Question about YouTube Computers & Internet
Karcher k4.99 nylon inlet pipe cracked
2 Suggested Answers
  • 11 Answers
SOURCE: karcher k2 power washer inlet-outlet manifold cracked along weld
well depends did u use it in cold tempatures if so no it was u. if not then most likely or could have been just a crazzy thought here that there was a electrical discharge when it was pluged in and cracked the block on it but honestly thats 1/10000000000000 chance of happening. or it overheated and cracked it but relistically if its new then just take it back and play dumb or if its still under warrenty play dumb and get it fixed. aslo u can search for a new part on craigslist or ebay. last but not least if its not uner warrenty or new to take back or u cant find a part either thru the ones i listed or by calling the man. ur last resort is to just throw it away.
Posted on Apr 03, 2009
How to connect the telescopic jet pipe to my Karcher K7?
Karcher utilizes a europeon fitting known as 22 mm female out of pump need to know type of fitting on wand they have adapters .telescopic wands may be standard either 1/4" quick disconnect or national male pipe thread
Aug 20, 2014 | Karcher Garden
Karcher k3.00 lack of power
Are you using the same water supply as before when you had good pressure? Some house water lines have pressure reducers to protect your pipes and appliances. This can restrict the water flow and reduce the pressure the machine develops. If the flow surges (good, then weak, then good etc) you are not getting enough water to the pump. Try a larger diameter garden hose (5/8"). If you know where your water line enters the house, try the hose bib closest to it. Often times it is at street pressure instead of (reduced) house pressure.
Aug 03, 2014 | Karcher Garden
Pressure washer is leaking at the bottom and no pressure
It sounds like you have cracked head.. is the unit surging/cutting in and out when you turn it on, this is a sign of a cracked head.. this is often caused by warm water entering the unit even slight warm water like leaving the inlet hose in the sun for an hour before using the cleaner
Brad
Jul 18, 2014 | Karcher K3150MT200
Water coming out of detergent pipe from top for karcher 3030 b jet wash
DISCONNECT HYDRO OR WITH ENGINE NOT RUNNING DISCONNECT SPARK PLUG THEN RE-LEAVE WATER PRESSURE BEFORE SERVICING the detergent pipe plugs into a pipe on the pump, under which is a spring and ball bearing (stuck open, debris) WEAR YOUR SAFETY GLASSES
Apr 01, 2014 | Karcher Garden
Water coming from bottom of unit
You will need to remove the mainc cover and see where the leak is. It could well be either the inlet pipe or the main pump seals.
May 21, 2010 | Karcher PSI Electric Pressure Washer
IWater Leak from LG12225FD Washing machine
may be pump...hose seal... in outer tub...cracked inlet valve cracked hose inlet to tub
Aug 17, 2009 | Washing Machines
Water spraying out of the front vent of unit.
Dear zenith 10deg,
The outlet elbow attached to the head inside must have cracked. Leakage from selas do not that much spraying. Spraying are almost always caused by the cracking of the outlet elbow or the cracking of the head itself. The inlet elbow also makes a lot of spraying wheb broken, especialy if inlet water pressure is high. To see exactly from where the spraying is coming out, one must for sure remove the cover. Removing the cover must be done, because just the same one has to fix the problem.
Regards,
fulltech.
Apr 08, 2009 | Karcher Garden
Karcher k2 power washer inlet-outlet manifold cracked along weld
Apr 03, 2009 | Karcher K2.26 Electric Power Washer
Water gushes out of the inside of my Karcher jet washer.
you can sometimes seal the water leak from the inside as I think your water inlet case has split
Jan 07, 2009 | Karcher Quick Connect Nozzle Set
Computers & Internet Logo
15 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
LP
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
