Question about Proscan 19LA25Q 19 in. LCD Television
Flashing yellow light
Hello i hooked a s-cable to my tv and now it does not turn on and there is a flashing yellow light were it used to be green
  • Anonymous Apr 06, 2009
    same
    New Friend:
  • 42 Answers
Http://oncorpus.com/Support/service.htm
You do not have to download the language pack!
Posted on Apr 02, 2009
Rear harness was bad they replaced with trailer harness and trying to fig out what yellow brown light green an dark green are on frame of truck it hooked in to so i can fix i un hooked not knowing what had...
Your description, I take it, is a problem with the wiring harness going from the driver's compartment to the rear lights. If that is the case, the normal color code for GM is brown for tail lights, dark green for the right stop & turn, yellow for the left stop & turn and light green for the backup lights. Any black wires should be grounded. The white wire in the trailer harness is for a ground when used on a trailer. It sounds like you have the green and yellow T&S wires shorted together somewhere! Some of the later vehicles use separate stop and turn bulbs... these would have a separate wire for the stop lights only, but I don't think your truck is new enough for that. Good luck!
Nov 25, 2013 | 1993 GMC Sierra
Hello my samsung hcn529wx/xaa is has a green picture,I switch my cable boxes and no help, when i disconnect cable box, i get a green blank screen instead of white,i went into the menu page and adjusted all...
If you have a DVD player you can do a test to see if you have a bad tuner in the TV. Using Red, White, and Yellow cables hook up your DVD player to the corresponding jacks on the back of the DVD player and INPUT on the back of the TV with corresponding jacks as well. Turn on the DVD and TV and go to the TV menu and find the input that you have the red, white, and yellow jacks hooked to and see if you get a picture from your DVD player. If you do get a picture you probably have a bad tuner in your TV (if you are sure your cable signal is good). This setup bypasses the tuner. Let me know how it goes. And if you haven't done so be sure you have the right input for your cable signal correct in the menu as well.
Dec 22, 2011 | Samsung HCN4226W 42" Rear Projection...
I just hooked up my Flat TV to my Panasonic VHS-DVD recorder player and the screen only shows blurry Black and White when displaying or recording, The TV itself is fine.
Sounds as if you hooked up your player wrong. If you are using a composite hook up. You should have a yellow, red and white cable. Make sure it gets hooked into the same on the TV. If it is a component connection, then RED, Green and Blue. It sounds like you have your Yellow composite going through your Green component. If by chance your TV is a new Sony, then you might have to go into the user menu and turn component off and composite on.
Apr 05, 2011 | Televison & Video
How to fix ps3 when light flashes green,yellow, then red
Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.hello
regards
shaun
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
Hello, i am trying to hook up my xbox 360 to my
Make sure the tv is set to A/V 1 if it has multiple A/V hookups make sure the tv is on and set to the A/V channel you are trying to use. And make sure your cable is set to tv if you have a composite cable. If that does not work try buying a composite cable (thats the yellow red red blue green white cable). If that does not work. There might be something wrong with the xbox or tv.
Jun 26, 2010 | Video Game Consoles & Games
Flashed red when you turn it on
The first thing that you need to thoroughly check is the cables. Most the times this problem arises because of the cables not being properly hooked up. Although this may sound very basic, yet it is something that most people tend to ignore.
Just in case the cables are properly hooked, the next thing that you need to check for is any damage in the cables. If you find that the cables are all right, then you need to check your TV’s resolution. These are some of things that you need to look for whenever you find your PS3 blinking red.
Aug 27, 2009 | Sony Playstation 3 (PS3) Console
Hook up of dvd to tv
hey I think you need to use component cables blue green red from the player to the tv, make sure the blue green red ports are also on the tv, note: red yellow white composite cable will not interchange with blue green red component cable or connection.
simplify- blue green red= component
red white yellow=composite
*wires must match colors on both tv and player inputs.
then set your input on your tv to where you conected the cable.
Jun 15, 2009 | Sony BRAVIA KDL-52W4100 52 in. LCD HDTV
TV channels
If cable is hooked through cable box with a coaxial cable, then turn tv to ch 3 or ch 4 as appropriate.
If cable is hooked through any other type of cord (red/green/blue or red/white/yellow) use the AV+ or Source button to change your source to Av1, AV2, HDMI, or however you have the cable box hooked to TV (I am assuming your TV is a Philips).
Feb 24, 2008 | Philips TV Tuner Video Capture PCI Card -...
TV won't turn on
sounds like the main board has an issue
Jan 18, 2007 | Samsung LTM1775W 17 in. LCD Television
Proscan 19LA25Q 19 in. LCD Television Logo
229 people viewed this question
Top Proscan Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you a Proscan Televison and Video Expert? Answer questions, earn points and help others
