Question about Ruud UAKA042 Air Conditioner
Icing up on a rudd air conditoner -heat pump upne-036jaz achever
4 Suggested Answers
  • 182 Answers
SOURCE: Ruud Heat Pump
this may indicate you have low voltage but no high voltage.check fuses and breakers.
Posted on Aug 09, 2008
  • 2976 Answers
SOURCE: When my Rudd air conditioner/heat pump is running,
It's working properly. Air conditioners make it feel cooler by removing humidity from the air.
Posted on Aug 04, 2009
  • 59 Answers
SOURCE: My rudd Heat pump upka043jaz condensor is iceing
Either defrost board, low on charge, thermostat at coil, or reversing valve
Posted on Dec 24, 2010
RUDD Model UBHC-21J18SFA: Emergency heat not automatically engaging. Used to work, now I must manually turn the thermostat to "Emergency Heat" to get the elements to engage. What's broken?
Sounds like your Auxillary heat is out (the element that is energized when an air to air heat pump can't keep up with the thermostat setpoints).
Jan 30, 2014 | Heating & Cooling
No heat from heat pump
if outside temperture is to low it will lock out heat pump operation.
Nov 07, 2013 | Dometic Rooftop RV Air Conditioner
Rudd acheiver 10 heat pump wont stay cool
did you change the air filter and do not set it below 70,the tstat is not a gas pedal its works like a light switch, on or off, also please don't use your breaker as a switch its a safety device and will be damaged over time,If the unit starts to form ice (and it should never do that)
set the tstat from cool to off and the fan button from auto to fan on,this will speed up the thawing
Jul 02, 2013 | Ruud UBHC Air Conditioner
I have a RUDD UPNE-042JAZ. How many tons is that?
That is a 3.5 ton heat pump at 13 SEER.
A S.E.E.R. (Seasonal Energy Efficiency Rating) is the rating and performance standards that have been developed by the U.S. government and equipment manufacturer's to produce an energy consumption rating that is easy to understand by consumers. It has a universal formula and conditioning that can be applied to all units and compensates for varying weather conditions.
Basically, the lower the S.E.E.R. rating, the more energy (electricity) is required to produce the desired effect.
Jun 13, 2011 | Heating & Cooling
RUDD UPKA-061-JAZ Specs:
Ruud Air Conditioning Division • P.O. Box 17010
Fort Smith, AR 72917-7010 • 479-648-4900
Jun 13, 2009 | Heating & Cooling
Rudd Achiever A/C float switch is clogged.
If the pump was bad the switch is supposed to shut down the ac so the water damage won't occur. You most likely have a bad drain.
May 11, 2009 | Frigidaire FAC107P1A Wall/Window Air...
Ruud Heat Pump
Check to see if there's low voltage reaching the contactor's coil. If there is. and it doesn't close (pull in), then it's defective and should be replaced. Cut the power and check ohms to be certain.
Aug 09, 2008 | Ruud UAMB Air Conditioner
Ruud UAKA042 Air Conditioner Logo
24 people viewed this question
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
