Sony STR-K1500 control centre. Hi I have always had this control centre but only recently upgraded to a TV with HDMI. So I have a DSTv decoder and a BluRay player. I conected the Bluray HDMI to the back of the Control Centre at DVD in. And the DSTv to the HDMI video 2 in. They are written 'Assignable'. Then I took the HDMI out to my tv. Nothing happens. On the remote I go into the 'Amp Menu' option 6-VIDEO. There is a HDMI A option. I enter that also but can't seem to get anywhere. Please help. Thanx. Heinrich
SOURCE: Remote control code for Sony BDP S350 Bluray player.
Try code 32907
Posted on Feb 22, 2009
SOURCE: NEED CODES TO USE WITH ONE FOR ALL UNIV. REMOTE URC3300
Try holding down the tv power button and keep holding it while you press the channel button until your tv comes in.. It takes a few pushes. Make sure your tv is off first though.
Posted on May 30, 2009
  • 3 Answers
SOURCE: how to reset the default value for the toshiba sd 6100 dvd player
If you want HDMI 'Auto' mode (the factory default), you need a combination of selecting the proper output mode (use the remote's 'Progressive' button to toggle between the four output modes: HDMI, RCA VGA, component video out and s-video. Once you're in HDMI mode (the led's on the front of the box are a dead give-away!), then you can press the front panel 'HDMI Select' button to move through the five available HDMI settings: 480P, 720P, 1080i, 1080P and 'Auto'. You're in 'Auto' mode when all four led's are lit.
Posted on Jul 18, 2009
pabloloco
  • 2335 Answers
SOURCE: bdp s350 sony bluray player.
I would just like to add that I have a Sony BDP-S500 player and a Sony TV.
The Sony TV's remote was preprogrammed to control the Bluray player, which i discovered by accident, so I didn't have to mess with universal remote control codes or anything.
Hope that helps.
Posted on Oct 09, 2009
  • 57 Answers
SOURCE: My new BluRay player has HDMI output for both
Yes, you can connect the HDMI Cable from the Blu-ray Player to the TV directly and then, connect the Digital Optical cable from the Blu-ray Player to the Receiver.
Posted on Feb 24, 2010
Sony wega kds r60 sxr1
Hi is it connect to a dstv decoder, if so try unplugin the decoder from the tv and see if the lines are still there, if not it could be the decoder thats causing it.
Feb 18, 2014 | Televison & Video
I have a Sony STR-K750 receiver running with a Samsung 50 inch series 6 tv.There is a digital lead running from the Austar receiver to the Sony receiver for sound.I have a Hdmi lead running from the Austar...
Run both audio and video to the tv, then use the tv optical audio out to go back to the receiver. The problem is, when you split the signal, the tv takes longer to decode the hdmi signal =, thus delaying it from the original audio signal.
Aug 06, 2013 | Sony STR-K750P A/V Receiver
Multi channel decoding blue light not working yet?
Multi Channel Decoding will only work when you have it briamp.Meaning to have a sepperate power amp hooked up to it for your fronts,Rears end Centre, Speakers, Witch sony is to stupid to tell you that in there owners (Manaul)
Oct 21, 2012 | Sony STR-DE545 Receiver
I want to couple my DSTV Decoder through my new THT-3017HDMI Home Theatre System to the TV. How do I do that? I am very much technology disatvantaged.
THT-3017HDMI to hook with TV.
Get RCA Cables, red and white from your DSTV straight to your DVD.
The Yellow (Video) Straight from your DSTV to your TV yellow input.
Set your TV to Input 1 or 2 depending on the port you used. PLease but your volume will be only controlled via DVD, if you switch your TV off it will still sound the TV channels via DVD speakers,
Sep 03, 2010 | Televison & Video
I have a Sony STR-DA5200ES amplifier hooked into a sound system and a 52" Samsung LCD TV. The system is set up to operate on HDMI. The problem that has started recently is that the amplifier polls between...
hello,
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Is the cable connection hdmi? is the unit capable of upconversion to hdmi, if you use a component connection? probably not. if it is capable of upconversion, check your input menu settings.
or
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} The HDMI on the Sony STR-DA5200ES does not pass the audio. You need to either connect an optical or digital cable from your audio source. If it is a cable box or DVD player there should be audio outputs in addition to HDM.
Hope this will help...
May 25, 2010 | Sony STR-DA5200ES Receiver
Sony STR-DG510 hook up with BDP-S560 no sound
The Sony manual for this receiver is not wrong, it is just a little misleading.
It does in fact use HDMI but ONLY for the HIGH DEFINITION video portion of the signal, as output from the receiver to your television. High Definition Multimedia interface carries both audio and video, however, your receiver is not decoding the high definition AUDIO portion of it and passing it through the HDMI, nor is it passing any form of multichannel audio through HDMI. So you can see why the receiver is no longer available for sale from the Sony website. The HDMI connection on your receiver is redundant unless you are not using a multichannel audio format, in which case you would be using either the TV speakers or connect an additional audio cable from the TV's "audio out" back into the receiver for external speakers.
All that should be done is use the HDMI cable from your blu-ray player connected directly to your TV. That will give you your picture, and possibly a better one since the receiver will no longer be in the signal path.
Then connect either a coaxial or optical cable from the blu ray player to the receiver for your audio. You will then be able to have Dolby Digital and DTS surround formats.
Your service person was wrong.
Jan 17, 2010 | Sony STR-DG510 Receiver
Need to connect my DSTV decoder through my sony amplifier (5.1) not sure of a the cabling or the connections, does someone perhaps ahve a wiring diagram to connect TV, dstv decoder and sony 5.1 amplifier?...
well this is easier than you think, get yourself a set of RCA's (the red and white and yellow cables that DVD players come with) look behind your decoder and place them colour to colour, then behind your Amp you will read (TV IN) do the same, then with just one yellow RCA plug it into (monitor) that one will then go to the (AV input) behind your TV.. And presto!!! now set your amp input on the remote to TV and your off!! good luck
Jun 29, 2009 | Fujitsu Siemens PlasmaVision P42VHA40...
Black and white dstv
look on the TV menu for (system) in south africa we use PAL, if you cant change it on the TV, with the decoder remote press menu then 7 then 4, it will ask for a pin code press 9-9-4-9 it will read "RF modulator" press OK, it will then read 1 MODULATION press ok again and it will highlight PAL I now press the right key and press OK, if this persists then the decoder it probably faulty... good luck
May 28, 2009 | Sony KP-EF61 61" Rear Projection...
Can't get Playstation3 sound through the STR-DG800 using HMDI.
Do you have your ps3 connected to the TV with HDMI and then audo cables from the TV to the receiver? If so, you need to make sure you change the audio settings on your TV to surround sound.
May 12, 2009 | Sony STR-DG800 Receiver
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
