Question about Kelty Acadia 4 3-Season Camping Tent
Can't get pole into the fly tabs
I am afraid to bend the pole and the fly material really seems tight
    Novelist:
  • 180 Answers
Get tough.. Your assembled pole will bend.. and it will bend a lot, as long as it isn't kinked in one spot. You can do it...
Posted on Jan 16, 2013
I need instructions for 89034 17x15 moab
Instructions
  1. Select a flat camping area and clean the area of sticks and rocks. Remove the tent from the bag and spread out the tent body with the floor on the ground. Assemble the tent poles by connecting the attached sections at the ferrules. Set the poles on the ground and separate by size.
  2. Locate the three long sleeves on the tent body. One sleeve is horizontal over the screen room and the other two cross the main tent body to create an "X". Locate the three long poles and slide one through each sleeve. Place the corresponding pins in the end of the poles. The poles will flex and erect the tent body. This step is best attempted with two or more people.
  3. Attach the clips to the exposed sections of the tent poles. The clips are attached to the ten fabric and will add rigidity to the tent. Locate the next largest pole and insert it through the sleeve on the screen house. Locate the metal grommets where the screen room meets the main tent and place each end of the pole in a grommet.
  4. Locate the two smallest poles. These are for the side rooms. Insert one pole through each of the side room sleeves. Attach the ferrule of one steel pole to each end of the side room pole. Insert the corresponding pins in the end of the upright poles to support the side rooms.
  5. Pull on each end of the tent to ensure the floor is tight. Use a rock to pound stakes through the ground loops on the tent. Place the floor mat in front of the screen room door and use stakes to secure the mat to the ground.
  6. Place the fly on the tent and make adjustments until the shape of the fly matches the tent. The fly will only cover the top of the screen room and the entire body of the main tent. Locate the D-rings on the base of the tent and attach the fly hooks to the closest rings. This will tighten the fly to the tent body.
  7. Locate the guy ropes on the fly. Pull the ropes to the ground at an angle and pound stakes through the loops to anchor the tent to the ground.
Read more : http://www.ehow.com/how_8092535_directions-ridgeway-tent-kelty.html
Jul 23, 2015 | Baby Gear
How do I assembly the tent
Step 1 Remove the tent, poles, stakes and tent rope of the dome tent from the Northwest Territory sack. Locate a large flat area and remove any sticks and rocks from the ground. Step 2 Lay the tent fabric on the ground with the bathtub style floor face down. Pull the corners of the fabric tight and rotate the tent so the door is facing in the direction you want. Use a hammer to stake the corners in the ground. Step 3 Assemble the two long poles to their full length. The pole segments are connected by chords and will easily snap into place. Slide one pole through the diagonal sleeve on the top of the tent. Slide the other pole through the other diagonal sleeve to form an "X" with the poles. Step 4 Place the end of each pole in the corresponding grommet. The poles will bend and the shelter will be erected. Step 5 Assemble the two small poles. Slide one pole in the doorway sleeve and the other in the back window sleeve. The poles will bend slightly to create a rain peak on the door and window. Step 6 Pull the doormat tight and pound stakes through the loops on each corner. Pull the tent rope tight on the back of the tent and pound a stake through the rope loop to anchor the tent to the ground.
May 31, 2015 | Northwest Territory Sierra Dome Backpack...
My helicopters tail bends down just a little, starting just past where the support beams and tail connect.
I have added a quarter to the tip of my dh9118 and slid the battery a bit forward to give it a center like balnce
Mar 01, 2014 | Protocol Predator SB 3.5-Channel...
10000 janome jamming fly wheel won't turn
I would replace the needle anyway. It's hard to tell if one is bent or not.
Remove your feed dog/needle plate and the bobbin cover. Take out your bobbin and bobbin carrier.
Get out a magnifying glass and really examine. Look for thread ends in between moving parts.
Also check the thread pathways. Especially where the take up lever is hidden. I've heard of some ladies finding threads snarled up in that area which caused problems like this.
Good luck. If all else fails take it in for repair.
Nov 04, 2012 | Janome Sewing Machines
LG Refrigerator not cooling
Call a technician because either a board was burnt out or the compressor or the start device for the compressor took an excessive load and is shot.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jason_4570d45317834dd3
Sep 06, 2012 | LG LFC25760ST 25 Cu. Ft. Panorama French...
