Question about Motorola Mobility H500 Wireless Headset
Pairing motorola H500 bluetooth w/ nokia 6102i
I've gotten as far as being able to turn the bluetooth device on, but the manual says to pair and when i look for "devices" on my phone, none are found. I need to bond it. Any ideas? Thanks in advance.
    President:
  • 2,961 Answers
You need to press and hold the on button on the headset, until the blue light stays on, then it will be in pairing mode. As soon as the headset is paired the blue light will go off and flash periodically. To turn off the headset press and hold button for about 3 seconds, it will flash 3 times then let go and it will turn off.
Posted on Jul 10, 2007
SOURCE:
Can not connect H500 bluetooth with Nokia 2680 slide cell phone. Need Motarola instructions.
Here are the steps to connect your Motorola H500 to your Nokia 2680 phone:
1. Switch off your H500 by pressing the main button for few seconds. 2. Put the H500 in discovery mode. To do this, press and HOLD the main button till it glows a solid blue light (no blinking). 3. Open bluetooth in nokia phone. Go to Menu, settings, Connectivity, Bluetooth. 4. Select "Add a new Device" and search for H500 5. Click on the name select pair. 6. it will ask for pairing code. Enter "0000"
You are done. Revert in case you have any problem
Jun 09, 2011 | Cell Phones
I can not pair my h500 to my blackberry storm
Turn the bluetooth off and go into the phone to search for devices, then turn the bluetooth on holding onto the on button until the blinking blue light turns solid for a couple of second then let go. The device should come up on the blackberry as Motorola H500, pair it and enter passcode 0000. Goodluck
Apr 08, 2009 | Motorola Mobility H500 Headset
Problems pairing up a Nokia 6301 with my Motorola H500
Try power cycling the phone. Turn the Nokia off, wait 10 seconds, then turn back on and try again. It really does help sometimes. Let us know if this doesn't help.
Apr 01, 2009 | Motorola Mobility H500 Wireless Headset
Cell samsung SGH-F250 with bluetooth motorola h500
ACTIVATING THE BLUETOOTH
You must activate the Bluetooth feature of your phone to be able to establish a Bluetooth connection
between your phone and your SuperTooth kit as well as with other Bluetooth devices.
1.
Press Menu > Settings > Bluetooth > Activation > On.
2.
Press Back as many times as needed to return to standby mode.
PAIRING TO THE CELLULAR PHONE (Not possible while charging the SuperTooth)
Pairing will create a link or connection between the two Bluetooth devices - the SuperTooth kit and your phone.
1. Bring the cellular phone at about 20 cm from the SuperTooth.
2. Turn off the SuperTooth and wait for about 4 seconds.
3. While pressing the Answer Button, turn ON the SuperTooth by sliding the Power Switch to the right. Keep the Answer Button pressed for approximately 10 seconds until you hear a distinctive tone and the Bluetooth indicator LED changes from blinking blue to alternately blinking of red and blue. The SuperTooth is now in pairing mode.
4. While the SuperTooth is at pairing mode, access the Bluetooth menu of your phone. Press Menu > Settings > Bluetooth > My devices > Search new device. The phone will then search for pairable devices until it displays them in the list.
5. Highlight SuperTooth then press Select.
6. Enter PIN “0000” then press Ok. (Wait until “Paired with …“ and “Connected” will be shown briefly.)
7. Press Back as many times as needed to return to standby mode. Pairing is successful if the alternating red/blue lights of Bluetooth Indicator stops and then change to plain blinking blue. Normally, the phone would also show briefly on its display if it’s already paired and connected to SuperTooth or if pairing with it failed.
The SuperTooth kit is now ready to use.
Nov 15, 2008 | Motorola Mobility H500 Wireless Headset
Communication problems with Motoroala H500
i have a h500 cannot pair with my phone lg env
Aug 01, 2008 | Motorola Mobility H500 Headset
Nokia 6102i will not detect my BH-600
Hey I found the solution :
1. When the headset is off, press and hold the multifunction key until the indicator light is continuously displayed.
2. Switch on your compatible phone.
3. Activate the Bluetooth feature on the phone, and set the phone to search for Bluetooth devices.
4. Select the headset from the list of
found devices.
5. Enter the passcode 0000 to pair and connect the headset to your phone.
In some phones you may need to make the connection separately after pairing. You only need to pair the headset with your phone once.
If the pairing is successful, the indicator light starts to flash slowly, and the headset appears in the phone menu where you can view the currently paired Bluetooth devices.
The headset is now ready for use.
Enjoy..
Pavan
Jan 27, 2008 | Nokia BH-600 Wireless Headset
H500 won't pair with Blackberry Curve
It might already have been figured out but if you hold the answer button on the headset down until the light stays on steady, it is in pairing mode. You can then go to bluetooth setup on the Curve and it will find the headset.
Nov 08, 2007 | Motorola Mobility H500 Wireless Headset
Bluetooth
Press the all-in-one button for about 8 seconds until the light is constantly on, this puts it in pairing mode. then go to your device and initiate pairing. the device code is 0000.
When done the blue light should shut down, and your all set.
Nov 07, 2007 | Motorola Mobility H500 Wireless Headset
Motorola Mobility H500 Wireless Headset Logo
188 people viewed this question
Top Motorola Mobility Radio Communications Experts
Lawrence Oravetz
Dennis Webber
Are you a Motorola Mobility Radio Communication Expert? Answer questions, earn points and help others
