Question about Craftsman Drills
Table wont tilt on king seeley drill press - Craftsman Drills
3 Suggested Answers
SOURCE: Manual for 1950 Craftsman Drill Press
Not sure if you ever found the manual for this model number. I just picked one up at a garage sale last weekend and it actualy had the manual with it. Doesn't really go into any overhaul of the machine, but does have a exploded view of the parts.b329678.jpg
Posted on Jul 21, 2010
  • 54 Answers
SOURCE: Looking for replacement benchtop drill press table.
On a small drill press you could make a 4.5" high riser block. Steel bar would be best. You could roll pin a bunch of 3/4" thick bars together in a stack just big enough to lock to the base T-slots. For tall parts you just then pry some of the bars off the roll pins with a big screw driver. I like to get rid of Universal or Adjustable stuff as it always introduces flex, movement while running and non-scoocum rigidity!
Scoocum Rigidity: Pertains to Harmonics of metal cutting with anything sticking out more than 1" from a fixed support of some kind. And also pertaining to large Cedar Totem Poles of the Pacific West Coastal Indians.
Posted on Dec 17, 2011
Parts manual for drill press job mate model # 55-5901-6, better yet need work table (not the sliding part on the post) just the tilting table ?
Fixya does not supply replacement work tables. For the parts manual, contact Job Mate directly.
Jul 19, 2017 | Drills
I am trying to find a table crank for a King Kong Drill press. KSD-42H drill press 14mm shaft size
Sorry we do not sell parts nor do we have anyway to locate them for you.
Jul 13, 2017 | Drills
My spindle slide out of the drill press. I remove spindle to clean , what did I do wrong.?
Please look at this site:
http://www.ebay.com/itm/DELTA-MILWAUKEE-14-Drill-Press-DP-220-Instructions-Parts-Manual-0239-/310388408599
This site has pictures that might help:
http://www.ebay.com/sch/sis.html?_kw=Vintage+Delta+14%22+Drill+Press+DP220+%22Triple+Duty%22+Bench+Model+Tilt+Table
Jan 23, 2013 | Delta Woodworking Vintage Delta Dp 220 14"...
My pinion arm works and lowers my drill bit but it will not go back up, it just stays down. Is there some sort of spring or adjustment that needs fixing so it will automatically go back up?
Most presses have a knob on the left with a spring in it just for this purpose. Mine is ancient and all I do is spin it and it tightens up. Check it out.
Jun 13, 2010 | Delta 15IN Stroke Production Drill Press /...
Feb 14, 2010 | Craftsman Drills
The chuck has come off my delta desktop drill press. nothing i can do will get it to stay on.
clean the spindle and the inside of the chuck with easy off oven cleaner. get it all very clean and then be sure to remove all of the debris. pound the chuck onto the spindle with either a rubber mallet or put a block of wood under the chuck and use a regular hammer. DO NOT hit the chuck directly with a steel hammer.
Mar 31, 2009 | Delta 15IN Stroke Production Drill Press /...
The shaft on my Delta floor mdoel press drill keeps sliding out
This sounds like a morse taper adaptor. if so look at the taper for any unusual wear. if none what I would do is get something like brake clean or similar product to remove all oil and grease. clean the shaft and the internal socket. wipe off with cleam paper towel after cleaning. retract the chuck jaws to prevent damage to the chuck and align the tang on adaptor with the internal socket. Take a piece of wood and hammer and hit the chuck seating the taper. You can also try using the table with a block of wood and the feed handle to seat it. If it continues to fall you have worn parts that need replaced. Good luck
Jan 06, 2009 | Delta 15IN Stroke Production Drill Press /...
Drill Presses Features
You compare the following features: Horsepower (HP) is the maximum power produced by the motor. Higher horsepower allows you to bore larger holes through tougher material. Drill presses are available with motors from 1/4 to 1 HP. Size/center drilling capacity is determined by the distance from the center of the chuck to the column. Since the press can bore a hole in a circle with a diameter two times the distance from the center of the chuck to the column, the size is listed as twice the distance from the column to the center of the chuck. A 16" drill press can drill a hole up to 8" from the edge of a straight board or at the center of a 16" diameter circle. Variable speeds allow you to drill different diameter holes through different materials without damaging the material or drill bits. Drill presses are available with five to twelve speed settings. The more speed settings, the more versatile the drill press. The table on most drill presses can be raised and lowered along the entire length of the column. It can also swivel 360° around the column for boring oddly shaped pieces. Better presses have large, tilting tables with fences. Quill travel determines the depth to which the press can bore holes. Greater quill travel allows you to bore deeper holes. Depth-stops control the depth to which the quill descends and limit the depth of the hole. Depth-stops are good for repetitive boring and dowel holes. The more precise your depth-stops, the more accurate your boring operations.
Aug 27, 2008 | Makita 6825 Factory Reconditioned Drywall...
Drills Logo
65 people viewed this question
Top Craftsman Drills Experts
Gareth Cockram
Gareth Cockram
John Trevino
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
