Question about Akai PT5492S 54" Rear Projection Television
Timer won't turn off, TV won't respond
Akai Model PT5492 manufactured in Nov. 2001...The power went off in the house and with it came back on the timer light was on. The TV won't respond at all, yet the timer light remains red. Is there any way to turn reset the TV? We no longer have the original TV remote control for this TV. Please Advise....
  • 1 more comment
  • christineewo Jan 25, 2009
    We tried to leave it unplugged for several hours, 8+, but when we plugged it back in the timer light was still on. Still is...any other suggestions?
  • christineewo Jan 27, 2009
    It's now been a few days with the TV left unpluged. I plugged it in this morning to see if the prior Expert advice worked but the timer light is still on. We have tried pressing the on/off switch and no reponse...please advise....
  • christineewo Jan 29, 2009
    Thank you for the clarity. Where can I purchase the power supply?
  • 15,935 Answers
In your case, one of the following has happened...
1. The Sleep Lock has been activated on your TV.
Without the remote, it cannot be de-activated.
2. The power supply has failed.
3. An IC has been damaged.
You can look for a used remote on the internet on various sites like eBay.
However professional service is required for all 3 of these events. Convergence, and service mode can only be controlled with the remote.
Posted on Jan 27, 2009
    President:
  • 1,952 Answers
To reset your TV, unplug the power cord from the wall outlet, power strip, etc. Keep your TV unplugged for about 5 minutes. Then, plug the TV back in, turn the TV on, and see if the problem is fixed. If the problem remains, then please contact RCA Customer Support using the Support
  • mohammed marika thambi
    mohammed marika thambi Jan 27, 2009
    The easiest way to make TVGOS search for a new host
    channel is to change the ZIP code in setup. This causes TVGOS to search for a
    host channel with data for the new ZIP. If you like, you can change the ZIP code
    to something arbitrary, turn the TV off, turn the TV back on, then set the ZIP
    code back to your home ZIP.
    Alternately, you can issue a "reset" command to TV Guide
    On Screen by entering the Guide, selecting the "Setup" tab, pressing "down"
    once, then entering "653274147" on your remote. If you entered the code
    correctly, the screen will blank momentarily and the guide's internal settings
    will be wiped. Program listings and channel lineups are preserved, but the clock
    will not be reset until TVGOS finds a host station for your ZIP code. Unplugging
    or hard-resetting your TV may have the same effect.
    President:
  • 1,990 Answers
Welcome to Fixya! They are Correct, The Power Supply will need to be Replaced. The Timer will still stay on Because it uses Very little Electricity and there is Just enough Coming in for this Option to Connect. Please Rate my Response, I need all the Help That I can Get! Thanks!
  • Travis Humphries
    Travis Humphries Jan 29, 2009
    There are a few Authorized Service Centers that will sell Parts in Addition to Repair.
  • 10,594 Answers
I think its some kind of power supply problem that TV does not power up.
Timer option can not last so long and can be canceled by pressing power / standby switch any time.
Posted on Jan 25, 2009
  • Shahid Electronics
    Shahid Electronics Jan 27, 2009
    TV have problem in power supply or horizontal deflection section and requires qualified TV tech for proper fix.
  • 11,896 Answers
The only way to do a reset in to leave UNPLUGGED for at LEAST 4 hours. That is the only way to reset it. If the reset doesn't fix the problem then it is due to faulty power supply or a blown fuse that you can find by removing the back of the tv
Posted on Jan 24, 2009
  • 2 more comments
  • Nate Stansfield
    Nate Stansfield Jan 26, 2009
    on SOME tv's, you can press and hold the volume bottons on the tv set itself to fix this problem.
    But the tv repair man said it would be the convergence modules
  • Nate Stansfield
    sorry, I meant holding the up and down buttons at the same time for 10 seconds.
  • Nate Stansfield
    The only other thing u could try is to press and hold the power button for 15 seconds. This resets some tv's as well.
    If you have tried both the reset suggestions I have given you and they haven't worked, I would either have the power supply replaced like I mentioned before
  • Nate Stansfield
    Nate Stansfield Jan 29, 2009
    If you unplugged it for 4 hours, tried to press and hold power button for 10 seconds, and tried to hold up and down volume buttons at the same time for 10 seconds, and the tv didn't respond to the reset, THAN YOUR PROBLEM IS You will have to replace all ofthe capacitors on the power supply.
