Question about Frigidaire FRS23KR4AQ Side by Side Refrigerator
Water leaking behind freezer wall
As my ice maker fills, water is spraying down behind the rear panel of the freezer. Ice is forming around the blower fan, ceating a loud noise and stopping the fan until I take the rear panel off and chop the ice away. I don't know why the water is spraying down there (the spout does not appear to be cracked) and I wonder if the defrost should be melting this ice buildup in the first place. I disconnected the water line and plastic spout and could not find the reason for the water going behind the panel.
    Novelist:
  • 159 Answers
I would make sure the fill tube in the freezer is in the proper place on the icemaker. there is usually a slot it will rest in or on. If it is it the right place. The water valve may not be closing in time and allowing excess water to fill into the icemaker causing it to over flow. On some icemakers there is a adjustment screw on the icemaker to increase or decrease the amount of water that fills. If not I would check the valve and replace it if nessacary.
Posted on Jul 19, 2007
SOURCE:
Fill tube to ice maker is loose water coming in bottom of freezer
Are you sure water is coming from the ice maker fill tube? What is your model number? Water that usally fills the base of freezer is most times caused by a blocked defrost drain opening behind the rear panel inside your freezer. There are ice maker fill tubes that leak but this only requires replacing the dual water control valve that fits your model. Here is more about leaking refrigerators=> HERE I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down ther rear wall of freezers on side by sides. Here is an example Click here=> Whirlpool Leak Photo taken by TechnicianBrian He has been around a good bit and deserves credit for his contributions. Here is another way to make this look more si mple in clip below. TechnicianBrian.com And in this photo are several parts listed in photo group #1 were it is most likely running down the wall=> MagicChef CTB1921AR fresh food section. If you still have questions please ask and rate me if I was able to explain this well enough. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! This is a common tip so I will be placing this post and add as we go new ideas listed in Sea Breeze Tips Section. If you run into any problems along the way of repair please let me know, Thanks, Sea Breeze
Nov 20, 2012 | Refrigerators
Ice maker leaking into ice storage tray
start with hose replcement buy parts at sears water hose to main ice maker might have crack in it or the stopper is bad get in ther look close with brite light
Oct 14, 2008 | Refrigerators
Maytag msd2651, icemaker stopsmaking ice & after a few days icesicles are forming and there are frozen puddles throughout the freezer. What is wrong?
Sounds to me your model MSD2651HEB has two problems. If you see icicle forming near where the water enters the ice maker the problem is the water control valve is defective and allowing water to enter the ice maker even after the ice maker is already filled with the next ice harvest. To repair the ice maker overfill problem you will need to replace the=> 67006531 Dual Water Control Valve
10_16_2012_7_51_14_pm.jpg67006531 Dual Water Contriol Valve
. I am pretty sure you are having a defrost drain blockage problem. Most defrost every eight hours and over a period of time the drain line that comes down from freezer into a cup like object top middle and back of the fresh food section. If blocked by gunk or ice you will see trails of liquid leaking down the rear wall of fresh food compartment until it reaches the crisper drawers.This is not always the same with every model as you may see frozen ice flowing down the rear wall of freezers on side by sides. Every refrigerator is made different so these are examples only. The key is to find if ice or just gunk has blocked you defrost drain. Unplug and then remove the rear panel in back of freezer. We need to see if the water is overflowing the condensate drain tray or if the blockage is in the turn the drain leads down back of your refrigerator. Much more on this page=> Leaking Refrigerators! If you have questions please ask, Thanks, Sea Breeze
Owner's Manuals (1)
MSD2651HEB.pdf (4536.63 KB)
You will need Adobe Acrobat Reader
to view these documents. The Adobe Acrobat
Reader is available as a free
download.
Get Adobe Acrobat Reader
For other models Click HERE
Oct 16, 2012 | Maytag MSD2651 HE Side by Side...
JSI-26 icemaker leaking water
You're ice maker is located on the left hand side of the freezer, if I'm correct.
Look to the back of the freezer slightly above the ice maker and you will see what they call the fill tube. Chances are ice has formed inside and when the ice maker goes to fill water sprays instead of flows out. In some models you can take the fill tube out from the back by removing two screws that hold it in, located at the upper right side if your behind it, and some you may have to pull out from inside.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
May 07, 2012 | Kenmore 21.9 cu. ft. Side-By-Side...
