Question about Star Micronics TSP100 Thermal Printer
My Star tsp100(143) cutter prints 2 copies instead of 1 even though the settings are set to 1 copies. Tried paper size letter, 72mm and 51mm, still prints 2 copies. Please advice. Thanks
OS: Windows XP Reinstalled driver but problem still exist.
  • brainchild Jan 18, 2013
    Thanks for the help everyone, It's been resolved.
  • 9 Answers
SOURCE: Star SP 2000 Printer
Make sure the dip switches are set identical on each printer. Use your old printer as the example They are located at the bottom of the printer near where the interface cable plugs into the printer.
Posted on Feb 23, 2009
  • 5189 Answers
SOURCE: My social club has bought
Try the driver from here: http://www.starmicronics.com/supports/starlegacydrivers.aspx#SP2000 . Extract the file from the zipped download (just right click and choose Extract All). Then either install with an exe file in the folder or use the Add a Printer Wizard and choose "I have the disc" and browse to the folder that the files were extracted into. The list that comes up otherwise lists printers that have drivers built into the OS. The SP2000 drivers are not part of WinXP.
The automatic installer (called SI.exe for some Star Micronics printers) will be easier since the SP2000 designates the printer class not the specific printer. (The automatic installer will list a model of SP2320, SP2360, SP2520, or SP2560 depending on the features of the printer.) Click OK at the Star Printer window. Then check the port that is being assigned to the printer then click OK again.
I hope this helps.
Posted on Dec 14, 2010
SOURCE: star tsp100 printer feeds extra paper
check that the paper type is set to receipt and not ticket in the printer properties: device settings.
Posted on Dec 22, 2010
SOURCE: my printer only prints to copies, want one Star
It could be a setting in the driver or in your point of sale software. If you want to check the driver, right click on the TSP100 in Printers and Faxes and click on properties, then printing preferences and advanced. In advanced, make sure the copy count is set to 1.
If you need help assistance with Star Micronics printers, you can contact their technical support at (800) 782-7636 or http://www.starmicronics.com/Supports/TechnicalSupport.aspx .
Posted on Feb 21, 2011
  • 15 Answers
SOURCE: We have a Star TSP800
Dear Star Customer
It sounds like you have a hardware issue. Please open the lid and take a photo of inside the printer and forward it to us at support@star-emea.com, it will help us find out what the problem it.
Best regards
Star Support.
Posted on Jul 18, 2011
Prints on partial page of an 81/2 x 11 photo paper. Prints OK letters fm word.
Instead of using the Letter or factory 8 1/2 x 11 page set up, create a custom page size for 8 1/2x11 and use that in your app for the page set up. Double check your page orientation and the size of the photo you are printing. It sounds like it may be trying to tile the photo because it's too large for the page size.
Sep 14, 2017 | HP Photosmart C6280 Printer
I use a CM2320nf MFP connected to Windows XP. The unit seems to be defaulted to print 2 pages - and for double sided copies, it stops after 2 pages, then the Cleaning window pops up, then I get an error...
Problem 1 :
As far as the machine printing 2 pages per job. To fix this it's usually the default number of copies the printer is set to. To change/ confirm the setting is set to one:
Press the menu button
Arrow down to -> Printing, Press the green check to enter the menu
Arrow down to -> Copies Press the green check to enter the menu
Change or confirm the value = 1, (Based on your question this might be set to 2) Press the green save the value.
* If your number of copies is set to 1 and the machine is still printing 2 copies, then the problem relays in your print driver.
Problem 2: General Misprint Error message something like 41.3
2 things to check:
1st - Press the menu button
Arrow down to Paper Handling, Press the green check to enter the menu
Now you will see options like Tray 1 size - Tray 1 type. Here their will be a option for each tray installed on your machine. You will go into each tray option and confirm the paper size and type.
Example
Tray 1 Size = Envelope #10 (This is the manual feed tray)
Tray 1 Type = Envelope
Tray 2 Size = Letter
Tray 2 Type = Plain
To perform arrow down to tray X size press the green check to access the menu, arrow up or down to select your paper size. Once the paper size is selected press the green check to save it. repeat for each tray.
2nd -
Pull out your tray and remove the paper, towards back of the tray you will see a guide (Tab) in the middle of the tray which allows you to expand the tray to accept various paper sizes, Please confirm the guide is set to the correct type. If your using letter, make sure the guide is set to letter (LTR) you can see these codes by looking at the base of the guide, their is a little arrow pointer.
Hope this helps
Jan 14, 2011 | HP LaserJet 2420 Printer
WHEN PRINTING - THE PRINTER SAYS TRAY 1 LOAD PLAIN PAPER, USE PLAIN EXEC INSTEAD? THE PRINTER IS LOADED WITH 8 1/2 X 11 LETTER SIZE PAPER.
You have the settinigs on the printer wrong. There are two things you need to do:
1. Open the tray and check that the paper guides are set to 8.5 x 11 (letter). There are both length and width guides in the paper tray, and EXEC size is quite a bit off from letter-it is more than 0.5 inch narrower than letter. It is also shorter than letter.
2. On the printer, use the settings button to navigate to the paper size. (The exact wording may vary; it's been a while since I worked on a 4050. It may be under print settings.) Once you find the paper size menu, configure tray 2-yes, I'm sure-to use letter size, any type. By the way, on HP lasers, tray 1 is the fold down tray on the front, tray 2 is the tray that will hold 500 sheets of paper and is the "drawer" that you load. Don't ask me why they use that numbering system.
Feb 11, 2010 | HP LaserJet 4050 Printer
IBM 1422 not feeding 8 1/2 x 11 paper through multipurpose feeder
Go into the paper menu and set the multipurpose feeder paper size to letter. It will work if the paper size is set correctly for the MPF.
Apr 30, 2009 | IBM Infoprint 1422 Laser Printer
Problem printing on matte photo paper
no thats why it is not working the right way you have to use the semi gloss paper thats what it requiers
Jan 03, 2009 | Brother MFC-3240C All-In-One InkJet...
Tray output
You should configure TRAY 1 as Legal only.
and Tray 2 as plain letter.
Specially when you specify from what tray/paper type to print.
This can be easily configured from the Printer Properties within the Printers and Faxes section of the Control Panel.
Jan 26, 2008 | HP Officejet Pro L7780 All-In-One InkJet...
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
3055 sends to manual feed
Hi there
I've had a similar problem in windows instead of the mac, but it sounds like it's a
similar problem where the computer's telling the printer to use a
different sized paper to what the printer's been told is in the trays. For example, if, say, your document is set up for A4 sized paper, but the printer is set up to think it has Letter sized paper in the trays, it'll ask to have A4 sized paper installed in the tray instead.
Go into the system setup on the printer and select the paper setup menu.
Select Tray 1 and choose the right paper type and size from the settings (After you choose the paper type you have to go all the way back through the menus on the printer and choose the paper size as well)
Hope this helps!
Nov 22, 2007 | HP LaserJet 3055 All-In-One Printer
Star Micronics TSP100 Thermal Printer Logo
Top Star Micronics Office Equipment & Supplies Experts
GoogleLaughs
sajidsarwar
Level 1 Expert
Are you a Star Micronics Office Equipment and Supply Expert? Answer questions, earn points and help others
