My windows have sweat on them
Foarming black looking stuff to be on seals
  • 92 Answers
It's mold from the moisture, make a mix of 1 part bleach to 5 parts water and spray it, the black may not go away entirely but it will kill the mold.
Posted on Jan 24, 2009
HBS-750. Why is volume low?
Take off the rubber earpieces and look down the holes to the speakers. Can't see the speakers? That is because there is a black sticker covering the hole. The sticker is actually a very fine mesh that is supposed to let sound through. But it gets clogged with earwax and other crud, which interferes with the sound. The mesh is probably supposed to protect the speakers, but what is the point if it kills the sound? I removed the mesh and my LG Tone+ sounds like new again. Maybe it will die a quick ***** from sweat and stuff, but I was going to throw mine away anyway, so even if it's living on borrowed time, I'm happy.
Apr 14, 2014 | LG Radio Communications
My brand new deepfrezzer glass top glass is sweating lot how?
There may be a crack in the seal or it is not shutting all the way.if it ok , then sweating is a natural occurrence. Age of freezer has nothing to do with the sweating. It probably is ok.
Jan 29, 2013 | Magic Chef 7 cu. ft. / 198 liter Chest...
How to clean water tank as water dispenses with some black stuff
If you look up inside you will mold around the spout. this is were your black stuff is coming from. THe water system is completly sealed and cant be cleaned. However you can flush it. Use a cleaner with bleach in it to remove the mold from dispenser. You also may need to change the chute door . It leaking air is where the mold came from. Ihope this helps.
Aug 21, 2011 | Jenn-Air JCD2389G Side by Side...
On my pentax k1000 the black fuzz looking stuff
That's the mirror bumper, it softens the blow and cuts the noise as the mirror flips up.
Carefully remove it and then replace it with a new one. You can get it as part of a foam light seal repair kit for your camera; this also ensures that the sticky black goo which used to be foam and which prevents light from getting past the edges of the camera back gets replaced. Light seal kits are very cheap, and if you buy a pre-cut version then it makes a fiddly job a bit easier and potentially less messy. They're widely available on sites like ebay, just search for "k1000 light seals" and check that the kit includes a mirror bumper/buffer.
If you don't get it repaired the fuzz will get everywhere and can also get onto the film surface causing white spots on your photos or black spots on negatives/slides. The debris can also get into your lenses so remove it asap. Gooey foam light seals are even worse as it's both corrosive and abrasive (due to the grit it attracts) and gradually migrates to gum up the works. It can also result in light fogging on your photos (usually seen as red streaks from the top or bottom of the picture). Modern foam seals do not decompose like the old ones did.
I hope that I've helped you, please take a moment to rate my answer.
Mar 02, 2010 | Pentax K1000 35mm SLR Camera
My Daewoo FR370 DLX two door rerfigerator sweats in the outside edge of the door. Has the door seal got worn off. It is five years since I bought this refrigerator. Kindly assist me
yes, the sweating is from the temp difference from the inside and outside of the door. The air must be escaping past the seal.
Nov 25, 2009 | Refrigerators
Frig sweats inside
Bad door seals. Air is getting in.
Sep 08, 2009 | Kenmore 65802
There is looseness in the back cover when it is closed and there is gooy black stuff on the door where it seems to sit against the camera body
Stick black substance is probably the light seal the camera has along the edge of the door. Over time these foam like seal become stickey and start to fall apart. The same stuff is used as mirror dampening the mirror flips up when you take a picture. I think you can do a search on Google for an instruction to replace these deteriorating seals. I've had plenty of them myself on classic film cameras.
Aug 19, 2009 | Ricoh KR-30SP 35mm SLR Camera
I've been told that my front and rear struts are leaking!
I doubt all four struts are leaking take it to another mechanic to get a second opion.
Jul 10, 2009 | 1995 Toyota Camry
Window Air Conditioner Sweats
You need to seal the portion of the air conditioner that is inside the window from the portion that is outside the window, Sweating is caused by moist outside air leaking in and contacting the cold portion of the air conditioner. Do not use duct tape, buy aluminum tape which is what professionals use to seal air leaks on ducts. Home Depot sells the tape. Buy the smallest quantity you can find that will do the job ( it can be expensive ) unless you plan to go into air conditioning duct installation.
For best results use some form of insulation over the accordian like side baffles ( cut to fit) . Styrafoam from packaging or silver backed insulboard (Home Depot). Now tape the sides of the insulation to all sides of the window frame, bottom of the window, the sill, and the air conditioner.
Unless you enjoy doing this every year - plan on this being a permanent installation. It is a tedious job because the aluminum tape is not very forgiving and has a peel off backing but it sticks forever.
May 08, 2008 | Heating & Cooling
Heating & Cooling Logo
64 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
