Question about HP OmniBook 6100 Notebook
Right click left click buttons not working
I have the HP omnibook 6100. Yesterday the touchpad arrow control was erratic and would jump from place to place. I rebooted and now the arrow is fine but the right/left click buttons do not work what might be the problem and how to fix it. Thanx
Cursor jumps around
Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Click on the Start menu and open the Control Panel. Choose an "Icon View" option from the "View by" dropdown menu, then click the "Mouse" icon. Navigate to the "Device Settings" tab and click on the Synaptics device in the list. If you have installed and use custom software other than a Synaptics application for controlling the touchpad, select it instead. Click the "Settings" button. Click the "+" symbol to expand the "Pointing" section in the left frame, and then the "Sensitivity" section. Click on "PalmCheck." If you have replaced the Synaptics drivers, the menu may use a different set of options. Click and drag the bar to the right, closer to the "Maximum" setting. An increased PalmCheck setting will help decrease cursor jumping due to accidental palm activations, a common occurrence when typing. Click on "Touch Sensitivity." Click and drag the bar to the right, closer to the "Heavy Touch" end. This will ensure light brushes by fingers or accidental activations by other objects will not cause the cursor to jump. Click "Apply" to test the settings, and "OK" when satisfied to save the changes and close the window.
Jan 28, 2013 | Dell Inspiron dncwix12 Notebook
Cursor jumps into a previously-typed word or line and emails won't open
which email account ??
Acer laptop computers come with built-in touchpads to control cursor movement onscreen. Depending on the sensitivity and settings of the touchpad, it may register undesired motions as mouse controls, causing the cursor to jump erratically. The software drivers that Acer includes with its systems have sensitivity options that help alleviate this problem and ensure that only deliberate touchpad motions and taps cause the cursor to move.
Try right clicking on email select open
Jan 28, 2013 | Acer Aspire One PC Notebook
What is the CMOS battery model of HP Omnibook 6100? Is it CR2032?
The battery is a Lion rechargeable LM 1220 A CR1220 won't work correctly.
Hope that helps.
Jan 26, 2011 | HP OmniBook 6100 Notebook
I upgraded my hp omnibook 6100 from xp to windows vista. now it tells me that there is no audio device installed. is there a driver i can download for my laptop that is compatible with windows vista?
I had the same problem with my HP when l put vista on it and overcame that problem with using my XP driver. It worked for me no harm in trying your XP driver.
Nov 24, 2009 | HP OmniBook 6100 Notebook
What type of hdd does a HP omnibook 6100 F3260KT support and can it hold more than 30 gig standard factory as current HDD heads are locking up
The type of hard drive you want is a 2.5 inch IDE (ATA) hard drive.
As for the HDD capacity I've worked on an Omnibook 6100 which had a 100GB hard drive so i expect it can possibly take up to 320GB but don't quote me on that.
Regards.
Nov 13, 2009 | HP OmniBook 6100 Notebook
HP Omnibook 6100 doesn't boot
get in to bios by pressing F10 generally in all hp laptop that the way yo enter bios and then press F9 to reset default and then press F10 to save and exit and it will restart the system and chk
Aug 17, 2009 | HP Computers & Internet
Need hash code converted for hp 6100
Maybe you can google the HP 6100 battery hash code in Google.
Just click here : http://www.google.co.uk/search?hl=en&newwindow=1&q=HP+6100+hash+code&btnG=Search&meta=
Hope you can get the answer. Good luck.
Aug 17, 2009 | HP OmniBook XE3 Notebook
I've had the acer one for 2 weeks. While using it today, the single and double click functions of the touchpad stopped working. The touchpad still moves the arrow around the screen and the left and right...
Hello cskpuels,
It sounds like the touchpad is working ok but probably needs some setting(s) adjusted. The touchpad settings can be accessed through the windows control panel. But before going to the control panel it's useful to review the touchpad basics for single and double clicking. They are as follows:
•Tap once on the main touchpad for single click.
•Tap twice for double click.
•The lighter the touch, the better the response.
•Tapping harder will not increase the touchpad's responsiveness.
•Opening the Control Panel
The Windows Control Panel can be opened by:
Selecting *Start > Control Panel (on Windows Vista)
- OR -
Start > Run > Type 'Control' and select OK (on Windows XP)
*The Enter key may be used on the keyboard in place of touchpad clicking*
In the Control Panel, do the following:
•Select Mouse [Enter] (Brings up the touchpad properties sheet)
•Look at the Buttons tab in the touchpad properties sheet.
•Adjust the settings and test the touchpad until you get the response you desire.
If this solution is helpful please click 'YES' by 'Was this helpful?' below.
Have a great day,
martyshaw152
Aug 01, 2009 | Acer Aspire One Netbook 8.9" Notebook
How do I change the bios battery. I have Hp omnibook 6100. I have looked the manual, but I could nod solve the problem. Thank you
You have to open the back cover..there u can find a CMOS battery on the motherboard(Round shaped battery).
Mar 04, 2009 | HP OmniBook 6100 Notebook
Open Questions:
See all HP OmniBook 6100 Notebook Questions
HP OmniBook 6100 Notebook Logo
123 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
