Question about Panasonic 1100w over Range Microwave Ovens Black NN SD277BR Appliances
Microwave displays H97--Over the Range Model: NN-SD277
Displays H97
MicrowaveSvc
  • 9098 Answers
SOURCE: panasonic microwave oven
Microwave fuses are normally located either on a filter board near where the power cord comes in, behind the control panel between the door switches, or behind the control panel in a hodler, sometimes on the floor of the chassis.
If you or someone you know decide to look into it, we have critical safety information, info on door switch diagnosis and replacement, and disassembly information at our site, and our link is at our listing here on FixYa.
At our site, we have a video showing how to remove a typical over the range control panel assembly in under 5 minutes.
You can find an authorized Panasonic servicer here.
You can order Panasonic parts from Tritronics, but if you don't find what you're looking for there, try here.
Posted on Nov 07, 2008
SOURCE: Panasonic NN-H264 1200...stops after 3 seconds
I found sufficient information elsewhere.
Posted on Feb 13, 2009
EwingElect
  • 276 Answers
SOURCE: our microwave oven Panasonic NN-S252WF stops after
Our technician suggest that there may be a problem with the Inverter Board in this model, which is something that would need to be looked at by a Service Center.
In rare cases it could be the door switches.
Posted on Mar 27, 2009
fathitkf
  • 1871 Answers
SOURCE: error code h97, on a genius prestige microwave -
Hello :
Troubleshooting of Inverter Circuit (U) and Magnetron .
This oven is programmed with a self diagnostics failure code system which will help for troubleshooting, H97, H98 and H99 are the provided failure magnetron and inverter circuit problem areas. This section explains failure codes of H97, H98 and H99. H97, H98 and H99 appears in display window a short time after start key is pressed and there is no microwave oscillation.
WARNING :
The microwave is capable of giving you a serious electrical shock even when it's unplugged , so I recommend you to call a repair technician for help .
please don't forget to rate .
good luck .
Posted on Apr 13, 2010
SOURCE: My panasonic over the range microwave model
I have same problem. Disconnect the power. Take the 3 screws out of the top of vented front thus exposing 2 screws that hold down the touch pad .remove them and move touch pad out of the front and out of the way. on the extreme top right within the compartment there is a circuit board that has a fuse on it. replace the fuse and try to restart the microwave. if the fuse blows again you have a major problem probably the magnetron. If you need further help call me (403)870 9110.........Ron
Posted on Apr 30, 2010
Why isthe fan on my new panasonic Genius over the range microwave is noisy NN-SD277
Check to see if the vent is not jamming the motor. It could be something fell into the fan blabes. It could be a noiy motor and this would be a warranty issue.
Oct 11, 2014 | Panasonic "NN-SD277BR 2.0cuft, 1200 Watt...
Why my microwave NN GD371M will run for 4 seconds then shut off. display shows code h97?
There are a number of possible causes.
The following link will take you to a page with the diagnostic flow chart that you can use to troubleshoot this issue:
Microwave Fault Codes
This customers review of that issue may also be of some help:
Customer Reviews Panasonic NN T945SF 2 2 Cubic Foot 1250 Watt Microwave...
Jun 17, 2014 | Panasonic NN-T990SA Microwave Oven
Panasonic flatbed microwave NN-sf550W displays code H97
If you wish to get some details about microwave oven and its working ; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Jan 21, 2013 | Microwave Ovens
Oven door on PanasoniPanasonic microwave Model NN-SD277 won't open when pressing open button
I just had that problem. It is the plastic workings. One of the plastic posts that holds the pivoting lever had to be epoxied. That plastic rejects crazy glue, don't waste your time. Just epoxy and as much as you think can fit under the electronics and the metal plate you will have to pull out.
My suggestion is take pictures of every step so that you can hook all the electrics back up. There are some testy switches that must be unsnapped too.
www.ianklepsch.ca
Oct 08, 2012 | Panasonic Microwave Ovens
Model NN-ST659W works for about 30 seconds then displays H98 on the display panel how do I fix this problem
H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here. If you're not in the US, see Panasonic.net.
May 31, 2012 | Microwave Ovens
NN-SD297S The exhast fan still works but the oven
Due to the technology used in this model, there are no user serviceable parts inside. Call a Panasonic appliance engineer.
Mar 07, 2011 | Panasonic NNSD297SR 1200 Watts Microwave...
My Panasonic NN-ST657W microwave has suddenly come up with an H97 code on display panel. Switches off after about 6 seconds before displaying this code. What has happened?
There is not a lot the layman can do except maybe to try a new magnetron.
It is a job for an experienced Panasonic Microwave repair man.
Dec 31, 2010 | Panasonic Microwave Ovens
Error code h97, on a genius prestige microwave - nn-sd787st. what does this mean?
Hello :
WARNING :
good luck .
Apr 13, 2010 | Panasonic NN-SD797S Microwave Oven
Panasonic 1100w over Range Microwave Ovens Black NN SD277BR Appliances Logo
97 people viewed this question
Top Panasonic Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Panasonic Microwave Oven Expert? Answer questions, earn points and help others
