Question about Maytag 24 in. MDB4000 Built-in Dishwasher
Water leaking onto the floor
When I run my dishwasher the water goes onto the floor. Not down the drain - can you help with what is wrong - it is a maytag.
  • bob collins
    bob collins May 11, 2010
    Does this only happen during the drain process or continuously?
  • 170 Answers
1. If the water is going onto the floor during the drain cycle there is either a hole in the hose or it is completely loose from the DW or a hole in the drain assembly under the sink but if that were the case you would have water under the sink also.
2. If it during the wash or rinse cycle then the seals are not sealing (door is not closed all the way or seals are bad) or the float at the right front of the DW is stuck allowing the DW to overfill with water.(you need to open the door and pull the float up and out as you do so push it up and down and listen for a clicking sound.(which indicates it is making contact with the fill solenoid)..if you here the clicking and the float is full of gunk (old soap and such) clean it out and replace it and run it through a cycle and monitor the DW to see if the fill cycle shuts off before the water reaches the overflow point.
3. the only other option is a possible rust through on the DW and or the drain and motor mount in the center of the DW where the food particles and water are drained...is loose and leaking or rusted through...(how old is the DW).
4. Also check to see there are no large particles around the door seal to prevent complete closure and sealing of the door seal. As well as the door latching properly (when closed can the door be moved or pulled open)?
I hope this helps and let me know if not Please relay model number, age and other specifics you feel are pertinent...thank you and please rate me if this helped...thanks again ...the Fang
Posted on Mar 26, 2009
Frigidaire FFHS2311LWD has water pooling up and freezing bottom drawer and lower vent. Drain tube doesn't seem to be clogged. Water leaks onto floor some days.
the drain tube is most likely clogged. if the lower vent is freezing up there is no way to confirm because it is covered with ice. the reason water leaks onto the floor is, the refrigerator goes into defrost, frost melts and runs down the ice to the door. use a hair dryer to remove all ice, then use hot water to check drain. drain tube may be up to a foot long and may have a trap. you may have to go in through the back to gain access to the drain
Oct 22, 2013 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Float switch dripping water onto floor while dishwaser running
You will find that the flood switch will be operating due to the leak, it will most likely be from one of 2 places:
1. Around the door seal, Give it a clean and check for splits/damage, and make sure screws on door hinges are tight.
2. Check the rollers that screw onto the inside of the dishwasher cabinet, The screws on these can come loose and cause water to run down into the base, check they are tight.
Hopefully this helps.
Mar 04, 2012 | Dishwashers
Hello! I have an issue with my maytag dishwasher model number MDB6100AWQ. It is running, and it goes to drain, and slowly starts leaking onto my kitchen floor! We took it out about a year ago and...
check the door gasket. check that it is draining. disconnect drain line from under sink ad put into a bucket. most likely it isn't draining ad is overflowing.
Sep 22, 2011 | Maytag Dishwasher
My asko dishwasher D 1716 is leaving a white film on my glasses and other dishes. I have added Jet Dry but it has not helped. Also sometimes water leaks under the handle and runs down the front of the...
Hi
The issue is with the water not draining as something might be blocking the drain pump assembly thus the water is leaking. To solve this issue you'll have to take the front lower access panel out and then clean the drain pump assembly completely, also clean the impeller and chopper assembly located at the bottom of the unit. After this is done the issue should be resolved, if not then check the float switch mechanism and make sure that is fine. Hope this helps...please post back for further assistance.
Daniel
Aug 27, 2011 | Asko D1716 Built-in Dishwasher
Periodic water leaking from Kenmore Elite K701
hello Adrian. I am suspicious that the standing drain pipe behind your machine may sometimes over flow. To find out, pack some dry newspaper around the drain hose where it enters the drain line behind the machine. If that newspaper gets wet you will know that the drain is sometimes overflowing. If that is the case, snake that drain or force a garden hose down it and run hot water thru it for ten minutes. J.
Jul 05, 2010 | Kenmore 24 in. 17482 / 17484 / 17489...
Water vALVE DOES NOT QUITE SHUT OFF. AFTER WASH COMPLETED, water leaks slowly into tub and overflows onto floor. iT IS TYPE 1353-1. wHAT IS PART NUMBER FOR WATER VALVE? pRICE AND WHERE i CAN GET ONE? tHank...
If you can supply the Product number or model number I would be able to help.It would not be a major expense for a new inlet valve.Check if the drain pipe from the dishwasher if going into a pipe outlet in wall that it is not too far down into pipe as this could cause it to syphon back into unit.Also if drain goes to a sink outlet make sure the drain hose is above any other outlets,you could tie hose up into a "U" shape above outlet this will stop waste from sink getting into Dishwasher.
Hope this helps.
Jun 07, 2010 | Dishwashers
Freezer door leaking alot of water on floor no ice on door
This really sounds like a plugged drain. When the unit goes into defrost the water should run down the drain into the drain pan...when the drain is plugged it will run over and down to the bottom of the freezer thus leaking out the bottom of the door and onto the floor. You will need to take everything out of the freezer and remove the screws that hold the back panel on break out the ice at the bottom and use hot water to pour down the drain to clear it.....also if you have a small hose to shove down the drain that will help out alot.
Oct 03, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have water dripping from the bottom of the dishwasher where the drain line connects
there is and you can find it at a resturant equipment dealer. if you need to have a quick fix untill then. silicone sealant will do in a pinch.
Aug 28, 2008 | Hobart AM14-253 Free-standing Dishwasher
Bosch diswasher
check heater element for open circuit, if the dishwasher fills and empties and wooshes the water round, there is little else to go wrong
Oct 05, 2007 | Bosch 24 in. SHE44C02UC / SHE44C06UC /...
Leaking on floor only after shuts down.
Griz, check the vent and see if you have bunch of gunk thats collecting water in it. Sometimes the spray arms are cracked and direct water into the vent. If this happens you will have leaking down the center of the door. Catriver...post back
Aug 14, 2006 | Kenmore 18 in. 14432 / 14439 Built-in...
Dishwashers Logo
426 people viewed this question
Top Maytag Dishwashers Experts
Charles T Nevin
Charles T Nevin
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
