Question about Sub-Zero 632 / S
Subzero 700BR Refridgerated Drawers Not Cooling
Over a few days the drawers began warming up. First thought was to remove the kick plate and vacuum the fins. Found that they were totally covered in lint / dust. I vacuumed them and put the kick plate back. The compressor still works but the drawers are not cooling. I have turned the unit off, reset the cooling temperatures and still the same problem. Is there an "easy fix"? That is, before calling in an appliance repair person. Not sure if it may be the thermostat? Thanks
  • 175 Answers
If your unit is new enough to have an on/off button on the keypad, then put it into diagnostic mode by pressing and holding the "colder" button, the pressing the on/off button at the same time. the display should change and it should read a temp like 67r or 67e. you can scroll back and forth through the 2 temp readings by pressing the colder key. If the fridge has been running, the temp of the one ending in "e" should be no more than 38. If it is, then you most likely are low on freon and will need to have the evaporater replaced. The part will be covered under the 12 year parts warranty, but the labor will only be covered for 5 years.(from date of install, not date of manufacture printed on the lable) If you want to go into it more, take the lower drawer out and remove the 6 screws holding the panel to the floor inside the fridge, then slide out the floor panel. Look at the coils in there, and if you see a ball of ice on the left hand side, you have a freon leak and the above repair is what youll need to to. if its older than 5 years, ecpect to pay about$500 to have it fixed...it's a mojor pain. If its less than a year out of the 5 year, call subzero...theyll probably take care of it for you anyways. Good Luck!
Posted on Jul 18, 2007
  • Corey Grove Sep 04, 2012
    I have the exact same problem, but my subzero does not have the on/off switch on the keypad. Any suggestions?
SOURCE:
Inside rear panel bulging
Unplug the unit and take out all the drawers and remove the back (behind the drawers) panel carefully. (This back panel has foamy thermal insulation behind it and this will be probably be enmeshed with ice - you may have to wait awhile for this ice to melt before you can remove the panel, even after you have unscrewed it.
When you have got the back panel off, you will see a large solid block of ice, probably halfway up the cooling coils, right down to the bottom of the exposed space. You have to melt all this ice (I used a hair dryer to blow warm air onto the ice (have towels and a bucket ready to mop up the melted water, otherwise it will run over the floor. When you have melted all this ice, you will see a drain hole at the bottom of the exposed space. This will have ice in it and it must be cleared.
Then replace the back panel and all should be OK.
The panel bulges because ice/water is accumulating behind the panel, water, when it freezes, expands, forcing the panel forwards.
I reckon it's a Hotpoint Design fault. What is supposed to happen is that during the heating cycle, melted ice drops down from the cooling coils and down the drain hole onto a plate over the compressor unit, where it evaporates. BUT, during the cooling cycle, a fan circulates cold air from the cooling coils, through the entire unit, which includes the chamber behind the panel that is below the coils. Thus this chamber gets cold (-18 deg.C) so that water dripping down during the heating cycle is frozen before it has a chance to fall down the drain hole.
I now defrost in this manner every six months or so. Sadly, very sadly, Hotpoint, like other white goods manufacturers (Baxi Potterton boilers for instance) do not reply to my enquiries.
Hope this helps.
Feb 19, 2013 | Hotpoint 6.92 cu. ft. / 196 liter Upright...
Sub zero freezer drawer frozen shut
Subzero freezer: We had all our drawers stuck, including the ice drawer. We turned off the refrigerator, took all the drawers out and defrosted the rails with a hair dryer. The ice drawer was misaligned, so we reset the allen screws on the left to be the correct width. All better!
Sep 08, 2012 | Refrigerators
SubZero 532 model Water collecting in bottom of refrigerator below vegetable drawers
Check out these tips...they can help you figure out whats going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
Sep 08, 2010 | Refrigerators
We can't find the model number on our old fridge we are trying to recycle and get a rebate.
Good day,
Look under the front kick plate (grille). You will have to remove it. If not there, look for an embossed plate inside the fresh food compartment. It may be covered by drawers, so you will have to look.
A general rule is it is located in a place that would not require you to move the machine, and it is never on a door, because they can be replaced.
Aug 18, 2010 | GE Refrigerators
Subzero 601R Extremely Difficult to Open
This is a problem with freezers that have their drain outlet blocked.
Clean the doorseals anyway with a warm cloth and soapy water, then remove inner drawers. There should be an access panel at the rear to remove, and this will reveal the cooling coils and the drain at the bottom of these. You will need a short length of wire to clear the pipe. Make sure power is off while you do this.
Sep 26, 2009 | Sub-Zero 650 / O Bottom Freezer...
Water on the bottom shelf of the Refridgerator
Has the refrigerator got a wet inner back?
Ff this is wet, adjust it until this solid ice 'blobs', bt not encrusted, like in a freezer
The refrigerator may not be cool enough and the natural warm moisture allowed into the cool compartment when the door is open is condensing into fluid before it is cooling sufficiently to suspend the moisture as a vapour. If the cool compartment is cool enough, any warm air admitted ill be chilled before it is allowed to condense, keeping the refridgerator dry.
However, the only drawback is that you will have to monitor it to prevent the build up of excesive ice.
Also, whether the refridgerator is either empty of full willaffe the day to day operation.
Hope this helps.
Oct 20, 2008 | Whirlpool ET1FHTXM Top Freezer...
Ice acculation under crisper drawers
No. There is, however, a drain hole in the back center that tends to get plugged. Remove the lower two drawers and see if it is plugged. It drains to a pan under the unitand behind the kickpanel
Oct 16, 2008 | Sub-Zero Refrigerators
Subzero 550
Call a servicer to determine if a mullion heater is called for.
Aug 02, 2008 | Sub-Zero Bottom Freezer Refrigerator
SubZero 550 not cooling, ice film
1. check the comp. working touch the top of the comp. 2.if the motor comp. working touch the high side tube of the motor comp. if to hot the freon is ok. 3. check the cooling fan inside.
Sep 23, 2007 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 632 / S Logo
4,689 people viewed this question
Top Sub-Zero Refrigerators Experts
John Tripp
John Tripp
Steve Allison
Steve Allison
louis_benton
Level 1 Expert
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
