Question about Canon C3380i Color Copier
Canon irc3580i service mode code
Hi, i need to realign my yello drum in the service mode but i dont know how can you advise.
3 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: CANON IR6000 COPIER
Is this a new problem??? Did you replace a major PCB? You may have to reinstall the door spec's back in from the pannel on the front door. Also, is the display sceen cracked? If so you need to replace the display screen... There is not a recaibation screen that I know of....
Posted on Sep 21, 2008
Elbastardo
  • 21 Answers
SOURCE: I get problem in my
1. Check to see if the ATR shutter comes off; if so, re-fit it.
2. Wipe the ATR sensor window with a damp cotton cloth.
3. If the symptom still occurs, replace the ATR sensor with a new one. 0012 is for the cyan drum
Posted on Sep 14, 2010
How can I check the drum life/consumption level of canon c-5185?
Hi, first you need to activate in the service mode the drum life notification
in the copier control panel:
press additional function
press 2 and 8 and the same time
service mode should appear in the screen if doesnt try again
select copier
select option
select body
select the item DLIFE-SW
press 1 in the control panel
press ok in the lower corner
press reset to finish service mode
turn the machine off from the main switch for a few seconds (5 seconds) and then on
once the machine is fully operating go to device status tab and you will see in there the level of toners and drums
May 04, 2016 | Canon Office Equipment & Supplies
Canon2202ir E0000-000 This error code deals with the fuser unit. It is saying that the fuser is not warming up. It needs to be reset in service mode.
How can I enter service mode on canon ir 2202? - Fixya
www.fixya.com/.../t25374950-any_one_help_me_enter_service_mode_...
Jan 19, 2015 - In standby mode, press the "Settings/Registration" key. 2. Press the "Reset" key. 3. Press the "Back" key. 4. Press the "Settings / Registration" ...
Error Code ir 2202n - CopyTechNet.com
www.copytechnet.com > ... > Copier Technical Discussion > Canon
Nov 22, 2014 - 3 posts - ‎2 authors
... pls help me ....i know how to enter service mode but ......pls help. ... Copier Technical Discussion · Canon. [Error Code] ir 2202n ... ir 2202n. how to print jam history in ir 2202.......i dont know pls help ... mm its a new machine , i need to know how to enter the service mode if u please ... Press the "Reset" key. Error Code canon image ronner 2202N
Aug 21, 2014
Canon IR 2200 error E000001-002
Jun 18, 2009
More results from www.copytechnet.com
Dec 21, 2015 | Office Equipment & Supplies
How do I get rid of black line on the printed copies on Canon IRC3580i when printing
If it happens when printing and copying then its either a drum, itb, cleaning blade or fuser issue. Sorry its not a one answer question.
Mar 02, 2015 | Canon Office Equipment & Supplies
Canonir3100cn error code E000020-0081
Dirty Drum patch sensor OR the drum has reached 100% of it's life.
iRC3100 drums NEVER go past 100%...once they reach that magic figure in the counters then it's time for a drum replacement.
If you know how to access service mode then check under:
COPIER>DENS>P-SENS-P and make sure that the figure is around the 500 mark...if it's below say,250 then that indicates that the drum patch sensor is having trouble reading correctly and may either need cleaning or a new drum unit.
If more help also see this link:
http://www.fixya.com/support/t575849-re_canon_ir3100cn_e000020_0081
Sep 25, 2013 | Canon imageRUNNER C3200 Copier
Irc3580i
A E000013-00 code is not a very good error code to have..... It has to do with the waste toner feed screw is "Backed up with toner" > most of the time you have to take the drum unit out & remove the drum & cleaning blade & chip out the toner in the tray under the drum blade. The other part of the problem is that the waste toner bottle is full and the feed tube in the back of the copier is packed up with toner and needs to be cleaned out. Also, there is a gear that may have cracked that drives the feed screw. This not a easy fix...
Good Luck
Sep 12, 2012 | Canon imageRUNNER 5000 Copier
Dear Sir, Our Scanner was showing to change magenda toner and we change with new one, but after end of the process it is showing the error code of E000020-81, even after shutdown 3 times. What else I can...
The error code your gettting E000020 is a drum code (imaging unit). You however do not have the complete digits after the E000020-????. Those digits define which drum needs to be replaced. You don't need to go into service mode to clear the error. You only need to buy the correct drum and put it in with the power off. Once it is replaced and the machine is turned on it will register and clear its internal error code. To help, here is what the ending codes mean. The xx's have further meaning but in most cases all roads lead to the same result (replace drum imaging unit).
-01xx yellow (Y)
-02xx magenta (M)
-03xx cyan (C)
-04xx black (K)
Jun 25, 2011 | Canon imageRUNNER C3200 Copier
Hi, i have this code error E000020 with my canon ir 2525 photocopier.i dont know what to do.please help me.thanks
1*Check the yellow drum unit, laser shutter or the plastic actuator on the right side of the front door. good luck.
2*Dirty Drum patch sensor OR the drum has reached 100% of it's life.
Mar 15, 2011 | Computers & Internet
I get problem in my printer CANON IRC3580i the erorr code is: E000020-0012, so any body can help me?
Sep 08, 2010 | Canon imageRUNNER C3200 Copier
CANON IR6000 COPIER
Sep 21, 2008 | Canon imageRUNNER 5000 Copier
Drum catridge codes
There is a drum counter clear that is service code 24-07.
Eventually your'e going to have to replace the drum. I can put you in touch with someone in the U.S. that can get you the parts you need.
To get into the service mode press #*C* on your copier keyboard.
Press 24 and the green key.
Press 7 and the green key.
Aug 18, 2008 | Sharp AL 1631 Copier
Canon C3380i Color Copier Logo
112 people viewed this question
old marine
old marine
