Question about Ingersoll Air Tools & Compressors
How can i set pressure for an ingersoll rand up6-7.5
virgils
  • 39 Answers
SOURCE: Air Compressor, low pressure
does the compressor keep running all the time but never gets above 40 or does it turn off at 40?
if it is turning off at 40 I would try using another gauge just to be sure it is 40psi, and if that is the case then you probably have a faulty pressure switch, if the compressor is constantly runnign but won't get past the 40psi then you may have a worn out compressor, check the oil for either a low level or if the oil is dirty, if it is you may just need to drain and refill but if that doesn't fix the issue then you will need to rebuild the compressor
Posted on Oct 11, 2008
  • 89 Answers
SOURCE: Cant set my compressor to automatic start/stop mode
U NEED TO ADJUST THE PRESSURE SWITCH ON THE BACKUP TO A LOWER PSI. TO COME ON AFTER THE PRIMARY. EXAMPLE: PRESSURE SWITCH ON PRIMARY COMP. SET AT 140-175 PSI AND BACKUP SET AT 135-170 PSI. U CAN USUALLY TURN ONE CENTER SCREW IN THE PRESSURE SWITCH COUNTERCLOCKWISE TO LOWER THE PSI.
Posted on Dec 27, 2008
  • 583 Answers
SOURCE: need to know how to adjust pressure regulator for low/high limits
sorry to be contradictory here, but better not to mislead or scare someone... Thepressure relief valve has absolutly nothing to do with cut in cut out pressure settings.the pressure relief valve is abrass fitting on the outside of the tank hexagonal fitting with a thin shaft coming out of the centre normaly with a ring on it not unlike akey ring .THAT is a blow off valve a safety device, that long before the air pressure is too great for the tank,will blow offthe air pressure in the tank ,try it, grab the ring and pull it out and it will dis charge any air in the tank ,that ios what it will do if thair is too great in the tank.. tanks are pressure tested and the appropriate valve fitted. NOW FOR YOUR ORIGINAL PROBLEM .you will find a control box ,useualy black or dark brown bakerlite cover,the electric cord goes into it ,also there will be another electric cord coming out and going to the electric motor that drives the compressor . If you take the cover off this you will find the cut in and cut out adjustments that allow you to set the cut in and cut out pressure as high or low as you want,that is whith in the capascity of the unit.It is self explanitory and there will be ( or should be ) instructions inside the cover .If you have any difficulty come back to me preferably with themotor and compressor sizes and i will walk you through it NOW AS MUCH AS THIS GOES AGAINST THE GRAIN, SHAG79 IT WOULD BE FAR BETTER IF YOU KNEW A BIT MORE ABOUT THE THINGS YOU ARE ADVISING THEM ABOUT EXPLOSIONS AND DEATH !!! WHAT ARE YOU-----A ******???
Posted on Aug 13, 2009
SOURCE: ingersoll Rand SSR compressor shuts down loaded or
When it shuts down, press DISPLAY SELECT button once and use the up down arrows to see the code just before shutdown.
HIGH AIREND TEMP
HIGH AIR PRESSURE
LOW SUMP PRESSURE
PRESSURE OR TEMP SENSOR FAIL
CHECK MOTOR ROTATION
MOTOR OVERLOAD
FAN MOTOR OVERLOAD
STARTER FAULT
I am assuming this has a Intellisys controller.
Posted on Sep 25, 2009
  • 41 Answers
SOURCE: I have a Ingersoll Rand Type-30, Mod#2475
when you remove the pressure switch cover,there is a screw on the top screw clockwise means increasing air pressure and anticlockwise means decreasing the drlivery air pressure
Posted on Sep 28, 2009
Testimonial: "Cool!!Thanks!I finally got a "page" on pressure switch. Its not in the regular owners manual. It was like pulling teeth,& had to get it from GRAINGER"
My ingersoll rand compressor is mixing pressure with oil.What could be the problem?
inline oil is set at a to higher rate , that is for lubricating air tools ....or worst case compression or oil rings are worn, if so service cylinder heads and replace rings
Oct 24, 2017 | Ingersoll Rand Air Tools & Compressors
I have Ingersoll rand ssr Hp40 SE compressor.. I can't set pressure above 95 psi if it have discharge pressure 143psi..what should I do for set this? If pressure touches 95 psi automatically vavle...
The tank, compressor head, and components need be rated at what you want set the compressor unit pressure to, the safety valve will keep from exceeding the lowest of those limits. If you suspect the safety relief valve needs replacing because it has weakened, then replace the safety valve with one OEM pressure values
Aug 09, 2017 | Ingersoll Rand Air Tools & Compressors
WHY DOES A SM75 INGERSOLL RAND COMPRESSOR CUT OUT ON LOW PRESSURE OIL
Low oil pressure. Are you adding a lot of oil. Have you check the oil level. Switch could also be bad.
Dec 08, 2014 | Ingersoll Rand Air Tools & Compressors
I have an Ingersoll Rand 2340L5 and need to know how to have it come on when it gets down to 120 instead of 100
Change the settings on the pressure switch. Brad Brown has a good description of the pressure switch
Nov 22, 2011 | Ingersoll Rand - Rand Type - 30...
Chuck on ingersoll rand air drill doesn't turn even without air pressure
pull it apart and check bearings and fibre blades check that they are not cracked or jammed from dried lubricant.
Oct 02, 2011 | Ingersoll Rand Ingersoll-Rand 1/2" Heavy...
Sep 11, 2009 | Ingersoll Rand - Rand Type - 30...
Air Tools & Compressors Logo
51 people viewed this question
Top Ingersoll Air Tools & Compressors Experts
elunsford
John Trevino
Are you an Ingersoll Air Tool and Compressor Expert? Answer questions, earn points and help others
