Question about Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator
I have a GE Profile refrigerator the does not produce ice cubes
We went on vacation a month ago and shut of the water main to our house while we were gone. Upon return, we turned on our water main supply and out GE profile refrigerator no longer produces ice cubes automatically. Did something freeze up in the ice maker unit while the water supply was shut off? How do I fix the problem?
  • 410 Answers
The fill tube that runs water into icemaker has most likely frozen up use a hair dryer and heat the tube up until the ice melts out then it should start up agian. you may have to remove the icemaker to gain full access to the fill tube. good luck peyton
Posted on Jan 24, 2009
How can I make my ge profile icemaker work better?
Sounds like you may need to change out you water filter or you have low water pressure or, you have a bad water valve on the refrigerator and that may be due to debris in your water.
Dec 31, 2017 | GE Refrigerators
Went on vacation and shut water off in house. Came back from vacation and frig. stop making ice. What do I do?
fill tube is probably clogged with ice you will have to melt the ice in the tube that goes thru the back wall to the ice maker, if you shut off the water turn off the im too
Feb 21, 2011 | Samsung RF265AA Bottom Freezer French Door...
GE Profile REfrigerator: Model PFSS6PKWASS Problem with loud clicking coming from icemaker every 2-3 seconds. Will do this for 30-60 minutes constatntly, then will stop clicking for the same period of...
i have same fridge with same prob makes 6 cubes of ice in a day with a lot of noise like you discribed also i have water collecting under crisper drawer of fridge i have to clean out water once a month or so still trying to figure out how to take ice maker out to fix
Jan 25, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Home from vacation--no ice.
Check the fill area of the ice maker for an ice blockage.
- make sure the tube on the back of the Ref. is connected to the white rectangled block of the fill tube.
- check to make sure the water filter in the bottom of the unit was not kicked and has popped out or is not seated / locked in place.
- Check to see if water is actually getting to the unit.. from the 1/4 inch supply line.
If your icemaker is the common one there here is a way to test it:
(I noted GE Profile but not an exact model number)
http://www.american-appliance.com/catalog/newsdesk_info.php?newsPath=12&newsdesk_id=34
Last question... does water in door work?
Thanks for using FixYa.
Kelly
Apr 03, 2010 | GE Profile 25.1 Cu. Ft. Side-by-Side...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE model GSH25JFTACC ice maker not working
When an ice maker is producing ice poorly--when it produces just a few cubes or none, or when the cubes are too small--it's usually because of a clogged water line or a defective water inlet valve.
First, check the water line attached to the back of the refrigerator for good water flow. To do that, first turn off the water supply valve. Then remove the water line from the back of the refrigerator. Next, place the water line into a bucket and momentarily turn the water valve back on to test the flow. If the flow is poor, you need to repair, clean, or replace the tubing or the shut-off valve that supplies the water. If the flow is good, you may have to replace the water inlet valve.
Mar 24, 2009 | GE 25.0 Cu. Ft. Side-by-Side Refrigerator...
I have a side by side GE profile Artica refridgerator. The Ice maker is producing, but I cannot get water to come out. When I push the water dispenser, I can hear something happening, but nothing comes...
One of two things. Water solonoid in back defective or water line insideof freezer door is froozen. I just posted a write up about this. Check other response. UJ63
Mar 01, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Ice cubes sticking together on ge modeltbx20tub
If the cubes appear to be shells, you have a restricted water supply to the refrigerator and will need to change the saddle valve where the 1/4" line connects to the house plumbing.
Dec 18, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Ice maker not working
check your owners manual for a water filter, make sure trip arm isn't stuck closed and not letting water in to freeze.
Dec 08, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 24.8 cu. ft. TRIO Bottom Freezer Refrigerator Logo
371 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
acrman404a
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
