Question about MSI K8MM-V Motherboard
My hdd sata is not detected by motherboar.
Hy.i`m from spain and my english is not very well, please sorry.
I have a K8mmv mother board and it was ok but yesterday when I turn on,it me say: check device, the bios doesn´t be installed, press G to continue. I press G, and then windows vista charge,ok.
the problem is that my hdd (seagate 500gb) sata i have like Slave is not detected anywhere, i have installed all controllers by via arena for windows vista 32 bits,ALL seriously. Via raid /ide V8237 etc all, but the problem doesn´t fix.
and another problem when I put off( i don´t no how it say) the hdd sata the problem, the bios doesn´t be installed, desapear.
the slave hdd is in sata 1, the primary with the OS is in IDE1,but the cpu don´t recognize me the sata disk.
i have clear the CMOS, but i don´t know what more i can do.
please can you help ? i have all information in this disk.
sorry my english
  • 2 more comments
  • diluquepil Jan 24, 2009
    perdon patea? no entiendo esa palabra encenderla?
    la computadora no detecta nada del HDD no se que le ha pasado
  • Roberta Smith
    Roberta Smith May 11, 2010
    usted necesita continuar contestándome en inglés pero i' intento del ll a contestarle en gracias españolas
  • Roberta Smith
    ¿cuándo usted patea la computadora… él demuestra las impulsiones del hdd?
Brohter you should chek you r hardisk and then check ram GOD WILLING YOUR PROBLEM WILL BE RIGHT IM RIAZ AHMED BROHI FROM PAKISTAN PLEASE EMAIL riazbrohi@gmail.com
Posted on Jan 30, 2009
Does the mother board Asrock 845GV (P4I45GV) support pci sata card
If you are trying to install Windows XP then -
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP.The FIX.Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.http://www.fixya.com/support/r4335035-installing_windows_xp_sata_hard_drive
Nov 19, 2011 | Asrock 845GV (P4I45GV) Motherboard
Any sata hdd can't dected by the mother board but any sata dvd dected by the mother board. what kind of procedure i followed now?
Your motherboard CAN detect a SATA device.
Your motherboard DOES detect your SATA optical device.
Your motherboard does NOT detect your SATA disk-drive.
This suggests that your disk-drive is "dead".
Exercise the WARRANTY on it, to get it repaired/replaced.
Or, if the warranty has EXPIRED, purchase a new SATA disk-drive.
Feb 03, 2011 | Seagate Barracuda 7200.7 ST380011A 80 GB...
Hdd detecetion proublem on 845 motherboard
845 chipset dont support sata devices and this is common problem that if unsupported device is forcefully bieng tried to work its goona happen sata support started from865 chipset u are lucky that ur hdd is getting detecting
Jun 11, 2010 | Computers & Internet
500 Gb sata hdd not detected on k8mm-v motherboard
Find in your BIOS if you have an option that says configure SATA as IDE, AHCI and raid. Set it at IDE and try again to install the OS. After intaling do not switch back because it will not work.
Apr 06, 2010 | Computers & Internet
MSI RC410 - cannot detect Sata HDD
i think the problem is with ur SATA HDD. To confirm, try another SATA HDD on ur mother board and see if the problem persists
Sep 20, 2009 | ASUS P5RD1-VM Motherboard
Mother board cant detect my Sata HDD, please advise me urgenly...
I will advice you to exchange the HDD with someone or with brand new one as it seems to be problem with drivers of the sata.
Sep 20, 2009 | MSI RC410M-L Motherboard
I have intel DG31PR mother board and samsung SATA HDD and i installed windowsXP. Actually it was working fine for the last two months. But now the BIOS does not detect the HDD.
If the HDD isn't detected, this means either the HDD has failed or the disk controller has failed.
Most likely the HDD has failed, remove the drive and test it in another computer as a slave drive, if the other computer can see the drive and the files then the drive is OK and the fault is the motherboard/controller.
Alternately you can also test the HDD with a USB hard drive adapter and connect it to a working computer's USB port, if the computer sees it as an external drive and the files then the HDD is OK.
May 02, 2009 | Computers & Internet
HI i m posting the same problem onceagain with the trouble shooti
You could try flashing to the latest bios and disabling SATA RAID, disabling IDEs including bus master if u dont use any.
Apr 19, 2009 | MSI Mother Board (MSM865PEN2V) Motherboard
Add sata HDD
Make sure the power cable of SATA hard drive is properly plugged in or not.. It is possible.. Try with SATA 0..
Thank you........
Aug 30, 2008 | EliteGroup (ECS 915PL-A2) Motherboard
Detection & installation problem
in bios ide configration selecl ATA select both ur sata HDD will be detected
Nov 28, 2007 | Intel Motherboard
MSI K8MM-V Motherboard Logo
245 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
