Question about GE Microwave Ovens
Ge mircowave message is P F
I have GE mircowave oven model # JES737WM02, mircowave only showing message " P F " in lcd screen when i plug in . no another function. what was happening to it? and how to repair it? thanks!!
  • GE Master
  • 9,098 Answers
"PF" means that the power has been interrupted, so you need to set the clock, then the oven should work.
If you actually do have a problem with this oven, it will have to be replaced, since GE does not make repair parts available for it.
Posted on Jan 17, 2013
bestdarngood
  • 3037 Answers
SOURCE: run but does not heats
Sounds like the magnetron has failed. This is the component that produces the microwaves that heats the food. The cost of the magnetron is about 95% of the cost of a microwave oven. Most people don't, for this reason, replace the magnetron, they replace the whole oven which is probably what you will end up doing. There is a possibility that the circuit that provides power to the magnetron is faulty and you need to take it apart, find the proper electrical leads and test them with a volt meter. To do this you have to remove it from its mounting and take it apart. It is a fairly lengthy process however. Benjamin
Posted on Jun 07, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: GE Profile Advantium 120 Oven not working; less than year old!!
No need to scan now...
We got the service manual for this model and have uploaded it to our site here to help you.
You will need the
free Acrobat Reader to view or print it in case you don't have it.
I'm suspecting the keypad or a door switch or switch mount issue.
Also, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 26, 2008
  • 87 Answers
SOURCE: GE Microwave Oven Installation
If the top of it butts aginst your cabinets you will have to take the bolts from the inside of your cabinets around the front area that that are holding it up out (use 2 people) once they are out it "should" still hang there, next step slowly lift it an inch or so (then you will be no longer on the back suppot) again use 2 people, then you can pull straight out. hope this is what you are looking for.
Posted on Oct 03, 2009
SOURCE: how to change the bulb in a jes1288sh02 ge microwave oven
I have a GE jes1288sh02 microwave and as many know the owners manuel didn,t help you when it came to parts or fixing things on the microwave.It took me a day finding parts for this model .I finally did and what it was was my light went out and i needed aa inside wave guide basically a cover. One thing i found was the 4 screws u have to take out to get the cover off are A star shape T20 however it has a small post in the middle luckly the screws was loosen enough I used Pliers to turn them! I went to the hardware and changed them to Philips .Another thing I found was the part lists in an envelope glued inside on top of the micro wave with all the parts wish i knew that sooner lol.Finally the Light bulb simple to replace a snap lol.Hope this helps someone else its a same You can,t get Help About something without a price .
Posted on Jan 13, 2010
  • 149 Answers
SOURCE: How to replace the bulb in our GE Microwave Oven,
the outter cover wrapes around unit remove screws, be careful high voltage is present even with power off just replace bulb reassemble
Posted on Jan 14, 2010
Why is my GE mircowave starting by its self ?You do not even have to in the same room and it just starts running.
The touch pad could be giong bad and closing the contact by itself. A new touch pad should fix this.
Aug 18, 2014 | GE Hotpoint RVM1535 Microwave Oven
Mircowave wont heat food
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101 ,;
Aug 25, 2011 | GE Monogram ZE2160SF Convection /...
JNM1851SM1SS - MIRCOWAVE makes a load noise when you try to cook sounds like a deep arcing sound...
heatman101
May 04, 2011 | GE JNM1851SMSS Convection/Microwave Oven
GE spacemaker mircowave not heating- all else works ok
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Feb 11, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE microwave model# jes737wm02 manufactured inFeb. 2009 it runs but won't cook
we purchased a ge microwave about 2 yrs ago & the paint is peeling on the inside. Is this dangerous & should we continue to use it?
Oct 28, 2010 | GE JES738 Microwave Oven
The controls along with the clock and timer works on the mircowave. The problem is that the food does not cook or heat up.
probably a defective magnetron; very common for this vintage microwave. there are usually generic magnetrons available; as the original GE part will be expensive.
Aug 25, 2010 | GE JVM1650 1000 Watts Microwave Oven
Mircowave runs but doesn't heat and it has a load hum.
You may need a new microwave..however, the diode may be defective or the magnatron tube may need replacing,,The magnatron tube is only warranted for 5 years so it may be used up as the model is (10years)fairly old.
Jun 18, 2010 | General Electric Microwave Oven
F3 Error Message
the code means this.
F3 Shorted touch pad panel
Good Luck
Dec 29, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
572 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
vince
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
