Question about Kenmore 35912 / 35913 Progressive Upright Vacuum
Buzzing sound sound comes from small port behind the suction hose, it's spring loaded, when vacuum is turned on it buzzes
    Problem Solver:
  • 6 Answers
You ether have an air restriction, or your bypass valve is broken. If it is an air restriction: The motor requires more air flow to stay cool, the noise you hear is an emergency air inlet made to prevent overheating. You may need to use the hepa bag to help increase the air flow. Some hose attachments will cause this to happen, your performance indicator light (if you have one) should also be illuminated if it is an air flow issue. Check your hose for a blockage.
Posted on Mar 07, 2009
I accidentally vacuumed up a small plastic bag. Now I have no suction. No plastic bag is visible in the canister or the hose. What do I do?
Take my word for it, the plastic bag and / or its' remains is / are somewhere in the hose. Visibility of clear plastic in the dark environs of the interior of the hose is extremely limited if possible at all. Some hoses are corrugated on the inside especially if so on the outside. Without specificity as to brand my best first shot would be to attach the hose to the vacuum cleaners exhaust and try to blow the plastic back out the hose. The exhaust is the port from which the air comes out when everything's working as it should. Even before that, disconnect the hose from the canister, turn on the machine and see if there's any suction at the port where the hose attaches. No suction at the port eliminates the hose as the problem. If your machine will run without a bag, take the bag out and momentarily turn the machine on. Suction with no bag = bad bag. Still no suction= a trip to the vacuum service / sales store
Nov 02, 2017 | Vacuums
My Kenmore bagless intelliclean vacuum is making a loud noise mainly when it is vacuuming on the highest setting (when the light is red). We have taken it apart and cannot find a clog. It has also lost...
This might help, it was posted on a previous problem but is the same issue you are having it seems: "Here is a possible solution. If the vacuum sounds normal when the green light comes on, then the issue is a suction bypass. Kenmore built a suction bypass in to help cool down and protect the motor should someone either never clean the filter, empty the canister or somehow manage to clog the hose. There is a spring holding the bypass closed and is overridden by vacuum suction. I guess the spring becomes weak, allowing high suction to pull it open which in turn reduces suction so it closes again. It can do this several times per second making a loud racket and slightly affecting performance until the sensor goes green, then the vacuum suction is too low to overcome the spring tension thus why it sounds fine then. The trick? The very hard way (what I did) was to open the vacuum, open the casing where the spring is and pull it apart slightly to increase the spring tension. The easy way is to put tape over the hole where the bypass is. The inlet is under the hose track on the back on the right side as you're looking at it. The hole is about the size of a quarter and you'll see fins across the hole. The tape would keep the suction. The motor would still pull back the bypass but since tape is applied, there would be nothing to reduce the suction thus keeping performance and reducing the noise. However, this circumvents the intended design so you do so only at your own risk."
Dec 27, 2010 | Kenmore Progressive Bagless Upright with...
Loss of suction on hand tools (DC07)
It sounds like there's probably a clog in the hose. Drop a small coin or marble down the hose and see if it falls through. There's going to be a loss of suction in the power nozzle too, just not as noticeable when vacuuming carpet.
There could also be a clog behind the filter where the hose plugs into tank, or a dirty filter.
Nov 22, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
Apr 06, 2010 | Hoover U6311-930 Power Drive Bagged...
I have unscrewed all the screws and can't get bottom off.
Mar 10, 2010 | Kenmore Progressive Bagless Upright with...
Eureka rm 4480
Hi there SmartAlec from NelsonVacuums.com.au . Unless there is a bad sound coming from your vacuum i would suggest you have a blockage. This machine is prone to getting blockages in 3 different places.
  1. at the base behind the brush.
  2. Inside the main suction hose - this should be removeable so you can drop a small coin through. If it doesnt fall easily viola blockage found.
  3. Where the dirt enteras the chamber or bag.
Basically start by removing all hoses and filters and turn machine on put your hand over all inlet and exit points provided you can feel airflow at one of these points work backwards from there and identify the point at which you no longer feel airflow.
HAPPY vacuuming !
Aug 26, 2009 | Eureka Whirlwind 4480 Upright Vacuum
Loud noise from Kenmore Progressive Bagless Inteli-Clean
Jul 04, 2009 | Kenmore Progressive Bagless Upright with...
Kenmore Progressive Direct Drive Upright - noise and bad suction
Had the same problem tonight. Took the entire thing apart only to find there was a much simpler solution. Check the small hose that runs from the brush rollers where the longer hose (on the back) attaches to the side of the vacuum. Easiest way to do this is to lay the handle down and stick something (coat hanger worked good) through it until it comes out of the head. I found a pretty good sized fuzz plug in mine. As soon as I removed it, everything worked great again - and no noise!
Mar 15, 2008 | Kenmore 31912 Progressive Direct Drive...
Loss of Suction
Thank you for this solution, it saved me $$$ and a trip to the repair shop.
Feb 23, 2008 | Kenmore Progressive Bagless Upright with...
No suction in vacuum on a Panasonic MC-V7355
the device is a bypass which allows some air flow when there is a blockage. you have a blockage somewhere i suspect hence no suction. check all hoses carefully. take off the base and check the air duct away from the brush roll
May 02, 2007 | Panasonic MC-V7355 Upright Vacuum
Kenmore 35912 / 35913 Progressive Upright Vacuum Logo
168 people viewed this question
Top Kenmore Vacuums Experts
Chris Nomland
Chris Nomland
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
