Question about Olivetti Lettera 25 Typewriter
What is carriage lock ? - Olivetti Lettera 25 Typewriter
  • 117 Answers
Carriage lock locks the carriage in the center so that it does not move around when you put it in the carrying case.It should be a metal slide on the frame.
Posted on Mar 24, 2009
Where is the lever that releases the carriage on the olivetti 32
There is a chrome lever on the right side of the carriage on top that should manually release the carriage by pushing down on it. If this works but there is no spring tension pulling the carriage to the left, then the drawband is probably broken. If pushing the lever down doesn't work then eithor the mechanism is broken or locked up or there is a carriage lock that need to be released. If there is a carriage lock it would be located under the carriage on the left or right side. It would be a small chrome lever sticking out the side.
Apr 15, 2013 | Office Equipment & Supplies
Cannot unlock the carriage
There is a little lever under the carriage on the left,used for locking the carriage when in transit.Move the lever in the opposite direction,if that does not work press the Capital Lock Key then try it.If this does not work,it will be your carriage return spring having lost its tension.This is the round drum(wheel ) on the back of the carriage connected by a cord.
Oct 29, 2011 | Olivetti Lettera 25 Typewriter
I am Eric, I have this error message on my epson stylus pro 9600, SERVICE REQ. 00010004
Service Request errors in the range 00010004 - 000101D are related to a carriage movement problem. In some instances like paper jams, the carriage locking tab may be partially pushed in, causing the carriage locking mechanism to put a drag on the carriage or lock the carriage completely. This will cause a carriage error. Make sure the carriage locking tab is pulled to the left. Then turn the printer's power off and release the carriage by pushing down on the cutter blade. Slide the carriage to the left and look for any paper that also may be restricting the carriage from moving freely.
00010004 CR Motor encoder check error
Hopethis helps. If it does, please accept and rate the solution! Contact me withany more questions you may have. Thanks for using FixYa!
Jun 24, 2011 | Epson Stylus Pro 9600 InkJet Printer
I have an epson 4880 with an error reading "service req. 0001001d" How can I fix this
00010004 CR Motor encoder check error 00010005 CR Motor out of step 00010006 CR Motor over current 00010007 CR Motor in-position time-out 0001000A CR axis detection error 0001000F CR Motor PWM output faulty 0001001D CR servo parameter error
The T-Fence may also be dirty or out of the carriage encoder. Check to make sure it is clean and in the center of the encoder. Contact Epson for additional assistance.
May 09, 2011 | Epson 4880 Stylus Pro InkJet Printer
Hermes 3000 carriage is "locked."
I think there's a lock there in the spacing. Mine can be locked by pulling the spacing lever far upward. Just set your spacing and I think it will unlock.
Apr 18, 2011 | Office Equipment & Supplies
How do you unlock a De Ville 410
Are you saying the carriage is locked, so it can't go back & forth? Sticking out of the right-hand side of the carriage are two tabs; I think they're light blue. Pressing down one one locks the carriage. Pressing down on the other unlocks it. When the carriage is unlocked and moves out of the way, you can see the ramps and notch molded into the bottom of the case to hold the carriage for shipping.
Feb 17, 2010 | Smith Corona Office Equipment & Supplies
Olivetti Lettera 32 typwritter carriage doesn't move
If the locking lever is off, then the carriage is bound, or one of the tabs is hung, try releasing all the tabs, pushing the space bar or the tab key while gently moving the carriage.
Try all of the function like shift while gently pushing on the carriage always to the right..
also check the that the margins are not locked.
This could be a lot of different things...
Dec 18, 2009 | Olivetti Lettera 35 L Typewriter
Scanner carriage jammed #3 and #6 does nothing.
Check if you haven't moved the scanner lock lever accidentally - find the lock lever (used to immobilize the carriage in transport) and move it to locked position, then to unlocked, and power up your unit. Chances are that the carriage was not dislocated when trying to move while locked, and will start to operate.
If it's not that, it may be a number of things, like broken belt, encoder strip (if any), carriage motor fault - things you won't be able to repair yourself.
Nov 12, 2009 | HP Office Equipment & Supplies
Can't find carriage lock on Olivetti Lettera 25
Learn how to unlock the carriage in Olivetti Lettera 22 Manual posted by Ed Cornish (Carriage Locking Lever 7). It is a different machine model, but the lock/unlock mechanism might be the same.
You can see the full manual at Ed’s Flickr account or you can download it from here: http://dl.getdropbox.com/u/1322442/Olivetti%20Lettera%2022%20Manual.pdf (temporary link)
Aug 28, 2009 | Olivetti Lettera 25 Typewriter
EPSON CX7300 locked carriage
hiii...
you carriage is jam at the purge unit..u need to open all u printer cover..try to move the carriage slowly..couse it may can damage purge unit..
Oct 31, 2008 | Epson Stylus CX5400 All-In-One InkJet...
Olivetti Lettera 25 Typewriter Logo
522 people viewed this question
Top Olivetti Office Equipment & Supplies Experts
James Cagle
James Cagle
Alun Cox
Are you an Olivetti Office Equipment and Supply Expert? Answer questions, earn points and help others