No instructions giving to erect our tent 6 man regatta hyperdome model no 927/5887
I bought one of these yeaterday. The instructions - for what they are worth are sewn inside the carry bag. So I decided to put it up today. Not as easy as i would have thought, but then this is my first tent of this size. ( saw a nice Outwell Montana 4 in Millets for 225.00 which would have been my tent of choice). But at half price in Argos I couldn't argue that one.
So to put it up.....
lay out the fly sheet in the approximate final position. put poles in as per instructions ..blue to back red to middle and blue to front.. across the tent. ( the pole guides are all colour coded.) Make sure poles are in pins at the base of fly sheet (bending gently to attach). these are attached by the black elastic straps.put in porch pole, put in front to back poles left and right.
Anchor back of tent temporarily with pegs. Lift from porch forward to lift tent. Temporarily peg base of poles, straighten out so that the straps inside tent are approximately perpendicular to each other. Move poles to tension flysheet and tighten anchor points on flysheet using straps buckles to pull flysheet down as far as possible ( to help prevent draughts)., anchor guy lines when happy with final position.
Put up inside ground sheet and attach to points on inside of flysheet. put up rooms starting with the rear yellow hook and work around to front red hook.
These instructions were not specifically provided but this was our first try and probably could be improved on. It requires 2 people for speed if nothing else.
Enjoy
Jul 31, 2011 | Sport & Outdoor - Others
I've just bought a Pfaff 1471 and it has "locked-up"... the needle won't go up and down and the hand-wheel won't move. Help please! :)
Do you have a bunch of material and thread stuck in the feed dog? Sounds like. This will sometimes happen. I'm afraid the only thing you can do is carefully work with a seam ripper or small scissors to get it all out. Be careful working. You will damage this part of your fabric, but you can take the seam allowance in a small bit. You will probably have to remove fabric & thread from underneath, through the bobbin area, too.
Once you have all of this cleared, the needle and wheel will turn. I suggest you try and take the needle out of the shaft and try pulling it out of the fabric before you start your work, too. That way, you won't risk breaking it and have a piece fly off at you.
It's frustrating and will probably make you curse at the machine-it's happened to everyone who sews at one time or another, and will happen again, I'm afraid.
May 10, 2011 | PfaFF Sewing Machines
I purchased the toy story bed tent for my daughter and misplaced the instructions on how to put it together so if you could provide me with this I would really appreciate it
there are four pockets on the inside of the tent which hold the ends of the pole with the string in them. connect all the poles with the string in them. bend it in a (n) shape and stick the ends in the pockets. the poles are bent so as to give the tent height not depth, do the same for the rear of the tent. the twelve other poles are connected using the small connectors. one connector for two poles then stick those poles into the front and rear (n) shaped poles in the empty connector spaces already on the pole you bent. remember when you bend the pole they will not stay bent until you stick them into the inside pockets in the tent. the nylon straps at the bottom of the tent help the tent to hold on to the mattress. its simple enjoy. i put all the poles together first and then had my helper to hold it in a (n) shape until i could stick the legs into the pockets. look inside the tent once together you will see where you need to tie the nylon straps to the poles
Jan 08, 2011 | Disney Toy Story Indoor Bed Tent With Push...
Swiss Gear Tent - Broken Poles SG33071F
Take a look on amazon for replacement. here: Amazon com tent poles. I hope this was helpful. Cheers
Aug 24, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
I need new poles for Swiss Gear tent # SG33071F
Go to Home depot and buy a tube that fit the pole. Cut it into 5 or 6 inches for the broken areas. It costs me less than 2 dollars. Let me know how it turn out on yours.
Jul 25, 2009 | Wenzel Swiss Gear Grand Lodge Cabin Dome...
Kelty Acadia 4 3-Season Camping Tent Logo
272 people viewed this question
Top Kelty Rock & Ice Climbing Experts
Makenzie Floyd
Level 1 Expert
ray gallant
Betty L Kidd
Betty L Kidd
Are you a Kelty Rock and Ice Climbing Expert? Answer questions, earn points and help others
