Question about Toshiba E-Studio 306 Copy Machine
Status code 4011
Not printing or copying
Kyocera FS6525MFP - How do I get it to display the number of copies already printed when I have a large job, such as 100 or 300 copies.
Press "System Menu / Counter" button. Press "Report". Press "Report Print". Press "Status Page". Press "Yes". The Status Page will print. Look for Counters in the right column just over 1/2 way down, then follow it down 4 lines to Total. The total page output is just to the right of the Total. Note don't use the Total at the bottom of the page, that is for scanned pages.
Sep 12, 2013 | Kyocera Office Equipment & Supplies
Error code status 4011
Error 4011 indicates that a job has been deleted at the machine console from the job list.
Cheers
Daren
Mar 26, 2013 | Toshiba E-Studio 3040c Color Copier
How do i print with color on this machine?
This machine (Sharp AL 1530CS) is a black and white printer/copier but can Scan (not print) in colour. It only has a black toner so will never print in colour...sorry
http://www.sharp.net.au/cms/products/4011/downloads/AL1530CS_Brochure.pdf
Dec 30, 2011 | Sharp AL-1530CS All-In-One Laser Printer
I replaced the cartridge of my hp psc 1401, copied the test page that was automatically printed, but now I can't print anything. Copying works OK. I don't get an error message or blinking lights on...
what is the status of print job in the queue? whether it is showing printing or no status in the windows.
if the status is printing you delete all the print jobs and switch off and on .then try print something. if no status is there in the windows then you check whether the printer is off line .try make it online by right click on the printer icon then click on the use printer online.
Aug 10, 2011 | HP PSC 1401 All-In-One Printer
Thin black line on Xerox 4011 laser printer
Does the same thing occur with a different document.. Because it is not repetative, it leads me to believe the line is being drawn at the direction of the software. Try printing a test page, and see if the line appears. If not the issue is from within the word processsing software. It almost sounds like a legal template for a pleading..
Nov 21, 2008 | Computers & Internet
Receipt not printing
I believe this might help, not exactly familiar with this exact model but here it goes.
Receipt ON/OFF function
When you use the printer to issue receipts, you can disable receipt printing in the REG mode to save paper
using the receipt ON/OFF function. To disable receipt printing, press the Rkey in the OP X/Z position. This
key toggles the receipt printing status ON and OFF.
The register will print reports regardless of the receipt state, so the paper roll must be installed.
To issue a receipt when receipt ON/OFF function is set to OFF:
If your customer wants a receipt after you finalized a transaction with the receipt ON/OFF function being OFF
status, press the Rkey. This will produce a receipt. However, if more than 30 items were entered, the
receipt will be issued in a summary receipt.
Copy receipt
You can print a copy receipt by pressing the Rkey when the receipt ON/OFF function is in the “ON” status.
To realize this function, you must enable the function. Please refer to page 62 (Job code 63).
Nov 11, 2008 | Sharp XE-A404 PC Desktop
XEROX workcenter M20i prints codes at bottom of page
someone has gone into diagnostics and enabled Status Print Engine
Fix
1. press menu/exit key
2. enter # 1931 in that order
3. engine test(diagnostic) should be displayed
4. use arrow keys to scroll to, then select engine test(status print)
5. press enter
6. press the "2" key on numeric keypad to disable (status print)
7. machine will revert to Ready to Copy
8. power off and then back on the M20
9. Your done.
May 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Canon MF6550
Try to press te System Monitor Button and scroll using the > to Print Status. If there is a print job in there press ok the < to cancel the print job. You may want to check the other status windows in case it is a Fax or Copy job instead of a print job.
Apr 18, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
Toshiba E-Studio 306 Copy Machine Logo
568 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
