Question about Proform GT 85 x Upright Bike at GNC
Proform 10.8 the console on my proform 10.8x does not work. I bought new batteries and it still did not work. I put a piece of tin foil in between the battery and the battery cover and it flickered for a few minutes. now its totally dead any ideas.
maxtreadmill
  • 832 Answers
SOURCE: After replacing batteries on Proform PF800 console stays lit
Pull the batteries out let it reset itself while its doing that check all cable to make the connection are seated firmly then reinstall the batteries, unless the function pad is sending a phantom signal engaging the display to be on continuously,or by pure chance the upper electronics went hay wire
Posted on Apr 11, 2010
Testimonial: "Thank you very much for your advice! Very helpful!!"
maxtreadmill
  • 832 Answers
SOURCE: proform treadmill zt 5 runs but display is dead
If what you say is that all functions are working (start, speed up , down and incline up,down) then the upper console lighting may have loose wire harness( check first) bad soldier connection or the components that generate the images on the LCD are defective. If you have good connections on the wire harness then you may need to replace the upper console.
Posted on May 22, 2010
ercupa190
  • 12223 Answers
SOURCE: Hi I have a proform 750 cs and after about 10
CompartirFacebookTwitterGoogle+DeliciousDiggGoogle BookmarksMySpaceStumbleUponRedditMessengerVodpodYahoo BookmarksBeboMister-WongWordPressGoogle ReaderOrkutXINGEvernoteNetvibes ShareStrandsPosterousBusiness ExchangeArtoTipdSmakNewsPlurkAIMYahoo MessengerIdenti.caMozillacaBlogger PostTypePad PostBox.netNetlogTechnorati FavoritesCiteULikeJumptagsHemidemiFunPInstapaperPhoneFavsXerpiNetvouzWinkDiigoBibSonomyBlogMarksTailrankStartAidKledyKhabbrMeneameYoolinkBookmarks.frTechnotizieNewsVineMultiplyFriendFeedPlaxo PulsePingSquidooProtopage BookmarksBlinklistFavesYiGGWebnewsSegnaloPushaYouMobSlashdotFarkAllvoicesJamespotImera BrazilTwiddlaLinkaGoGounalogHuggDiglogNowPublicTumblrLiveJournalCurrentHelloTxtSpurlYampleOneviewLinkatopiaSimpyLinkedInBuddyMarksAsk.com MyStuffViadeoMapleWistsConnoteaBackflipMyLinkVaultSiteJotSphinnDZoneCare2 NewsHyvesSphere***** BrowserGabbrSymbaloo FeedsTagzaFolkdNewsTrustAmazon Wish ListPrintFriendlyRead It LaterTuentiEmailRediff MyPageGoogle GmailYahoo MailHotmailAOL MailAny email By Lockerz 1)is probably a faulty speed sensor adjust face to face with magnet to the motor 2) the speed sensor is not plugged in properly. 3) also possibly a faulty motor measure 115 vac without load 4) motor control board or lower board, measure for 115 vca for input and +5 Vdc for output .6) Test the transformer por input voltage and secondary voltage 7) Test the pwer supply forund +5 Vdc. The error codes will differ between makes and models but could be e1.
http://www.fixya.com/support/r10786838-test_procedure_dc_motor
Read this tips and the next onww.
http://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitness
Sincerely. Happy New Year. G-d bless you
ernesto cuadra
managua, nicaragua
Posted on Dec 26, 2011
ercupa190
  • 12223 Answers
SOURCE: new console on proform 580 doesn't work right
Dear Sir:
Please 1)adjust the reed switch see the diagram below 2) Change the baterries by new ones 3) Tigh the flexible cable from keypad 4) Tigh the connector from display board vs lower board.
Run inmediately after you did the step before software calibration for easy diagnose and troubleshooting.
If you can nor RUN your software calibration please see my personal TIPS, for easy diagnose and Trouble.
sincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 29, 2012
jbiggs8150
  • 14 Answers
SOURCE: proform xp 70 stationary bike console is not getting power
IF BATTERIES ARE NEW THEN CHECK THE CABLE AND CONNECTION FROM BATTERIES TO THE CONSOLE.MAKE SURE ALL CONNECTION ARE TIGHT AND CABLES ARE NOT BROKEN,FRAYED,CRACKED,OR CORRODED LOOKING.ALSO MAKE SURE SAFETY DEVICES(KEYS,PINS,CLIPS) ARE IN PLACE .
Posted on Oct 13, 2012
The remote control is no longer working - how do you change batteries?
Remove the back cover from the remote, note how the current batteries are oriented, carefully remove the batteries and check the terminals for corrosion. Corrosion can easily be removed with a small piece of tin foil or the blade of a knife. Once the terminals are clean and the batteries are out, replace with batteries of the same type. Close the back cover and test the remote.
