Question about Dynex 20" Digital TV
How do i Connect RCA VCR to Dynex 20" 480i tv
Color codes from vcr to tv do not match
    Problem Solver:
  • 5 Answers
Out puts from vcr to inputs on tv. video out to video in. audio out to audio in.
Posted on Jan 24, 2009
    Genius:
  • 1,199 Answers
Ok yellow is always the video signel! and if you have a stereo vcr there should be yellow/red/white the red/ white are audio left and right! if your vcr is in mono then there will only be a yellow/white just use them and let the other red one hang free because it is not needed...if there are other color codes on your model just remember yellow is always the video(picture) the other are for sound and it does not matter where you plug them in at! If you have a black wire just use it in any audio input (red/white)
I hpoes this helps! if you need more help come see us
please rate answer!
How do we hook up VCR to TV
  1. 1
    Turn off all of your components. This will help prevent any accidental damage while connecting.
  2. 2
    Connect the RF/COAX Out port on the VCR to the RF/COAX/ANT In port on your TV. Use a coaxial cable.
  3. 3
    Connect your antenna to the the RF/ANT In port on the back of your VCR (optional). This will allow you to watch over-the-air broadcasts through the VCR.
  4. 4
    Turn on the VCR.
    • Make sure that the VCR is plugged into the power outlet.
  5. 5
    Set the VCR channel to Channel 3 or 4.
  6. 6
    Turn on your television to the same channel that your VCR is set to.
  7. 7
    Start playing your tape.
or check this site:
How to Hook Up VCR to TV
May 19, 2016 | Televison & Video
Need to know step by step instructions 0n how to record from my tv to my vcr including plug ins
I am assuming you wish to record what is playing on your TV to the VCR and not just asking how to record on a VCR, which is much easier, just put your cable from your antenna/cable box on the vcr and pick a channel from antenna or use channel 3 or 4 for cable box and press record. To watch TV with or without recording connect VCR output (Either coax or Composite) to same type input on the TV. If this is your question, then comment if you have trouble and I will get more detailed. This is a good video on doing this: https://www.youtube.com/watch?v=zgb7uoLIaQE
So if you want to record what is playing on your TV to the VCR, you must have a TV OUT on the TV. The only types of TV OUT that I have seen that would match to a VCR are either coax or RCA.
If the TV OUT is coax just connect one end of coax cable to the TV OUT on the TV and connect the other end to the Antenna/Cable IN on the VCR. Play the program on the TV and record on the VCR usually on either channel 3 or 4. Unless you have the VCR set up to play on another TV you will just have to use trial and error (record on one channel and playback on TV to see if you recorded anything, is so that is right channel, if not, then try the other one.) to find out which.
So, on to recording the signal from a TV on a VCR. If the TV OUT is Composite (RCA jacks, yellow, red, and white or black) you will need some RCA (Composite) cables. They may be labeled patch cords or dubbing cables at the store. That is if you can find them. I don't know if they are still being sold as a video accessory. If not just use RCA audio cords.
There will be two plugs on each end for mono sound recording and three for stereo sound recording. You will have to have audio or L & R audio, and video OUT on your TV and audio or L & R audio, and video IN on your VCR. Plug the yellow cable end into the video OUT on your TV and the yellow on the other end into the video IN on your VCR. Do the same for audio. I have always seen yellow as the color for video, but audio is sometimes white and sometimes black, and in stereo audio right is usually red, but left can be either white or black. With a little luck the cable plugs and TV and VCR IN & OUT jacks will match in color. If sound is mono the is nothing to get wrong. If audio is stereo the worst that can happen is the sound for right side will play on the left and sound for the left side will play on the right. As long as red is used for right it should be correct.
If there is only one set of input jacks on the VCR, the VCR input will probably need to be set to 'Line In'. If there are multiple sets of input jacks they should be labeled 'Input 1', 'Input 2', etc.. The VCR input setting will need to be set to the input you plugged the RCA cables into. The jacks you plugged cable ends into should be labeled. The setting for input on the VCR and TV should match the label on that device.
Now turn on the TV and put it on what you want to record. Do this before it comes on if you want to record all of it. Having set the VCR on 'Line In' or on the correct input, just press record on the VCR. Leave the TV on while recording.
As long as the TV is on and going to play something you want to record, you can set the timer on the VCR to record it, but instead of setting a channel you will choose either 'Line In' or the input number you are using.
This should always work to record a show on the TV when the signal is coming in through a coax cable from an antenna or cable box. But there are some TVs that only send that signal to the TV Out jacks. So if you are watching something from another source, like another VCR, a DVD player, or a video camera on TV on the TV and try to record that you will only record the incoming signal from the antenna or cable box.
In that case just connect the other VCR, the DVD or the camera to the recording VCR and play it on the one using the OUT jacks and record on the VCR using the Input jacks. This should make a better recording too. You can see what is happening by using the OUT jacks on the VCR and connecting the cable from them to the IN jacks on the TV and selecting the 'Line In' or 'Input 1, 2 etc.' matching where you plugged the cable from the VCR in on the TV.
