Question about Kenmore 53642 / 53644 Side by Side Refrigerator
I have a Kenmore Frig "Cold Spot Mod#106" side by side
I want to know how to:
1/change the water filter (for water dispenser).
2/fix the light switch (vegetable side) not on -new light-bulb changed.
Thanks
Trang
    Sniper:
  • 50 Answers
The water filter is really a screen in the water valve the same as a washing machine. turn the water off for the water line in the back of unit near the bottom you will find the fill line expands and a connection like a garden hose is there . loosen the connection and inside the valve you will find a stainless screen ,take it out a rinse it under afaucet then reverse your steps. the light switch is easy to change . unplug the refrigerator and lull the light switch off maybe you will need a small flat blade screwdriver to get it going. once you have the switch out check the terminals for broken or burnt wires and connections. take the switch and a vom meter and put it on ohms put a meter lead on each terminal of switch press the switch and you see the meter peg out if it doesn't peg either way the switch is bad get model # and find a parts store.if switch tests ok then problem may be at light socket. make sure light bulb is screwed in tightly because it has to prevent moisture from getting in. good luck
Posted on Jan 24, 2009
Water dispenser not working on Kenmore refrigerator
Is it making any noise when you press the flapper if no then change water inlet valve
Dec 17, 2014 | Kenmore Side by Side Refrigerator
Kenmore mod. 106 water does not get to ice maker and when pushing despenor no rotation of ice out door
Hello Jim,
Sorry it has taken me a while toget back to ya i just got.
So on your refrigerator it very likely is the switch forthe cradlethat ya push to dispense ice and water through the door.
Unfortunitly modelnumber 106 asyou have listed is only the source number of whom your Kenmore was made by. Typically the full model# that does start with 106 willbe on a label on the ceiling or side wall of the refrig. section inside of it, reply with complete model number please and i will be able to help ya disassamble the door dispenser as well as provide you with part numbers and such
Thanks for using FixYa.Com
GENE
Sep 29, 2011 | Kenmore Refrigerators
Changed my water filter on my Kenmore refrigerator. Now the water dispenser keeps dripping? The water filter is located at the bottom of the frig.
You have air in the line from the new filter . Run about 1-2 quarts of water thru the dispensor to remove the air in the line .
Jun 13, 2010 | Kenmore 57029 Side by Side Refrigerator
Water condencing in refrigerator area.
your drain is clogged. defrost unit. remove back panel in freezer and unclog hole where water collects
Feb 10, 2010 | Refrigerators
Slow filter water stream and hollow ice.
You have a mesh screen in the water supply line where it connects to the water inlet valve. It can be stopped up with sediment.
Sep 27, 2009 | Freezers
Kenmore Cold spot 106 Warm Fridge
I would replace the evaporator fan, this fan problem is hard to diagnose because the fan will spin but not fast enough to circulate the chilled air thru the freezer and the refrigerator. The minimum cost to repair/replace is around $300.00
Jul 26, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore side by side refrigerator Ice maker not working
Found out we still had a warranty/service contract on it. Contacted SEARs and I explained problem to technician. Scheduled house call is Friday.
Apr 14, 2009 | Kenmore Refrigerators
Ice maker and water dispenser not working
well there is two things it could be low water pressure or ur ice maker is defective try replaceing the ice maker this should work if not u need to get a frig repair man out to help u because if the problem is in the frezzer door it is not easy to fix on ur own
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
The ice maker stopped working on my Kenmore Mod 106.55532400
either your water valve is clogged or it has gone bad, located bottom right corner, you can take it apart and check the screen filter if it is not clogged than you need a new valve approx 72-80$ plus install unless you diy!
Nov 29, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Kenmore 53642 / 53644 Side by Side Refrigerator Logo
187 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
