Question about Panasonic Microwave Ovens
Model:NN-SD277- Displays H97
robotek
  • 1512 Answers
SOURCE: h97
Hi there..
If it is displaying error H97, this means that the invertor(power supply Panasonic part number: Z606YM300BP,) is not functioning. The magnatron may also be faulty.
You can get a new invertor on ebay.UK from here
Here is some more information about the part. The microwave may also have a faulty magnatron. If you are unsure, then you should get someone to look at the unit for you before you go buying parts.
BEWARE... VOLTAGES INSIDE MICROWAVES CAN KILL
Panasonic part number: Z606YM300BP, supersedes all previous versions of the inverter used with the 2M261-M32J This Inverter is now available at a lower cost, it used to be £60.00 plus VAT and delivery trade price.
This inverter is fitted to many of the more recent Panasonic inverter type microwaves such as the NNC596S .Some microwaves such as Bosch and Siemens also use this inverter as they are rebranded Panasonic ovens. These ovens are upmarket models, some include advanced functions such as steaming and are normally well worth repairing.
The inverter as fitted to earlier ovens with the 2M236-M42 and 2M236-M1 is also available.
An inverter microwave oven is one without a high voltage transformer You will know you have one as it is not extremely heavy at one end. This type of microwave uses a high power DC converter, called an inverter, to produce the high voltage and filament voltage required by the magnetron.
If you purchase this item for replacement in your microwave then we recommend that you do this only if you are qualified and aware of the dangers of tampering with electrical equipment.
Failure of the magnetron is common and at times the inverter can fail as well. Sometimes the inverter fails on it's own. If your microwave blows the 10 amp mains input fuse as the cooking cycle starts then you probably need a new inverter. An instruction sheet with basic guidelines on fitting will be provided but please do not purchase this item unless you are confident about fitting it. We only accept returns if the inverter supplied is defective which is extremely unlikely.
If you have one of these ovens that is not cooking then it is worthwhile looking at the magnetron. It often shows signs of distress through overheating.
As well as the inverter failing it is also possible you could also have a defective magnetron,
Good luck and thanks for using FixYa
A FixYa rating would be spot on for this information to you.
regards
robotek
Posted on May 07, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: panasonic microwave no working at all
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
In Canada, you can find an authorized Panasonic servicer here.
Posted on Dec 28, 2008
fathitkf
  • 1871 Answers
SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Apr 13, 2010
SOURCE: Panasonic NN-SD277. Almost 3
We also have this same microwave. It is less than 3 years old. We've had nothing but problems since we purchased it. In November 2010, the microwave made a crackling sound and then BOOM! Nothing. I have been back and forth with Panasonic. I refuse to pay for the repair on an appliance that is less than 3 years old. It's ridiculous!
Anyway, the problem t is an issue with their inverters. Google it and you will find page after page of the same story.
Posted on Feb 15, 2011
  • 8909 Answers
SOURCE: I am a member of
For user guide and instalation instruction see;
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
I don't know what you mean about "tilting" unless is has not been installed on a flat surface.
Hope it helps.
Posted on Mar 30, 2011
I have a panasonic model nn-sd277 microwave. I changed the fuse and now it has power again. The fan and light all work. It trips my breaker and sometimes blows the fuse when you try to heat anything.
time to take it to an appliance repair shop for a quote
it is blowing fuses and tripping breakers because it has a serious short in the electrics
Jan 03, 2016 | Panasonic Microwave Ovens
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Panasonic flatbed microwave NN-sf550W displays code H97
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Jan 21, 2013 | Microwave Ovens
Oven door on PanasoniPanasonic microwave Model NN-SD277 won't open when pressing open button
I just had that problem. It is the plastic workings. One of the plastic posts that holds the pivoting lever had to be epoxied. That plastic rejects crazy glue, don't waste your time. Just epoxy and as much as you think can fit under the electronics and the metal plate you will have to pull out.
My suggestion is take pictures of every step so that you can hook all the electrics back up. There are some testy switches that must be unsnapped too.
www.ianklepsch.ca
Oct 08, 2012 | Panasonic Microwave Ovens
Panasonic nn-sn778s microwave shuts off and no heat- H97 is error code
You can find an authorized Panasonic servicer here.
Aug 21, 2012 | Panasonic Genius Prestige Nnsd997s -...
NN-SD297S The exhast fan still works but the oven
Due to the technology used in this model, there are no user serviceable parts inside. Call a Panasonic appliance engineer.
Mar 07, 2011 | Panasonic NNSD297SR 1200 Watts Microwave...
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
WARNING :
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Panasonic inverter model locked. How do I unlock
i have probleam with panasonic inverter model NN-SN977S ON SCREEN H97 NOT MOVING
Jan 28, 2010 | Panasonic Microwave Ovens
Microwave Ovens Logo
16 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
