Question about Whirlpool Dishwashers
Whirlpool dishwasher du915 wont run
Stopped running. no power to it apparently. electrical fuse appears in place. any reset buttons?
SOURCE: Dishwasher won't run.
Buy a new one!
Posted on Mar 01, 2008
SOURCE: Whirlpool Gold Quiet Wash Plus GU940SCGZ3
Press the cancel button, Then cut power to the dishwasher for a period of time. restore power to it then try a cycle.
Posted on Sep 11, 2008
  • 171 Answers
SOURCE: Whirlpool Dishwasher model gu980scgq3
Hi vicyoung0921,
I'm Harvey the Master Plumber.
Your question is: Will not start, seems to have no power at all. You checked the breaker and it's fine. Is there a reset button somewhere on this dishwasher ?
No reset, if breaker is good then check the connection at the d/w. It's under the d/w behind the kick plate on right or center under a cover box. 9 times out of 10 you'll find a loose, broken or burnt connection there. That done, it's time to call in warranty repair. If beyond warranty you might consider utilizing the Repair Directory to find a repairman. If the d/w has a few years on it perhaps it is time to compare the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
  • 50 Answers
SOURCE: Whirlpool Dishwasher Not Working
Change the thermal fuse in the control and door switches. The thermal fuse is designed to fail if there is a problem with the switches.
Posted on Feb 26, 2009
  • 17 Answers
SOURCE: Do indesit dishwashers have a reset button?
no they dont have a reset button you might be able to reset by holding the on button for 4 to 5 seconds
Posted on Aug 11, 2010
My Whirlpool dishwasher was running when there was a power failure, and now there is no power whatsoever. The power failure happened when the machine was on final rinse and drain. Water is still in the...
Most Whirlpool manufactured dishwashers have a thermal fuse, located inside the operator console. When tripped, the dishwasher will not run. A power outage can cause the thermal fuse to trip. It cannot be reset and has to be replaced, if bad. Please post back with your COMPLETE MODEL NUMBER (located around the door opening) so I can determine the configuration of your dishwasher and explain how to access any potential fuses. -->
May 19, 2011 | Whirlpool Dishwashers
My dishwashers normal light keeps flashing and wont do anything
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run your dishwasher as normal.
If this same light appears again then you have a bad element or thermostat.
Dec 07, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Control clean light keeps blinking and dishwasher will not function
Dec 06, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
8 yr old GU1200 stopped mid cycle - no apparent reason - no response to buttons - appears dead?
These dishwashers have a thermal fuse in the control panel. If it overheats for some reason (sometimes a bad connection on the fuse itself causes that)it will turn whole machine off.
  1. Disconnect power to dishwasher. Remove screws holding the control panel from the side of the inner door. Remove control panel. If it does not come off - remove all screws on the inner side of the door and separate the inner and outer door.
  2. Fuse is on the right side on top of the control board. it usually has tan or black or yellow wires to it. Disconnect wires and check fuse for continuity. if none - replace fuse. Here is your part
Good luck
Vlad
First Choice Appliance
Sep 11, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
No power to dishwasher; checked breakers they seem
you need to check the power only:
1- check the power come to the wall right ,if not
get elecricity man to bring it to plug in the wall
2- check the cord of m/c if it has fuse check it
and replace with same values ampers,....so on
3- if problem still check electricity reach at end of cord if not ,chang cord
4- if you still have problem inform us
>be ware of electricale chock it is your your life> thanks from me m abba
Jul 10, 2009 | Whirlpool Dishwashers
Wont do anything, not even drain
Try unplugging the unit for 15 minutes then plug it back in. If that fails it sounds like the inline fuse which means you will have to pull out the dishwasher and look near the pump is blown and fuse needs to be replaed
May 26, 2009 | Kenmore 24 in. 15932 Built-in Dishwasher
The dishwasher doesnt turn on
1) Be sure the power is on, the door is latched, and the control is turned on. If absolutely nothing happens--in other words, nothing on the control panel is lit and there are no signs of life-- the appliance may not be receiving power. If the dishwasher's cord is plugged into a receptacle, check to see if it is a GFCI receptacle with a reset button. 20090521162623_gfci-receptacle.gifIf it is, push the reset. If it isn't or if the dishwasher's cord is wired directly to the electrical box, look for any other receptacles in the kitchen that have a reset and and try resetting them. (This is a longshot but it's easy to do and may solve the problem if the dishwasher is on the same circuit.) To test a receptacle for power, you can also just plug a hand-held appliance into it.
2) If that doesn't work, check the electrical panel for a tripped circuit breaker or blown fuse. If you find one, switch the breaker to "Off" and then back to "On" or replace the fuse.
3) If electrical power is available to the dishwasher but the appliance doesn't run, the problem is likely to be a defective door switch, timer, or selector switch. To solve a door switch problem, you may be able to adjust the door latch’s strike slightly, using a screwdriver (turn off the power to the dishwasher at the electrical panel when working on it). Regards Fixya..
Mar 24, 2009 | Whirlpool Gold GB2SHDXPS Stainless Steel
May 17, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Dishwashers Logo
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
