Question about Sewing Machines
Brother entrepreneur pro 1000 reset thread tensions to factory defaults
I changed all upper thread tensions and don't know how to get them back to the factory defaults . Don't ask what possessed me to do that but I did. Now I am having a very bad time trying to get my tension back to normal. I have tried adjusting many times and embroidered the thread tension design but cannot get it back to normal. Is there a factory default setting somewhere I can reset to and adjust where and when from there?
    Top Expert:
  • Sewing Machines Master
  • 50,566 Answers
Try ignoring the factor default tension setting and try the simple method of pulling the thread through the tension plates
just before threading the needle, pull on the thread and there should be a resistance to pulling the thread
now adjust the tension up or down to get the two threads to meet at the center of the materials
Posted on Jun 29, 2017
  • 323 Answers
SOURCE: Just starting yesterday(I haev had
Remove the bobbin and reinsert it so that it turns counter clockwise when you pull on the thread.
sewman7
Posted on Jul 17, 2008
  • 9 Answers
SOURCE: Thread breaks when embroidering
Try changing threads. If you're not using embroidery thread specifically, the "treatments" they use on different threads can really cause problems.
Posted on Feb 21, 2009
SOURCE: I have a brother SE 270-d. my only problem is that
Try making the material tighter in the hoop and check your bobbin to be sure it's a L (look at your instruction manual...it will show you which bobbin works and which does not. I say this because you have a tension problem...dont we all, Ha Ha!
Posted on Jun 23, 2009
  • 201 Answers
SOURCE: can not adjust the upper thread tension tight
If you are adjusting the upper tension on your machine and yet there is no difference to the sewing, it seems to me that maybe your upper thread is not in the tension disks correctly. Re-thread taking care to make sure the threads bed down into the tension disks. I pull off about 2 foot of thread from the spool and put my right-hand finger on the thread very close to the spool (the idea is to hold it down so it doesn't move) then use my left hand to take the thread through the thread run. Once I get close to the needle, I tug the thread a little and you can hear/feel it go into the tension disk.
Sometimes it looks like the top thread is the problem, but in fact it is the bobbin which is at fault. Re-insert your bobbin again taking care to click it into its tension slot. If you are still getting bad results, try loosening off the bobbin tension. Use a tiny screwdriver to turn the tension screw (the one just on the outside of the tension slot). Turn it no more than 1/5th of a circle at a time (to the right to tighten, to the left to loosen) then put bobbin back in and test. You should not need to adjust it more than two or at most three times. If you do, something is seriously wrong with your machine's tensions and it needs to see the Sewing Machine Doctor.
Posted on Jun 15, 2010
vetteman3002
  • 2299 Answers
SOURCE: I have a Janome MC11000,
Try a different stitching. Then if it works with a different stitch, then switch back to the stitch that you were using.
Posted on Nov 01, 2010
Why is my Brother SQ9185 Sewing Machine thread bunching up on the back side of the fabric?
That is called thread nesting or bird nesting. Usually it is because it is threaded incorrectly (sometimes the thread jumps out of a thread guide or the take-up lever), the upper thread is not seated in the tension disk, or the upper tension is incorrect.
First thing, install a brand new needle.
Second, remove the upper thread, RAISE the presser foot and rethread from the beginning--make sure the correct thread path is followed.
Third, check that the upper tension is set at the midway point between high & low number.
Test. Adjust the upper tension as needed. Re-test. Tension is correct when the upper and bobbin threads meet in the middle of the fabric.
need elp with tension on singer cg550
Apr 07, 2016 | Brother Sewing Machines
I don't have a manual what are the tension for this machine
Difficult to address without knowing the make & model.
However, generally speaking, the standard factory setting for the upper tension is the midway point between the high & low numbers.
Bobbin tension is set at the factory and is tricky to reset by a novice. For the most part, it is recommended that the tension skrew setting on the bobbin case be marked with a permanent marker before any changes are made. That gives a reference point so that if it needs to be returned to the original setting, it is easier to do so. Make only 1/8 turns at a time and retest.
The correct tension is when the upper and bobbin threads meet in the middle of the fabric.
Keep in mind that the needle, thread, and fabric all impact tension. Before beginning a new project, test the tension first on a scrap of the fabric and get it set where you want it before sewing the project. That being said, tension (mostly upper thread) is static so it is important to get familiar with adjusting it to fit your project. One tension setting will usually not work for every project.
Apr 01, 2016 | Sewing Machines
How do you adjust the bobbin tension?
