Syncmaster 2232BW blank screen
I have Samsung Syncmaster 2232BW which has been great until today, now whenever i switch it on it displays properly for approx 2 seconds and then goes blank. If i press the menu button the menu comes up very faint as if there is no lighting from the back. switching the monitor off and on produces the same effect (picture for 2 seconds and then blank)
Does anybody have any ideas about this?
bunnydawg
  • 5158 Answers
SOURCE: screen goes bank after 2 seconds even if powder light is on
i just finished repairing a 20 inch acer monitor that had the same issue.... you have to take it apart and examine the power supply side of the monitor. there are capacitors that go bad on that board. you can tell be feeling the tops of them... the feel rounded. replace the capacitors and put it back together and it will work fine
Posted on Apr 16, 2009
  • 788 Answers
SOURCE: Monitor not wrking
Sounds like you may have had a power surge.??
Disconnect power and signal input.
Turn the unit off for 20 minutes or so. Check the outlet against another device. ( Light )
Turn unit on without connection to PC video.
If you get a no signal, you good to go . Reconnect. If you continue to get a flashing light on power button,
Check warranty, get it back to Samsung for repair.
Hope this has helped
Posted on Sep 03, 2009
SOURCE: Monitor goes blank after 3 seconds -Samsung SyncMaster 920NW
hello i have the same problem, there are 4 lamps (bulbs) inside the monitor when some of them falls the system turn off, cheks and good look
Posted on Oct 27, 2009
SOURCE: Benq FP71G monitor screen displays momentarity on
check your power supply and power cable and check your monitor cable if its not damaged..or try your monitor to another computer..
Posted on Jan 19, 2010
  • 732 Answers
SOURCE: My Samsung SyncMaster T220 does not display
m_r_murphy, The T220 may have developed an internal ac to dc "switch-mode-power-supply / CCFL inverter supply" power problem an you may need to need to have it repaired, Look into warranty or outside technician to refurbish the unit's SMPS/inverter!!! From your description, I believe that the SMPS is in "partial shutdown" mode!!! (no 12 to 14v dc) to power-up the "cold-cathode-fluorescent-lamps" that enable you to see the text and graphics that you already know are being displayed on your lcd panel!!! (+5vdc or 3.3vdc rail still alive!!!) You have "black screen" symptom!!! NOT BLANK n BLACK screen!!! There are lots of DIY videos on YOUTUBE to help you decide if you can attempt a cheap (<$20usd) repair to your unit. Do some reading in my old fixya profile (louie12fix) and visit some of the links you find there. Because your T220 isn't any different than any other brand of CCFL back-lit lcd display in it's basic design and operation you should be able to fix it. Get back to me lmistyrel on aim or do additional comment to this original post here on fixya with info on your next step to repair this unit.
All the other ccfl back-lit lcd monitor tech's on fixya already know what's wrong inside your unit!! Do your research first!! Bye for now, 12fixlouie
Posted on May 07, 2010
Increase in brightness & sometimes switch to "negative" momentarily
he Dell I'm using also has an adaptive brightness, regardless of the fact it does not have a light sensor. It just changes brightness of the screen depending on how much white/black is shown at that moment. Whenever I switch from a very dark to a very bright website I notice and increase/decrease in screen brightness. I'm running Windows 7 by the way.
Good Luck
Jan 01, 2018 | Samsung SyncMaster 2333SW 23" LCD Monitor
I have a SyncMaster 2232BW monitor hooked to my pc, the blue power button comes on when power on, my computer POST appears for about a second then vanishes leaving only bright lights on display, none of...
Seems that you may have the wrong type of video selection theres a button for auto sensing the type of connection. if your video cable is blue then you have an analog connection, white video cable is a digital connection you just need to ensure that the monitor is set to the proper selection.
Sep 05, 2011 | Samsung SyncMaster 2233BW 22" LCD Monitor
I have Syncmaster 2232bw. When I first switch it on it flashes for about 1 minute before it stopsa flashing. After that it runs fine until I switch off and it cools. Is this the backlight dying?
This happened with my 2232bw also. The problem was that the 5 820uF capacitors that had burnt out so I replaced them with 5 1000uF capacitors and it's now working like a dream.
Hope This Helps
Slick2160
Oct 15, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung syncmaster 245bw menu buttons don't work
It is a hardware problem. you can repaired it from service center.
Nov 13, 2009 | Samsung SyncMaster 245BW Monitor
Samsung SyncMaster 213T - DIM DISPLAY
I would follow the self-test below. If you see the same issue in the test screen then your monitor has lost it's sync and would need a board replaced.
If it dosn't appear during the test, then you might want to test it on another PC.
Self-Test Feature Check
1. Turn off both your computer and the monitor.
2. Unplug the video cable from the back of the computer.
3. Turn on the monitor.
If the monitor is functioning properly, you will see a box in the illustration below.
This box appears during normal operation if the video cable becomes disconnected or damaged.
4. Turn off your monitor and reconnect the video cable; then turn on both your computer and the monitor.
If your monitor screen remains blank after using the previous procedure, check your video controller and computer system; your monitor is functioning properly.
Jul 22, 2009 | Samsung SyncMaster 712N 17" Flat Panel LCD...
Samsung 191T Blank
You need a fluorescent back light and inverter kit. Available on eBay.
Jun 10, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Blank screen, flashing led power light
this sounds exactly like what happened to my 2232BW. I took screenshots of the fix and posted them on my webpage:
http://www.alexdemo.site90.com/#samsung2232bw_fix
Jun 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
My syncmaster 2232bw keeps blanking out
Check the power connection on your screen.
If this doesn't solve the problem, you will have to contact Samsung.
Dec 01, 2008 | Computers & Internet
Syncmaster 171s keeps blacking out.
video card may not be able to keep up with the page or the monitor is set to th wrong resolution on the display settings
Apr 29, 2008 | Samsung SyncMaster 171S 17" Flat Panel LCD...
Sounds like the invertor board in the monitor is bad or the LCD screen has had it and needs replacing.
Jun 04, 2007 | Samsung SyncMaster 191T 19" Flat Panel LCD...
Computers & Internet Logo
681 people viewed this question
David Payne
David Payne
