Question about Jet 10" Xacta Saw Left Tilting Arbor Tablesaw 708661
JTAS-10XL-1 sudden onset of difficulty tilting saw
I was using saw today and had it tilted to 45 degrees. reversed tilt to verticle and when I tried to repeat 45 degree angle it was extremely difficult to rotate trunion wheel. Previously it would be difficult for first few degrees then was easy to tilt.
2 Suggested Answers
  • 384 Answers
SOURCE: jet 10
Adjust the stop screw under the saw top plate.
Posted on Sep 11, 2009
Degrees
The owner of Inline Industries (he invented the PALS product that lets you get a precision alignment on a contractor saw) has a video that shows how to add grease fittings that will make blade raising, lowering and tilting very easy. Check him out. He sent me the video when I bought the PALS.
Apr 28, 2013 | Craftsman 10" Table Saw
What is a compound miter saw?
A compound miter saw has a rotating vertical pivot allowing the cutter head & blade to be tilted (or beveled) sideways in addition to the horizontally rotating table. This allows vertical & horizontal angled cuts as well as cuts angled in both planes.
Jan 28, 2013 | Saws
10 inch lest tilt Unisaw will not tilt to complete verticle --only goes to 88.5.
There is an adjustment under the table top. It usually is a bolt with a lock nut that allows you to adjust the table to a predetermined angle every time. You can adjust the amount that the table will go by unlocking the lock nut and then turning the bolt the correct direction allowing the table to come to a full 90 degrees. Once you have the table a 90 degrees lock the bolt down with the lock nut. This will aloow you to change the tilt of the table to something other than 90 degrees and then come back to the 90 degrees by turning the adjusting wheel until it bottoms out against the locked doen adjusting bolt.
Mar 17, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I have a 1/16" tilt
Your question is not very clear. Here are several answers.
By tilt you may be speaking of bevel adjustment 0 - 45 Some saws have hidden under the table or obvious positive bevel stops or screws in the table top for 90 and 45 degree. Adjust them.
You may have a bent or warped blade causing the "tilt."
Thin blades may be stiffened with blade stabilizing washers $14
With the saw unplugged remove the blade. Grab the threaded arbor shaft and pull it up and down. Next push the shaft straight in and out. If there is wiggle the bearings are worn and may need replacing.
Feb 26, 2011 | Delta 36-979 10" Left-Tilt Contractor's...
I have a Contractor's Craftsman 10 " table saw, #113.29884, that will not tilt to a true 45.degrees. It starts to bind up at about 43 degrees and refuses further tilt just shy of true 45 degrees. Thus four...
yes there is, first I would unplug the tool and tilt on its back and thoroughly try and clean the debris from the undercarriage. Then go to managemyhome.com and download a manual for this, I was looking at page 55 and it talks about how to reset the saw to make square cuts. Let me know if you need more assistance
Aug 25, 2010 | Craftsman 10" Table Saw
TABLE SAW MODEL JTAS-10-1 SERIAL # 9031109
my table saw jet model jtas-10-1 serial # 9031109 stock # 708510
Aug 21, 2010 | Jet 10" Xacta Saw Left Tilting Arbor...
Jet saw Manual for a JTAS-10/12
Jet's Manual site is here. There are a number of manuals for Jet table saws there. I believe the exact manual you want is here though.
If this helped, please vote. Thanks!
May 25, 2010 | Jet 708663PK/JTAS - 10XL50 - 1PK 3HP 1Ph...
45 degree tilting problem
You have set screws in the table top, they stop the trunnions from tilting at a certain point, just blow out the dust and get a wrench in there and turn it up or down, they stop tilt both directions.
Dec 14, 2009 | Delta Saws
45 degree cut
loosen the miter lock, tilt the table to 45 deg. tighten the miter lock
Feb 19, 2009 | Makita 7 1/4" Circular Saw 5007NB
Jet 10" Xacta Saw Left Tilting Arbor Tablesaw 708661 Logo
29 people viewed this question
Top Jet Saws Experts
woodzowl307
Are you a Jet Saw Expert? Answer questions, earn points and help others
