Question about Garmin Nuvi 760 Handheld GPS Receiver
No sound from my nuvi 660
Device seems to function but no sound - no voice, no MP3 player, no touch screen tones - nothing. Checked volume, mute, pressed the reset button. Held down the on off button until pre boot mode. The device has not been used for a few months but was stored in a safe drawer
  • 1 more comment
  • nihoa Feb 16, 2009
    nuvi 750 same problem no sound at all. i went to garmin site and tried all updates and still no use. found out there is a year warranty but i bought on feb 12 2008 and stopped working on feb 13 2009. funny? i also kept getting a message about 2 weeks before about the maps being out dated and needed to buy and update. i am going to call tech first thing on monday to see if any solutions.
  • Anonymous Feb 18, 2009
    no sound
  • Anonymous Mar 01, 2009
    same problem as described above except i have the nuvi 350 model
  • 38 Answers
Let me first start by saying that for the $$ I paid for this thing I think it is really screwed up that so many people are having the exact same problem and I truly hope Garmin fixes the glitch. Now - on to the fix..... Before getting started, you should test my theory to see if the reason you no longer have sound was the same reason as I had. Turn the unit on and ensure all the setting indicate that FM transmitter is OFF and volume is not muted. Go to the volume adjustment screen and while adjusting the volume up and down you should apply pressure to the back left side of the unit with your fingers. I found the sweet spot to be about 1/4 distance down from the top and 1/4 distance from the left of the unit. Now, while pushing in at this location on the back of the unit with your left hand pointer and middle fingers, click the volume buttons up and down with your thumbs and if you hear sound... then it's time for the SIMPLE repair!!!
There are 2 small torx screws located on the back of the device down at the bottom. I didn't have a torx bit this small but I did have an allen key that worked. take out the 2 screws and open the back plate, don't be scared. Once open you will see 2 sets of wires connecting the back plate to the main board, one is the power cable coming from the battery which is affixed to the inside of the back cover, and also the speaker wire. I had plenty of room to perform my fix without any need to disconnect these wires, just be sure to pop it open gently as to not damage the wires but trust me - you will have plenty of room to work with. On the mainboard side of the device you will see a square chip-looking thing mounted onto a metal plate which protects the mainboard. All I did was put a glob of hot glue onto this chip. The glob should sit about 1/4 of an inch high. Let the glue dry. Place the back cover back in place and screw it back together. Done. If you don't have a hot glue gun then by all means feel free to use anything that is roughly 1/4 inch in width such as a folded up piece of paper or perhaps or whatever else you want to use. If your's was like mine then you are set to go and this problem should not rear it's VERY ugly head again.
Joe E
Posted on May 06, 2009
Go to tools...then select settings...then language...make sure voice is set to American English. Hope this helps!
Posted on Mar 20, 2009
    Brigadier General:
  • 5,158 Answers
If you go to www.garmin.com you can download the manual for that gps as well as any updates... it is likely that the sound is shut off in the menu
Robert
Please rate this solution ... thanks
Posted on Jan 24, 2009
I'm not getting verbal directions from my Garmin nuvi 260W. How can I fix this problem. A day ago it was working properly.
If you are not receiving any sound on your N?vi 2xx thefirst thing to check is that the sound is not muted. To ensure that your unitssound is not muted please perform the following: Turn the device on Press the Volume button on the 'Where To?', 'View Map'screen Ensure the Mute box is not 'checked' If the mute button is not 'ticked', you will need to changethe voice to ensure that the preset voice is not faulty: Turn the device on Touch the Tool icon Touch Settings Touch Language Touch the language voice next to Voice Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you arerunning the latest software which can be done by installing a program calledWebUpdater. WebUpdater can be installed via the link below:
http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Once updated please allow the unit to reboot which will ensure the softwaresuccessfully installs.
Jan 21, 2011 | Garmin nuvi 260W GPS Receiver
I do not have any voice but do have picture. Volume is turned up.
