Brother Multi-Function Center  MFC-240C All-In-One InkJet Printer Logo
Related Tags:
Problem with Brother Multi-Function Center MFC-240C All-In-One InkJet Printer
phone won't go into voicemail, only fax mode
before I moved into my new place people could leave messages on my voicemail. But now for some reason they can't. I have triple-play (phone,catv,internet) and although I called catv company they said it was a default in fax machine. Even with the fax machine off, my phone won't go into voicemail. What could be the problem?
Posted by avatar on Jan 24, 2009
    • By avatarthelionking1 Jan 28, 2009
    • o.k. I set printer to receive faxes only and I still have the same problem of no voicemail. My phone jack has 2 ports, one straight to my phone and the other to my fax. Are my wires crossed or does it matter?
    • By avatarthelionking1 Jan 30, 2009
    • I have time warner triple play. does my computer have to be reset to the fax for some reason? i"m still trying to figure this out. thanx
Solutions (1)
Your cable company is correct. Your printer is set to the phone/fax mode which allows the machine to be act as a phone or fax. It can tell the difference between an incoming voice call and an incoming fax. You should set your printer to Fax Only. Here's how:
  1. Push the menu button
  2. Press 0 (zero)
  3. Press 1 (one)
  4. The display should now show fax only.
  5. Press Ok.
To review what we did:
We set your printer to only recognize faxes when they are sent. Voice calls will now go through to your voice mail, if you do not answer.
If my assistance has been to your satisfaction, please rate my service. Thank you for using Fixya.com
    • By avatarBernie Thames Jan 30, 2009
    • Do you have a Vonnage phone with a separate phone line? The connection is is a little different with their phone system. I'd appreciate the opportunity to help further. Thanks!
  • i need to know how to set my fax for 3 rings, because my voicemail picks up on 4 rings
  • Hi I have a HP 3380 Printer which is working fine. My issue is it answers all incoming calls (both voice and fax). Is there a way to...
  • I cannot leave the phone jax connected to the printer. If I do the phone will ring only one time. When you try to answer it you get nothing....
  • I have a jewett set up on 4355 fax & phone when some person rings me it goes to the fax instead of the answering merchine can some one...
Add Your Solution
See all Brother Multi-Function Center MFC-240C All-In-One Problems
