I am trying to download my video files from my JVC MG130U to my Windows Vista Laptop. I am connected with a USB cord. I went to Windows Movie maker and tried import from digital video camera. I get an error message on the computer "cant find a compatible video device". On the camera I connected and the computer gave me a msg that the software has been loaded. I tried to create a DVD but that doesnt work either. I have a disk in the drive. I would like to download the files to the PC so I can edit them and then burn them to a DVD. Any ideas how to get it to work?
You can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=GZ-MG21U
You might want to consider NOT using a driver. The best way to download videos and pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy videos and pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any video/photo cataloging program, such as Windows Movie Maker and Windows Photo Gallery.
A firewire to USB will not work. It has to be firewire to firewire. A JVC GR-D240ek uses 4-pin, IEEE 1394 compliant Digital Video Connector [DV OUT] to connect a 1394 cable (also known as a FireWire or i.Link cable) to a laptop equipped with an equivalent IEEE 1394 port. Please note that some laptops firewire port could either be 4 pins or 6 pins.
Soon as that connection as shown above is established, you can use Windows Import Video to capture / download the videos.
Other notes (from the same Windows Help link above) :
You can also open Windows Import Video by using Windows Movie Maker. After you connect ... your DV camera, and your computer, start Windows Movie Maker, turn on your DV camera, put it into playback mode, and Windows Import Video should open automatically.
You can also open Windows Import Video by using Windows Photo Gallery. After you connect ...your DV camera, and your computer, start Windows Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Photo Gallery, click File, click Import from Camera or Scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
You can also open Windows Import Video by using Windows Live Photo Gallery. (This options requires you to install Windows Live on your computer.) After you connect your...your DV camera, and your computer, start Windows Live Photo Gallery, turn on your DV camera, and put it into playback mode. In Windows Live Photo Gallery, click File, click Import from a camera or scanner, click your DV camera in the list of devices, click Import, and then follow the instructions.
Verify that the laptop's firewire port is 100% up to specs and totally compliant to IEEE 1394.
I had the same problem, try downloading a file converter such as
"prism File Converter" to change your MOD files to JPEG and then import
in Windows Movie maker
Here is the issue. Connecting this camera to your PC via USB will only allow you to download the pictures that you have stored on the camera's SD card. To download video to your PC you will need to use a firewire to 4-pin DV cable. If you do not have the software from JVC, no worries as Movie Maker on Windows XP will import video from devices for you. Movie Maker in Vista will not allow importing video or capturing from devices at all, so you will need to get the JVC software if you are oin Vista.
First, you need a program on your computer that searches for connected digital video devices. Like Windows Movie Maker! Look for Windows Movie Maker on your laptop. If found, bring it up and there should be a task panel on the left side. Near the top, there should be something that says "Capture from video device". (Or something close to that.) Click on it and Windows Movie Maker will search for connected video devices. It should find you camera and will show you what you need to do. (Make sure your camera is turned on play mode.) Windows Movie Maker is a very easy to use program and allows you to add music, transitions and all kinds of cool effects to your videos. If you have any questions, please ask.
So after a little digging around I might have a solution for you. Use this program (Super) to convert your files into Windows Media Video (.wmv) files and Movie Maker should be able to handle them.
I have he everio GZ-MG130U and still hav the install disc and would be glad to help ny of you that need an install disc,should work with 225u 155u and f course 130u
ditto...me too!!!! This sucks!!!
