Question about Garden
3 point hitch capacities of 3910 ford tractor
3 point hitch lift capacite of 3910 ford tractoa
SOURCE: John Deere 1020 Weak 3 point hydraulics
I would suggest you find a JD dealer and buy a manual if you want to do the maintenance yourself. You can also do a Google search and find manuals.
I would also suggest you completely drain the old hydraulic fluid and replace it with new fluid and a new filter if it has not been serviced any time in the recent past.
The symptoms you describe can be low fluid and/or a clogged filter. If you or anyone else has run the tractor too long and it has low fluids and/or a clogged filter, you can damage the hydraulic pump and that can get costly.
Posted on May 01, 2009
RonPark
  • 855 Answers
SOURCE: Manual needed for JD 3 bottom plow w 3 point hitch
The first thing to do is get all the information you can off your plow. Like: serial number, model number and any info on any tags you find then go to the John Deere web site. Go to the plows section and you should find everything you need. They do have parts lists and manuals on the site. But it may be harder to find parts without at least a model. But they do have help areas you can try. Try there and if no luck try to give me all the info you can about what you are looking for and I'll do some research for you.
Posted on Sep 13, 2009
  • 78 Answers
SOURCE: how to install a 3 point hitch on a 140 farmall
I think a 140 is a IH Cub . I don't believe they had available a 3 point hitch. Please register at www.farmallcub.com and there are people there that have had a 140 apart and back together many times. IF there was a 3 point hitch available they will know about it.
GOOD LUCK
Mike
Posted on Oct 22, 2009
  • 8404 Answers
SOURCE: LIFT ARMS FOR 3 POINT HITCH WILL NOT MOVE
Standard tractors have a lever to the right of the driver, move toward the rear of the tractor to lower ... move toward the front to lift.
Posted on May 07, 2010
  • 251 Answers
SOURCE: ALLIS CHALMERS 190 GAS -HYDRAULICS ON TRACTOR ARE
hi , replace your hydraulic oil filter and pump and renew the oil .
hope this helps
Posted on Jun 21, 2010
How do I get to three point hitch to apply down pressure on the implementI
3 Point Equipment - Tractor Supply Company
www.tractorsupply.com/tsc/.../3-point-equipme...
Tractor Supply CompanyTSC has 3 point tractor disc, trechers, forks, attachments and implements for sale every day. ... modern farming as much as the adoption of the three-point hitch.3 Point Landscaping & Utility ... - ‎3 Point Cutters & Hay ...
Oct 01, 2015 | Toys
What is the part called that I need to order?
3 point hitch mounting bracket?
Apr 06, 2015 | Garden
I have a te20 tractor and the 3point hitch won't lift or go down . why ?
The hydraulic control valve for the hitch is not opening correctly, take it apart and clean it
Aug 31, 2014 | RTO Massey-Ferguson Tractor TE20, TO20,...
Three point hitch wont lower, kubota l2550
Mine did the same thing. Below the front of the seat is a knob sticking toward the front of the tractor that is angled upward that controls the fall rate of the three point hitch. After searching the internet for a while I found what this knob is for and went out and turned it until the three point fell down. The knob is perfectly placed to bump with my foot as I get off the tractor (I have large feet and bump a lot of controls getting on and off) and I guess I had bumped it closed over time.
Dave
Jun 22, 2012 | Garden
How to install a 3 point hitch on a 140 farmall did not come with a 3 point hitch
GOOD LUCK
Mike
Oct 16, 2009 | Garden
Three point hitch on 2020 Jogn Deere Tractor will not raise.
The three point hitch raises with hydraulic pressure. When the hitch will not raise the first thing to check is the hydraulic fluid level. If it is low add hydraulic fluid to the proper level as stated in the owner manual.
Jun 20, 2009 | John Deere 420,1020,2010,2020,2510,2520...
3 point hitch wont lower
Some of these tractors have a knob under the seat that locks the three point up so it cannot be lowered by accident. Check for this knob and open it.
Mar 27, 2009 | Garden
Garden Logo
42 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