May 04, 2011 | Televison & Video
Tip
Turn AAA batteries into AA batteries in emergancy
all you need to do is roll up some tin foil into a flat circular shape the size of the battery that you need,circomfrence,not the actual size of the battery,put it against the spring on what ever gadget you need the batteries 4,then push the little AAA battery on the tin foil so it fits tight into the slot where the AA bigger battery should be and WALLA, sorted.your gadget should now work,and its the same principle with all batterys.
on Oct 01, 2010 | Toys
It didnot start ,you hear it warm up but there is no light or dose not work
The problem is with the formatter board, it is a cold solder joint/connection. What you need to do is remove said board, unsolder the battery that is on the board...now hold on for this one, you have to put in in your oven @ 380 degrees for about 8 - 10 minutes face down on a cookie sheet on a piece of tin foil. Believe it or not it worked for me and i have also fixed several HP LJ2015's the same way. Good luck
Dec 29, 2010 | HP Laserjet M2727nf Multifunction Printer
My Xbox froze then it displayed three red ring around the green power indicator.
ur EX-box to be could be really broken or an easy fix try turning on ur xbox with two q-tips in the holes were the fan is and stopp both fans untill u overheat ur xbox till the three lights turn to 2 light on the left had side the wait 1 min if that the unplugg and let it cool down to room temp the boot it bak up
if that dont work try opening ur xbox and take off the two metal heatsinks inside and use some isophyrol (bad spellin ) clean all that gunk off untill its like a mirror then buy some artic silver thermal paste stuff and put a grain of rice sive squirt on it and spead it over the mirror parts of chips under heatsink put it all back together try again boot it still.... nothing...try removing xclamp and replacing them with bolts
okay try this try takin every single thing off the board dvd , fans, heatsinks ,hardrive just so ur left with ur board now go preheat oven to 230 uk 475 usa and now get some tin foil and cover all the capacitators with the tin foil ther the black lookin battery things and cover any plastic parts aswell now put on bakin tray FLAT and cook for 10 mins this is in my opinion lat hope
Nov 26, 2010 | Microsoft Xbox 360 Console
My remote doesn't seem to be working to my Naxa TV. I have put in new batteries. The TV comes on with the "green" light in front. But when I click remote "pOWER" nothing happens ??? Thanks
If you replaced the batteries and can turn on the TV manually, then the button is probably not making proper contact with the remote. Try opening up the remote and placing a small piece of tin foil where the power button is, close the remote up and it should work.
Aug 03, 2009 | Televison & Video
My xbox360 (wireless) controller keeps turning off if a lil shake is applied to it. (brand new batteries in it) it just keeps turning off and its not just one, it both of mines!
Take the battery pack off, there are two coiled springs that touch the batteries.
Stretch these springs up slightly, but not too much.
Then replace the battery pack.
Jul 15, 2009 | Microsoft Xbox 360 Controller
My olympus fe-330 will not turn on
was just having the same problem the camera would not turn on... NOTHING....  battery fully charged was messing around with it opened battery door pushed in on battery while trying to turn on and it came on, guessing battery was not making complete contact added a piece of foil in door to push down on battery when door shut now working fine
Jun 17, 2009 | Olympus FE-330 Digital Camera
Sharper Image iTower remote not working
I put a small piece of tin foil on the negative side of the battery and the remote worked again.
Mar 28, 2009 | Electronics - Others
Yes, we were a couple of dummys when we received our brand new LG stove, with convection oven,glass top and very fancy, and we put tin foil to cover the bottom of the stove and of course yesterday when I...
I really don't know what to tell you. During the clean cycyle the metal probably melted and is permantly sealed to the bottom. You are lucky the oven still works. Sometimes using foil will destroy sensors or other things. NEVER use foil in ANY oven!!!!! The only exception is to partially cover the shelf underneath something you know is going to make a mess. Even then don't cover more than about 60% of the rack.(Never do this in a convection oven as the fan will blow the foil ) Also NEVER!!! allow foil to come in contact with a hot burner. It will melt to the smooth top or coil.
Jul 07, 2008 | LG Kitchen Ranges
Melted Tin Foil in bottom of oven
Unfortunately, it's too late. The tin foil has melted into the panel and can't be removed. The melted foil will not affect oven operation. You should never place anything on the bottom of a stove that has a hidden element. You will damage the panel. The only option you have is to replace the panel (if replaceable) or the entire oven liner...
Jun 05, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Proform GT 85 x Upright Bike at GNC Logo
62 people viewed this question
Top Proform Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Proform Cycling Expert? Answer questions, earn points and help others
