Question about Coleman Propane Forced Air Heater w/Electronic Ignition (50,000-80,000 BTU)
Fan in furnance
I just received a large electric bill , i have a ques , when the furnance kicks on that goes on my gas bill, i was told there is a fan in the furnance & when that auto kicks on that is considered elect is this true
  • 92 Answers
Any furnace with a blower will go on your electric bill but it really should'nt draw enough power to raise your bill noticably unless it's running constantly.
Posted on Jan 24, 2009
Does the water heater and furnance run on gas and electric?
If the units are in a RV then yes, they both may run on gas and DC (battery power). The furnace requires gas to provide heat and DC power to run the fan. A water heater may be gas or electric, but if gas, it requires gas to heat and DC power to ignite. If the water heater is electric it requires AC power to heat.
Oct 15, 2015 | Water Water Heaters
Do you know if they purged the gas lines? Sometimes when the meters are changed air can build up in the gas line
Dec 07, 2012 | Heating & Cooling
Air conditioner unit out side is not working. The fan is not moving, and it is flipping our breakers. The furnace is still running - so we are circulating the air in the house. The big unit out side goes...
it could be the compressor or possibly the dual stage capacitor that starts the compressor and runs the fan ,it will be marked with H-for compressor appx35uf./F-for fan at appx 5uf./ and a C-common terminal in the center for the neutral line to both fan and compressor
Jun 04, 2011 | Air Tools & Compressors
I have a Goodman gas furnance. The furmance kicks on the glow rod lights and then the furnance shuts down after about 60 seconds it goes through the same cycle. The burners never come on. What's wrong?
Let's trouble shoot a few possibilities:
Can you confirm that your gas pressure/ supply is correct-- by lighting all of the range top burners at the same time-- Do they all light quickly, and burn to full height, without much of any yellowing at the flame tips? That should indicate you have god gas pressure and supply.
Now-- in the Oven itself-
When you light the BROIL burner-- does it's glow ignitor light up, and does that burner light off OK?
If it is only the main oven burner that is not lighting, are you able to remove the cover plate that covers it, and watch it light off? -- Any clues on whether or not the gas valve even open?
If NO gas flow, likely you need a new Main Oven Gas Valve-- Probably need to call your Gas Appliance service person.
Let us know if this helped
Mack B
Jan 23, 2011 | Goodman GMS90703BXA Heater
Gas valve is not kicking in or gas shut offs are off. Can you check voltage where 2 wires connect to gas valve. Can you see blinking lights thru lower door window and count blinks. Code sticker should be on inside of lower door.
Jan 23, 2011 | Heating & Cooling
Furnance not starting
Try cleaning the flame sensor. Its the most common problem on todays furances. You should clean it with a fine grit sandpaper or emery cloth once a year.
Apr 11, 2009 | Heating & Cooling
I'm renting an apartment with what appears to be an old...very old furnace. I've gone to the leasing office and nobody has come to look at it yet and it's been nearly 3 days without heat in my place. So...
i got a solution.don't mess with it.
just harrass the landlord till you get's against the law not to provide you with patient though....we are coming off the holidays.any people are just returning to work.that includes supply houses to get parts.
by the way, did you pay your gas bill?check for gas to the gas valve at the inlet.
Dec 21, 2008 | Weather King 12AJA6001AH Air Conditioner
Lennox Gas Frunace fires goes out, fires goes out, fires goes out
Check your thermostat anticipator setting. If you dont know how to do this don't try on your own or you may damage your thermostat.
Dec 12, 2008 | Honeywell Electronic Programmable...
Furnance will not heat
Check your voltage going into the gas valve. It should be 24-27 volts. If it is to low the gas valve will chatter. If the voltage is strong enough you have a bad gas valve.
Dec 09, 2008 | Heating & Cooling
Heating & Cooling Logo
139 people viewed this question
Top Coleman Heating & Cooling Experts
Bill Long
Paul Carew
Dan Webster
Dan Webster
Are you a Coleman Heating and Cooling Expert? Answer questions, earn points and help others