Summary:
Device playing what you want to record is the: SOURCE
1. Using RCA dubbing cables plug them into the OUT jacks on the source and the IN jacks on the VCR.
2. Set the VCR input to the setting that matches the label on the jacks in which the RCA cables are plugged.
3. Play the program on the source and press record on the VCR to begin to record it.
Note: Leave the TV on if that is the source.
If you have any questions I assume I will get a notification if you leave a comment and I will be happy to answer.
Hope this helps. Good Luck!,
Ron
Jan 24, 2015 | Samsung Televison & Video
Connect a Wii to VCR
Hello
Take the Wii's audio/video cable and the power cord and hook them up in the back of the Wii.
Take the Wii's audio/video cable and plug it into the 'audio-in and video-in sockets on your VCR.Make sure you match the cable colors with the input colors.i.e white goes with white,yellow with yellow and red with red.
Take the RCA cable which looks like the picture below,
and plug one end of this audio/video cable into the 'audio out' and 'video out' ports on the VCR.Make sure the cable and ports colors match.
Now take the other end of the RCA cable and plug into the 'audio in' and 'video in' ports on your TV.Again make sure you match the color connections.
Hope it helps.
Ken
Jan 22, 2012 | Nintendo Wii Console
Mitsubishi HS-U540 VHS VCR How do you connect the red, white, and yellow cables?
The RED is Right Speaker the WHITE is Left Speaker and the YELLOW is for
Video. They connect with RCA Cables to the same color coded inputs on yout TV.
You may find it easlier to just use a CoAxial Cable; Use a CoAxial for the CABLE IN to the Cable Box then 1 CoAxial from the Cable Box OUT to the VCR IN then use 1 OUT from VCR to TV IN. That is much easlier then using RCA Cables.
Aug 14, 2010 | Mitsubishi HS-U540 VHS VCR
Can't hook vcr to tv
on the back of your VCR there will be a yellow colored port - most likely labeled "OUT" as well as possibly a white/red pair of ports.
The yellow is for a VIDEO hookup, the white and red are for AUDIO hookups.
These ports use what is called an RCA type connection.
Radio Shack, or just about any department store should be able to sell you an inexpensive set of RCA cables.
now on the back of the TV (possibly on the side) you will also have the yellow, white and red ports.
Hook one end of the RCA cable to the colored ports on the VCR, the other end of the cable to the colored ports on the TV.
last thing - the TV most likely has multiple inputs. there is probably a input button on the TVs remote, you need to press that button to cycle through the inputs until you get to the one the VCR is hooked up to.
its easiest to put a tape in the VCR and press play - when you get to the right input, you will see your tape...
good luck
Apr 05, 2010 | Dynex DX-L32-10A 32" LCD HDTV
How can I connect my tv to my vcr using rca connector ? My VCR is old and only records up to channel 44.
if your old vcr have a rca jack at the back, then you can easily connect your rca. remember color yellow means the video and red and white means audio left and right. but if there's no available jack then you have to connect it using RF connector directly connected to the antenna connector at the back of your tv. then you need to rescan your tv to get the exact channel for your vcr. good luck!
Aug 20, 2009 | JVC Televison & Video
Don't know how to connect my vcr to my tv
You can either plug RCA cables from the audio and video, audio is red and white for stereo or just one of them for mono, the video is yellow, from the "outputs" on the VCR to the matching colors on the tvs "inputs". You can also connect the antenna output on the VCR to the antenna input on the tv and put the tv on channel 3 or 4, if done this way connect the antenna/cable to the VCR antenna in and connect a cable from the antenna out to the tv.
May 27, 2009 | Televison & Video
Unable to separate VCR playback from Sat. Receiver input,both av2
try to find a multi-video selector swicth that the best you can do
Dec 19, 2008 | Dynex DXR24TV 24" TV
Ipod vido out
Using the iPod AV Cable
Step 11Use the Apple iPod AV cable. This plugs into the RCA ports on your TV or VCR. This is by far the easiest method. Step 22Connect the AV cable into your iPod. Plug the small end into the iPod where the earbuds would go. Step 33Connect the red RCA plug. This goes into the right audio input of the television or VCR. The colors should match. Step 44Connect the white RCA plug. This plugs into the left audio input of your TV. Connect the yellow RCA plug. This goes into the video input of your TV. Step 55Begin playing a video on the iPod.
May 27, 2008 | Apple iPod MA446LL/A MP3 Player
How do you connect the VCR Mitsubishi HS-U446 to record a TV show?
Usually the standard color coding for those connections are yellow, red and white. Yellow for video, red and white for audio left and right if it is stereo. Also pay attention on the the label of your vcr if it is input or output. You need need to connect it from output of your vcr to the input of your tv set. TV have also the same color coding. By the way the cable you use for this purpose is what we called RCA, which is also color coded. good luck!
Feb 26, 2007 | Mitsubishi HS-U446 VCR
Dynex 20" Digital TV Logo
424 people viewed this question
Top Dynex Televison & Video Experts
Jaime Hernandez
Are you a Dynex Televison and Video Expert? Answer questions, earn points and help others