If you are not receiving any sound on your nuvi 200 or 205 series device the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  1. Turn the device on
  2. Press the Volume button on the 'Where To?', 'View Map' screen
  3. Ensure the Mute box is not 'checked'
If the mute button is not 'ticked', you will need to change the voice to ensure that the preset voice is not faulty:
  2. Touch the Tool icon
  3. Touch Settings
  4. Touch Language
  5. Touch the language voice next to Voice
  6. Scroll through and select another appropriate voice
If changing the voice is not helping you will need to ensure that you are running the latest software which can be done by installing a program called WebUpdater. WebUpdater can be installed via the link below:
Once updated please allow the unit to reboot which will ensure the software successfully installs.
If after following all the above the final steps would be to perform a master reset:
Note: A master reset will erase all waypoints or favorites and will restore your unit to the default factory settings.
  1. Start with the unit OFF and unplugged from power
  2. Touch and hold the lower right corner of the screen with an index finger or the eraser end of a pencil
  3. Continue touching and holding the lower right hand corner of the screen then power the unit ON
  4. Release the power button when the device powers on. After 5-10 seconds you will see a new message: Do you really want to erase all user data?
  5. Remove your finger from the touchscreen when this message displays
  6. Touch Yes
The device will automatically reset. Please follow the on screen prompts on the nuvi and when completed place your device in an area with a clear view of the sky until it acquires satellites.
Sep 23, 2010 | Garmin nuvi 200W GPS Receiver
Garmin Nuvi 265w voice command stopped working. Any suggestion on what to check?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you are not receiving any sound on your Nüvi 2xx the first thing to check is that the sound is not muted. To ensure that your units sound is not muted please perform the following:
  2. Press the Volume button on the ‘Where To?’, ‘View Map’ screen
  3. Ensure the Mute box is not ‘checked’
If the mute button is not ‘ticked’, you will need to change the voice to ensure that the preset voice is not faulty:
  3. Touch Settings
  4. Touch Language
  6. Touch Yes
Nov 15, 2009 | Garmin Nuvi 265W GPS Receiver
Help!! Volume not working!!
  3. Touch Settings
  4. Touch Language
  6. Touch Yes
Nov 02, 2009 | Garmin nuvi 260W GPS Receiver
We have no verbal direction on our garmin nuvi 260 & it is not on mute. This Garmin is 1 yr old & we have not had this problem in the past. It has not been used for awhile & when we plugged it...
  3. Touch Settings
  4. Touch Language
  6. Touch Yes
Nov 01, 2009 | Garmin nuvi 260W GPS Receiver
The voice on Garmin stopped working
Hi
Please do this and let me know results.
If your device is not providing navigational prompts the language settings on the device will need to be checked:
  2. Touch Tools
  3. Touch Settings
  4. Touch Language
  5. Touch the blue box under Voice
If this section has your desired voice please make sure this voice is selected which will resolve the issue.
If the above fails or the unit doesn’t list the voice/s that you require you will need to update the software and reload the voice/s back to the device via WebUpdater. To install WebUpdater please click the link below:
http://www8.garmin.com/products/webupdater/howtoinstall.jsp
Once installed and the software is updated please make sure that you check for additional updates which should provide you with a number of voices to reinstall to your device.
Once reinstalled your problem should be resolved.
Let me know
Aug 24, 2009 | Garmin Nuvi 660 GPS Receiver
No sound
Check the audio output setting on the nuvi. There is a possibility that the FM Transmitter setting has been turned on or that the device has been muted.
To check the audio output setting:
  1. Touch the Speaker icon below the Wrench icon.
  2. At the bottom of the screen, touch Audio Output.
  3. Make sure that the Internal Speaker is selected and touch OK (660, 670, 680, and 5000 models only).
  4. Make sure that the MUTE box does not have a check mark in it. If it does, touch the box to clear the selection.
  5. Make sure the volume level is at a reasonable percent level.
Aug 13, 2009 | Garmin Nuvi 660 GPS Receiver
Garmin 260w no sound just purchased
  3. Touch Settings
  4. Touch Language
  6. Touch Yes
Jul 04, 2009 | Garmin nuvi 260W GPS Receiver
No Sound
You might have just turned the volume all the way down. Page 4 of your manual tells you how to adjust your volume.
Apr 22, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin Nuvi 760 Handheld GPS Receiver Logo
293 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
Steve
Are you a Garmin GPS Expert? Answer questions, earn points and help others