Water leaking. Mongram zic[s]360 (frig on top, pullout freezer on bottom with ice maker. no water dispenser). Leaks with water supply cut off to icemaker. Ice forms on bottom. Several years old but we...
Have the fridge pulled out and check behind it. I had same model and it was leaking into my walls/floor and caused thousands of dollars in damage to my kitchen. BLACK MOLS Covered my walls/cabinets and made me sick. Please be very careful with this excess water coming from this model. GE should recall it but will not unless forced. Not Cool.
Jan 16, 2010 | GE Monogram ZICS360NR Bottom Freezer...
Leaking water in icemaker. water from icemaker leaks into freezer and freezes on freezer wall
If you are sure that it's coming from the ice maker I believe that you possibly have a leaking water control valve on the side for the ice maker on the rear of refrigerator near floor there is a dual water valve control. Many times when this happens the water will freeze in the fill tube that fills the ice maker in the rear of freezer. You can defrost the frozen water in the fill tube with a hair dryer but that will not stop the problem from coming back. When that happens water tends to at times go everywhere but the ice maker. You can test the water control valve several ways. By unplugging the side to the ice maker and if water continues to flow slowly to the ice maker then the dual water control valve will need replaced, Sea Breeze
Sep 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice build up on bottom of freezer. Water leaks out of freezer possibly from melting. Water leaks onto floor of kitchen.
Your problem is possibly one of two things. The ice maker is leaking or the defrost tray behind the rear panel inside freezer back wall is clogged with ice or something else. If you know its not the ice maker unplug the refrigerator and remove the back panel to see if the drain is blocked there, Let me know, Sea Breeze
May 19, 2009 | GE Profile Stainless Bottom-Freezer...
Ice maker water leaking
Is the fill tube in the cup? also is the ice maker the correct ice maker for the unit.
Mar 25, 2009 | Frigidaire FRS3R5EMB Side by Side...
Water is leaking from the ice maker. It is
Are you sure the ice maker is leaking? MOst often it is a blocked drain. The problem you are experiencing is normally a blocked evaporator drain line. Whether you have a side by side model or a top mount freezer the solution is relatively the same. Most top mount freezer models have a rear evaporator panel covering the aluminum evaporator coils. There are some instances where the evaporator coils are on the floor. These instructions are for top mount freezers where the rear freezer panel covers the evaporator coils. First of all, if there is an ice maker in your unit, this will have to be removed. Normally there are two screws which can be loosened and the body of the ice maker can be lifted off the screws leaving only a plug in harness to disconnect. Remove the harness either from the plug at the left wall or rear of the freezer and set it to the side. Next, remove all the screws securing the rear panel. Remove the rear panel exposing the aluminum evaporator coils. Be careful not to damage these coils as they contain the freon that cools your refrigerator. If you look closely underneath these coils, there will be ice from frozen defrosted water. Using a hair dryer and not a heat gun, melt all the ice and sop up the water with a towel. Now you will see a drain hole which is normally still blocked with ice. Pour hot water in this hole and sop it up. Keep doing this until you pour water down the hole and it drains into the evaporator drain pan either under or behind your refrigerator. Once you have unblocked this drain line, reassemble and plug the refrigerator back in. Set all controls to the middle settings and within 24 hours, your unit will be functioning correctly once again. If you need further assistance, we are here. Eric Campion
Mar 20, 2009 | Roper RT21AKXKQ Top Freezer Refrigerator
ICE MAKER FREEEZES
my suggestion is unplug frige. for a couple of days! yes you will have to vacate everything. let all ice melt.. have mops and buckets ready for a poss. flood due to so much ice buildup. see if you can disconnect any hoses after thaw and blow in them. make sure fridge is disconnected!. look for any cracked plastic since these can become brittle in time and use 100 percent silicone to seal.
hope for the best!
Mar 18, 2009 | Whirlpool 21.8 cu. ft. Side-By-Side...
Frigidaire FRS23KR4AQ Side by Side Refrigerator Logo
179 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
Thomas F. Schneider
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
