to visually tell if it's Vent-free (Vent-less) look for a round hole for a vent pipe connection and/or look at the manufacture's data plate on the side or rear of the heater. It will tell you whether it's Vented or Vent-free. If it doesn't have a 3' round hole for a vent pipe, it's Vent-free.
Hope this helped you and thanks for choosing FixYa.
Sep 08, 2011 | Heating & Cooling
I purchased a house that the pool filter was stolen and I purchased a used filter with a side mount valve. I need to know how to plumb itto my pool. there are 3 ports.
Thank you for posting your question here on Fixya.com.
If it is a Hayward valve like your post suggests there will be a word cast into the black plastic area near all three ports you need to connect. One will say pump, another return and the last one waste.
Pipe the pump port to the pumps discharge. Pipe the return to a heater if one is present or back to the pool. Pipe the waste to an area where you can safely discharge water as you backwash the filter.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. You may also contact me thru our website at www.arrowpools.net. Positive feedback is appreciated once your problem is solved!
John
Feb 04, 2011 | Hayward Pro Series Side Mount Sand Filter...
Wandering steering on Isuzu Bighorn
Why, of course, Get an alignment because your front end is too much in the positive caster. Don't let anyone tell you it's the nature of the beast. Good Luck. Ask for the before and after settings to be put on your receipt._Ned_
Nov 18, 2009 | 1992 Isuzu Trooper
Replaced existing Lutron skylark low voltage dimmer
You will need to return the 3-way dimmer and get a single pole dimmer, as the Lutron Skylark series is suspectible to failure if connected to a live circuit first, or misconnected at intial installation. As an electrician, I ceased using these dimmers years ago, due to the rash of call-backs by customers and went with Leviton togglers and have had excellent results.
If you purchased it at a 'big box' store, they will accept the return as a defective item, as they have national agreements with their suppliers to accept customer returns. Just tell them it didn't work and you want a store credit, you can then purchase the lower priced single pole dimmer you need and save some money in the process too.
Hope you find this Very Helpful - best regards!
Aug 18, 2009 | Lutron Electrical Supplies
Audio output ?
MOST UNITS HAVE MONITOR OUTPUT ON THEM. IF YOU ARE GOING INTO THE PHONO INPUT ON THE RECIEVER YOU WILL NEED TO PURCHASE A STEP DOWN CONVERTER. THIS REDUCES THE AMPLITUDE OF THE SIGNAL DOWN, SO THE PHONO INPUT CAN ACCEPT IT.
Jan 23, 2009 | Televison & Video
PUMP RUNS BUT DOES NOT **** UP WATER
I have experienced this same problem and all I needed was to prime the pump. Unless your pump cannot pump up that high.
Jan 09, 2009 | Little Giant Opwg 71 71 Gpm Out of Pond...
Aerate a pond
I live near Memphis TN so don't have that pesky "frozen water" problem. However, I do aerate my 2,500 gal goldfish pond with a Oase Biosys Skimmer (free standing/ floating skimmer) which is powered by a Laguna fountain pump. I attached a small pipe on the discharge end of the pump & set the pump so that this pipe is a few inches below the water's surface. The discharge provides a small fountain effect that keeps the surface moving while aerating the water. The skimmer keeps the leaves / debris off the top of the water the pump keeps the water moving...and moving water will not freeze. Hope this helps
Raincreek
Dec 24, 2008 | Aquascape Designs Aquascape - AquaForce...
Tetra 16361 Vacuum Bottom Drain Portable Logo
128 people viewed this question
Top Tetra Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a Tetra Garden Expert? Answer questions, earn points and help others