    Parts express and Centerpointe Electronics sells the Capacitors you
    will need. Cost of fix $30 and an afternoon of soldering.
  • Akai Master
  • 19,396 Answers
Unplug TV power cord for two hours , and plug it back, this will fix the problem.
Will any universal remote work with my Akai Model CFT2790?
Hello there
YES !!!!
Do you simply HAVE to have UNIVERSAL Remote?
For this TV the correct remote is here for 10 American dollars. http://www.replacementremotes.com/AKAI/Buy-10111J-AA5910111J-TV-Remote-Control.html
On the other hand if you must have a universal remote, then it WILL work with remote code for Akai which is 002; See the instructions with the new Universal remote.
Obtained from here http://en.kioskea.net/faq/281-codes-for-universal-remotes#universal-remote-codes-by-brands
Sep 19, 2014 | Akai Televison & Video
I HAVE A AKAI MODEL NUMBER PT5492 TELEVISION I HEARD A LOUD NOISE THEN THERE WAS NO PICTURE ONLY SOUND.
Sounds like your ballast need to be replaced, did you get sparks at the back of your tv?
Aug 24, 2008 | Akai Televison & Video
Akai tv model PT5492 has real bad orange tint that will not go away, with any adjusting.
it souds like your blue and green tube are getting weak and will need to be replaced
unfortunately they are no longer avail I would think about retireing that set
Dec 10, 2009 | Akai PT5492S 54" Rear Projection...
Akai tv
Not if it doesnt have HD on it all HD Ready Sets have it printed on TV.
Dec 27, 2008 | Televison & Video
Akai PT5492 54"
HELLO IT SOUNDS LIKE YOU HAVE A BAD FLY TRANSFORMER. . THAT NEEDS TO REPLACED. "GOOD LUCK"
Jul 22, 2008 | Akai PTH5498 54" Rear Projection...
Mitsubishi WS 55859 Green light flashing
HELLO. WELL SOUND'S LIKE YOU A PROBLEM.!! THAT COULD BE A FEW DIFFRENT THING'S.!!! FIRST THING YOU WANT TO DO IS UNPLUG THE SET..!!! THEN TAKEOFF THE BACK.!!! AND LOOK FOR FUSE'S ON THE BOARD. TO SEE IF YOU HAVE A BLOWN FUSE.!!! GET BACK TO ME AND LET ME KNOW .? OK ASAP. "GOOD LUCK"
Jun 15, 2008 | Mitsubishi WS-55819 55" Rear Projection...
Won't turn on
If you're using a DVD player or other component using the Component cable hookup, try unplugging that from the mix, unplug the power cord for the TV from the wall and wait 15 seconds and plug it back in, then power the TV back on. Mine used to do this and I gave up on the component cable option and went back to composite (RCA).
Feb 09, 2008 | Akai PT5598HD 55" Rear Projection...
My akai tv
IF IT IS A POWER INVERTER TRY EBAY OR PARTSTOR.COM SAME FOR THE POWER SUPPLY
NOW AS TO THE POWER SUPPLY--- ALL POWER TO THE HOUSE IS IN A.C. (ALTERNATING CURRENT ) THE POWER SUPPLY CHANGES THIS TO D.C. ( DIRECT CURRENT ) WHICH IS WHAT ALL OF THE STUFF IN YOUR HOME RUNS ON THIS PART CAN SOMETIMES BE A LITTLE HARDER TO GET BUT GO WITH THE ABOVE LISTED SITES OR DO A GOOGLE SEARCH FOR IT
Dec 18, 2007 | Akai PT4298HD Rear Projection Television
Akai pt5492
This could be one of many different issues. Main flaw with these units are as follows:
Blue picture tube leaks coolant onto neck board and mainboard causing problems.
Dec 17, 2007 | Akai PT5492S 54" Rear Projection...
Our tv will not turn on
Our AKAI was just 14 months old. A few days ago, it died also. Blank screen, no sound, but the timer light will flash on a couple of times when you try to power it up. It even sounds like it wants to turn on. I paid a tech to come to my house $65 and it turns out to be the power supply $385. I checked other chat boards and many people are having this same problem with their AKAI 42" (PT4298HD) televsion. A real piece of junk this model! Sorry for the bad news!
Sep 10, 2007 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Akai PT5492S 54" Rear Projection Television Logo
59 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