Factory standard tension for upper thread is the midway point between the high and low number. However, that tension dial is meant to be used for tweaking tension. Generally, tweaking is required whenever the type of fabric, needle, or thread are changed, ie thicker fabric like denim should have a different upper tension setting than fine chiffon. To be successful with tension settings, one must become comfortable adjusting the upper tension.
NOTE: Accurate tension is achieved when the upper thread and bobbin thread meet in the middle of the fabric.
Understanding Bobbin Tension
Jan 20, 2016 | Brother Sewing Machine - XL2600i
How do you adjust or set the tensions
Make sure you raise the presser foot BEFORE threading the upper thread so it will seat properly in the tension disk.
The factory standard tension setting is the halfway point between the low & high numbers. Be sure you are using needle & thread that are compatible with each other and the fabric you are sewing.
All About Needles
Test your stitch on the fabric you are sewing. If the upper thread is showing on the bottom of the fabric, the upper tension is too loose. If the bobbin thread is showing on the top of the fabric, the upper tension is too tight.
Ideal tension is when both upper and bobbin threads meet in the middle of the fabric. The tension will need adjusting anytime you change fabric weight, needle size, and thread weight.
Dec 16, 2015 | Sewing Machines
Needle goes down but don't pick up the bobbin thread. It come up and tell me that my upper or lower thread is cut.
try changing the needle
try rethreading the machine top and bobbin
make sure to use every thread guide-this is improtant for the
thread tension
make sure the bobbin is turned correctly in the bobbin case
also could be a problem with the computer motherboard
or there could be a problem with the timing
Dec 03, 2012 | Brother PE-150V Computerized Sewing...
Brother XL-2600i upper tension too tight even when set to ZERO
I agree with you to take it back & buy another brand
Sep 30, 2012 | Brother XL-2600
Top thread don't look right when i pull it it comes out
try rethread the top thread
use the right thread & needle for the fabric
adjust the top thread tension just a little forward, if that doesn't help
(write down where the top tension was before you moved it)
if adjusting the top thread tension doesn't help put the tension back
where it was
clean under the needle plate & in the bobbin are for lint
here is a link for a free manual
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_CS_6000i_EN_2889.pdf
it's also possible that the machine could be slightly out of time
& it needs to be checked
Sep 07, 2012 | Brother CS6000i Computerized Sewing...
I can't seem to find the correct bobbin tension for any projects.
Hello
What did you do differently to gather? Did you change the upper or bobbin tension? If you changed the upper tension, set it back to 4. If you changed the bobbin tension (don't!), set the upper tension to 4 and fiddle with the bobbin tension screw (1/8 of a turn at a time, no more!) until you've got balanced tensions again.
Cure is usually take ALL the thread off of/out of the machine, give it a good cleaning (vacuum and brush only, no compressed air), oil if it is required, a new needle right way around, and then carefully rethread, following each step in the manual, and making sure you thread the top with the presser foot raised (which opens the upper tension and allows the thread to enter it.) Don't forget to put the presser foot down to sew, and hold on to the thread ends for the first couple of stitches in a seam.
Jul 11, 2011 | Sewing Machines
I have a Brother sewing machine and whenever I try to pick up the bottom thread (or when I try to sew), the upper thread gets caught around the bobbin case causing a huge, knotted mess. It's just all...
Check your top tension dial setting is on 5, as this sounds like the thread is not in tension fully so is looping up around the rotary hook and not being held back by the tension device. Is the pressure foot lowered (this turns the tension on) fully and is the thread through the tension discs correctly. Lower the pressure foot and pull the top thread from below the tension dial, it should feel firm to pull, if it comes out easy, its not undertension, device could be faulty and machine will need to be serviced.
Also, check that the bobbin case is fully inserted into the rotary hook in the correct position, bobbin is in and rotating the right way and thread is into the tension spring fully.
If you have the manual pull it out, and carefully check the threading up instructions and follow on your machine - it is probably one of these things causing the jamming.
May 23, 2011 | Brother LS-2125 Mechanical Sewing Machine
Brother innovis qc 1000 machine. The upper thread is breaking and getting greasy. I have tried rethreading, changing the needle and rewinding the bobbin. Help?
Also check your tension. I'm assuming you've recently oiled your machine, and that's why the thread is getting greasy. You'll need to get in all the areas the thread runs thru with a thin bit of cloth to absorb the excess oil, too. You probably inadvertently changed the tension settings while you were oiling the machine. Check the tension and adjust it-see if that solves your problem.
Good luck! Hope that helps!
May 12, 2011 | Sewing Machines
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
