Question about Panasonic Panafax Uf-7200 Monochrome Laser - Fax / Copier / Printer /
How to change date & time on fax machine
3 Suggested Answers
  • 134 Answers
SOURCE: how to set an old fax machine
function 7,1 set for date & time, press set after entry
function 7, 4 set then parameter 12 for confirmation report, set to on.
Posted on Jun 12, 2008
  • 54 Answers
SOURCE: how do I print a fax from memory & how do I
press menu then set then feed date and time
Posted on Mar 03, 2010
How to change the time on a phaser 3635
To Set Date & Time on a Xerox 3635
Press: Machine Status (hard button)
Press: Tools (on touch screen)
Press: Device Settings (on touch screen)
Press: Set Date & Time (on touch screen)
The machine will have tabs at the top
Press: Set Date
Press: Month
Enter the Month: (Using the hard buttons)
Do the same for Day and Year
Press: Save
Press: Time
Same procedure as above setting the Date
Press Save
Turn the machine off and back on for settings to take effect.
Dec 20, 2012 | Xerox Phaser 3635MFP/X Multifunction...
I cannot send fax
Hi there!
For you to send a fax with the Brother Fax you can try these steps:
1. First make sure that you have a dial tone by lifting the handset or just by pressing the hook/speakerphone button. Once you have verified you have a dial tone press the hook button again to return to the main screen or hang up the handset. LCD should display the date & time
If you don't have a dial tone make sure that the telephone line cord is connected on the fax machine's Line jack. If you don't have a dial tone still, connect it to another working outlet. If you don't have a dial tone still, connect a working telephone on the wall jack to see if you'll get a dial tone. If you get a dial tone on the regular phone then problem is either with the line cord or the fax machine.
2. Once you have the date & time on the LCD screen, Load the document that you want to send on the automatic document feeder which is directly above the LCD screen.
3. The LCD screen should change from the date/time to "Enter Fax No. & Press Start" Once you got this screen dial the fax number and then press Start.
Hope this helps. Rate if it works.
Thanks!
Apr 02, 2011 | Brother IntelliFAX 2600 Fax
Change the dates on the canon fax l350
Lift the flap on the right-hand side of the fax machine.
Select Data registration
use the down arrow
1. Data registration
SET
1. User Settings
SET
1. Date & Time
SET
Enter date or time
SET
Good Luck!
Hope this helps!
CreativeTECH
Dec 20, 2010 | Canon FAX-L350 Plain Paper Laser
Time & date on Panafax UF-550
Press
Function
71
set
enter date and miltary time
set
stop
Oct 05, 2009 | Panasonic Panafax UF-550 Plain Paper Laser...
Changing date and time for panafax uf6000
press function-7-1-start- change the time and date on the machine. then hit start then stop
Jan 12, 2009 | Panasonic PANAFAX UF-6000 Fax
How do you change the date and time on a Ricoh 3800L fax machine?
To change the date and time on a Ricoh 3800L:
Press the Function key, 6222291, Yes. When the date appears, use the asterisk (*) and pound sign (#) to change the month and to change AM or PM, and use the keypad to change the date, month, and time.
Press Yes Function when you've got it set and want to save it.
Dec 23, 2008 | Ricoh FAX3800L Plain Paper Laser
Showing incorrect date - how do I change the date?
Please change the Leithium battery fixed inside your fax machine, usually this the problem.
If the Date time is running in different date & time.
Please press Menu, then scrolle left of right arrow key. When you find set Date/Time enter the key mentioned in the Display key and change to your date & time.
After some time see if the date/time working normally. If not change the above mentioned battery.
regards.
Jan 07, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Changing Date/Time on fax Machine
Press teh MENU button. Go to INITIAL SETUP. Then to DATE AND TIME
Nov 29, 2007 | Brother IntelliFAX 2800 Laser Fax
Canon L100 fax machine
Just flip the little key cover open on the right hand side of the machine then press "Data Registration" then press "Set" then press "Set" again this will put you on time & date setting if you press "Set" a third time you can now change the settings using the arrows to step around and the numbers to change the settings. Just press "Set" when finished to save your setting & press "Stop" to exit programming mode.
Oct 30, 2007 | Canon FAX-L1000 Plain Paper Laser
Panasonic Panafax Uf-7200 Monochrome Laser - Fax / Copier / Printer / Logo
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
